09-25-2016, 08:21 PM | #1 |
Drives: Red 2013 Camaro SS, Black 1980 Z28 Join Date: Jan 2015
Mods and Rear Wheel HP Question?
I have a question about the RWHP my '13 Camaro SS should be making with the mods I have. I have a cold air intake, SP Longtube Headers, Exhaust, HHP Custom Cam, LS3 Conversion and tune. Prior to the cam install and conversion, I had 370rwhp. After, my car has 432rwhp. The before and after dynos were done on a mustang dyno. Are the numbers consistent with the mods? Advice please! Thanks in advance!
09-25-2016, 09:07 PM | #2 |
+/- a few horses here and there. But that sounds about right.
I solve problems for a living. Either accept my advice or go figure it out on your own.
09-26-2016, 01:29 AM | #3 |
Too much is never enough!
Actually sounds dead on. There is a sticky dedicated to this exact question.
http://www.camaro5.com/forums/showthread.php?t=114824
09-27-2016, 08:03 AM | #4 | |
Drives: 2011 Camaro SS Convertible Join Date: Nov 2015
09-27-2016, 08:08 AM | #5 | |
Drives: Black L99 2SS/RS Join Date: Mar 2014
Cam swap - $2,500 - $5,000 That includes tune and install for everything. |
09-27-2016, 08:17 AM | #6 |
09-27-2016, 08:24 AM | #7 |
Really depends though, you can get cheaper / good quality headers for around $500 out the door.
So then there's the cam where all bets are off... depends on your goals. If you want a weekend warrior that shakes the block with each lope, then you're looking at an easy $3.5k on an LS3 (Manual) You're always going to be looking at least $4.5k for an automatic cam... there's more labor involved with the autos so there is a tax on them. Let's say you have a manual (ls3) then you can pick up 80 rwhp for an easy $3.5k |
09-27-2016, 04:36 PM | #8 |
Drives: Miss Con Ception Join Date: Aug 2016
09-27-2016, 04:44 PM | #9 |
Cam kit or power adder (s/c, turbo) seem to be about the same costs, just supporting mods after those seem to wake the cars up.
when i s/c'd, i jumped from 367rwhp (fbo) up to 434rwhp (don't remember tq #'s), cost was similar. $7100 for the s/c kit, installation & tune. now i'm looking at adding a cam, estimates show around $5k with a stall & cam. then need a roll bar to keep going to the drag strip, that could be anywhere from $1500-$3000 then of course, more boost... wheels... tires.. never ends lol
Robert
12.012 @ 115.75mph DA: 2371 | 486rwhp/467rwtq (11/8/2015)M 11.265 @ 123.55mph DA: 2318 | 526rwhp/532rwtq (11/19/2016)M 10.722 @ 132.21mph DA: 850 | 645rwhp/581rwtq (12/3/2017)M 10.609 @ 130.19 DA: 975 | 675rwhp/629rwtq (2/16/2020)D Build: E-Force w/ 3.25" pulley (11lbs of boost), 10% OD under pulley, Fore Dual Fuel System, ID850's, AEM CAI, Borla Long Tubes, Flowmaster Super 10's, Circle D 3200 converter 258mm triple disc lockup, cam 226/242 116+4 LSA, ZL-1 Rear end, E85 & BRC Raceworks Tune (previously known as CMS) Youtube Channel: http://www.youtube.com/c/RobertMitchellRCM |
09-27-2016, 05:00 PM | #10 |
Drives: 2013SS IOM LS3 Join Date: Mar 2013
OP: is yours an auto?
I have an M6, '13SS with identical mods (albeit different vendors - tobofab intake, kooks headers and green cats, corsa catback, nightfury cam and a tune by FSP. I dyno'd at 475rwhp
CamaroSS - Daily 476whp@6300rpm, 2001 Dodge Viper GTS - Toy (sold)
09-27-2016, 06:41 PM | #11 |
Drives: 2011 ss 2ss auto camaro Join Date: Mar 2015
Do it your self I got off my stuff from Texas speed l99 to ls3 kit cost me 1700 did the swap myself had a friend tune it for me .now have the rod mod from gpi just I installed that .only thing stock left is heads.
09-28-2016, 04:13 PM | #12 |
Like CamaroFred said samman11.......the 62 hp was just from the cam swap and tune. I had a gain of about 50 when I did the headers, CAI, Exhaust and tune. The cam swap was 3700 with parts and labor.
09-28-2016, 06:25 PM | #13 |
Something wrong with the numbers here cause 370 RWHP is stock numbers.
No way he was only getting 370 with headers. Headers will put you to 400 ish and the cam and tune did the rest. If anything the numbers for both mods seem low. |
09-29-2016, 11:35 AM | #14 |
Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
I spent $8883.00 for my performance mods that I installed myself and with the cost of a dyno tune. 546/rwhp, that is $48 per HP.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
