Old 06-10-2020, 01:37 PM   #1
CJ27
Drives: Chevrolet camaro zl1
Spark plug question
I'm currently running the 3347 BR7EF. Has anyone ever run iridium plugs and had any luck with a modified setup?
2014 Sliver ZL1. Built engine, Stage 1 Frankenstein heads, Magnuson, SW long tubes, AFCO H/E, She Gone cam, flex fuel sensor, meth injection. 820rwhp e85.
CJ27 is offline   Reply With Quote
Old 06-10-2020, 02:48 PM   #2
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
Your car came from the factory with a set of NGK Iridium Plugs, and most people on the forum run them modified. Most move from the stock TR6IX to the TR7IX.
ZMEnow is offline   Reply With Quote
Old 06-10-2020, 04:26 PM   #3
CJ27
Thanks, just running what the tuner told me to.
Old 06-10-2020, 04:57 PM   #4
Dutchman427
Dutchman427's Avatar
Drives: 2012 ZL1 #1329 M6
BR7EFs work good. I gap mine at .028
2012 Camaro ZL1 #1329 M6 Summit White
Built by Mike @ Rapid Motorsports
784rwhp 757 rwtq on 93 Octane ET - 10.97 @ 128
Heads-Blower-Snout-TB ported & prepared by Jeremy Formato of FasterProms
http://www.camaro5.com/forums/showthread.php?t=395950
Rapid Motorsports 396ci Build
https://www.camaro5.com/forums/showt...1#post10321301
10.832 @ 130.99
Dutchman427 is offline   Reply With Quote
Old 06-11-2020, 07:38 AM   #5
CJ27
Mine are gapped the same but they just don't last long.
Old 06-11-2020, 04:54 PM   #6
Dutchman427
How long are they lasting you?
10.832 @ 130.99
Old 06-11-2020, 11:24 PM   #7
CJ27
These lasted almost 15k. Going to the TR8IX next time.
Old 06-12-2020, 04:14 PM   #8
Dutchman427
ok. good to know
10.832 @ 130.99
Old 06-12-2020, 07:08 PM   #9
'10CamaroDude
Drives: 2010 Camaro LS
Not that it's the same, but I am running Iridium in my V6. Denso
Iridium TT.
'10CamaroDude is offline   Reply With Quote
Old 06-12-2020, 10:26 PM   #10
d kings z28
Drives: 2014 white z28
If not NGK’s don’t wast your time& money
d kings z28 is offline   Reply With Quote
Old 06-23-2020, 04:59 PM   #11
CJ27
What are you gapping them at?
Old 06-23-2020, 09:38 PM   #12
ZMEnow
.40 is standard, but depends on your tune. I personally would not go under .34, but some are down into the .2x range which is a race tune.
Old 06-24-2020, 02:14 AM   #13
CJ27
Thanks. Tuner and the shop he works at haven't suggest the iridium and just use the BR7EFs.
Old 06-24-2020, 09:16 AM   #14
ZMEnow
Doesn't want to pay the extra dollar, but will charge you the same.. Its called Margin..)
