Old 02-14-2015, 10:46 AM   #1
Dutchman427
Dutchman427's Avatar
Drives: 2012 ZL1 #1329 M6
Rapid Motorsports ZL1 Build- 784rwhp/757rwtq
The ZL1 was dyno tuned today and put down 784rwhp and 757rwtq. On the first pull, it laid down 751rwhp. Car is running 15lbs of boost and is on the stock bottom end. (We will have to see how long it lasts!)
The ZL1 is down at Rapid Motorsports in Birdsboro, PA. Mike is a well known LS engine builder/tuner and his 99 Trans Am was the first LS1 to go into the 9s. He will be building and tuning the car. I will also be using Mike's custom grind blower camshaft. Mikey's cams always make good power and he is quite popular with the F-body crowd. Jeremy Formato of Fasterproms will be porting/milling the heads, blower, snout, and throttle body. My goal is to get as much power out of the stock components as possible. I will post up dyno results when it is done and looking forward to going to the track when it gets warm out.
Supporting Mods-
Metco 2.50 Pulley
10 % Lower Pulley
Kook 1 7/8s Headers with O/R pipes
Ron Davis Heat Exchanger
RotoFab CAI
ID850s
Brian Tooley Springs
Mighty Mouse Solutions Catch Can
I am sure I am forgetting something.---Update-I am not forgetting anything.
2012 Camaro ZL1 #1329 M6 Summit White
Built by Mike @ Rapid Motorsports
784rwhp 757 rwtq on 93 Octane ET - 10.97 @ 128
Heads-Blower-Snout-TB ported & prepared by Jeremy Formato of FasterProms
http://www.camaro5.com/forums/showthread.php?t=395950
Rapid Motorsports 396ci Build
https://www.camaro5.com/forums/showt...1#post10321301
10.832 @ 130.99
Dutchman427 is offline   Reply With Quote
Old 02-14-2015, 10:48 AM   #2
LuckyZL-1
Ragtop Rocket!!!
LuckyZL-1's Avatar
Drives: Black on Black Convertible
Awesome can't wait to see results!
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package.
744rwhp 727rwtq
LuckyZL-1 is offline   Reply With Quote
Old 02-14-2015, 10:49 AM   #3
Dutchman427
Thanks man...Me too!
10.832 @ 130.99
Old 02-14-2015, 11:07 AM   #4
sscamaro
sscamaro's Avatar
Drives: 2010 2SS, 2017 Silverado LTZ
What S/C are you using? Mikey put LT headers, a can and a tune in my 02 Camaro SS in 03. Haven't seen him in a while. Tell him Ralph said hello. I've done all the work on my 2010 SS myself, with the help of a buddy. It's a lot cheaper that way.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
sscamaro is offline   Reply With Quote
Old 02-14-2015, 11:56 AM   #5
Dutchman427
Hi Ralph, I am using my factory LSA blower, just getting it ported. Mike does all the tuning for County Corvette. He is still doing select builds though.
10.832 @ 130.99
Old 02-14-2015, 12:23 PM   #6
owhite3003
Z-BEAST
owhite3003's Avatar
Drives: 2013 JDP ZL-850 Track Spec ZL1,
I
owhite3003 is offline   Reply With Quote
Old 02-14-2015, 12:32 PM   #7
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Very nice...
Any projected hp#'s?
Mods:
Old 02-14-2015, 12:48 PM   #8
Dutchman427
Originally Posted by KaBoom1701 View Post
Very nice...
Nothing projected yet. In a week or two I will know.
10.832 @ 130.99
Old 02-15-2015, 02:25 PM   #9
mmarx82
mmarx82's Avatar
Drives: '12 ZL1 #1609
If it's not too late I would like to know the before and after temperatures from using the Thermal Reduction Spacers. Maybe after 4-5 runs...
Life is too short to drive cars that suck.
My build Thread
mmarx82 is offline   Reply With Quote
Old 02-15-2015, 02:34 PM   #10
Dutchman427
The car is apart man. I am having these installed as recommended by Jeremy Formato.
10.832 @ 130.99
Old 03-14-2015, 03:33 PM   #11
Dutchman427
Got the ZL1 cranked over today and it sure sounds healthy. Mikey will be taking it down for dyno tuning this coming Wednesday. I am looking forward to seeing what it puts down.
10.832 @ 130.99
Old 03-14-2015, 08:18 PM   #12
Top Off
Drives: 2012 LS3 1SS/RS Vert
Looking forward to seeing what it does.
Top Off is offline   Reply With Quote
Old 03-17-2015, 08:41 AM   #13
harner
harner's Avatar
Drives: 2018 ZL1 A10
Also looking forward to the build. Mikey is a great guy, glad he's still building and tuning!
SOLD! 9/1/2020 2018 ZL1 A10 Hyper Blue - Rotofab CAI, Gibson catback
@SurefireDetail
OEM ZLE tails/third brake light, Gen5DIY reverse LEDs, front Amber LEDs, SMG laser LED side markers, SMG smoked reflectors
1994 Trans Am LM7/CPT 4L60E/9"
1987 IROC
2006 Silverado
harner is offline   Reply With Quote
Old 03-17-2015, 06:46 PM   #14
Dutchman427
Yes he is. Car is now getting dyno tuned on Thursday. He is doing all of County Corvette's tuning.
10.832 @ 130.99
