Old 03-17-2013, 08:34 PM   #351
SUKXOST
Do you even lift, bro?
SUKXOST's Avatar
Drives: 2013 1LE Camaro
Originally Posted by tramtwo View Post
can't figure it out.... which leds did you change
The door panel LED's....stock is a light blue. Below is a the link to a DIY thread for it:
http://www.camaro5.com/forums/showthread.php?t=283380
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461
SUKXOST is offline   Reply With Quote
Old 03-17-2013, 09:33 PM   #352
tramtwo
tramtwo's Avatar
Drives: 2021 1LE
Oh... what an idiot I am. Thought u had already done that.... I was looking at every other led.
tramtwo posted this on the go
tramtwo is offline   Reply With Quote
Old 03-17-2013, 10:00 PM   #353
Vette TPI
Vette TPI's Avatar
Drives: 1987 Corvette TPI
Originally Posted by SUKXOST View Post
O'Reillys :P
Not sure....acorn or OEM...whatever is in the pic.....didnt pay attention to what kind.....just wanted locking and black :P
Very nice build thread! I love the car and the power The lugs should be acorn, as I'm sure OEM's are acorn. The lugs that came with my Camaro wheels are acorn.
Vette TPI is offline   Reply With Quote
Old 03-18-2013, 05:50 AM   #354
SUKXOST
SUKXOST's Avatar
Thanks man! Pretty good for a safe tune on very mild A/F.
I think you're right....thanks for the "chart".
Old 03-18-2013, 04:02 PM   #355
Vette TPI
Vette TPI's Avatar
What is your A/F at WOT by the way?
Old 03-18-2013, 04:19 PM   #356
SUKXOST
SUKXOST's Avatar
it's pretty much @ 10 all the way across the powerband and increases a lil towards the very end (set my redline DOWN to 6400 due to boost peaking @ 12 in cold weather) Like to have less bost and better A/F (11.6) and maybe even gain some power. Will be retuning in the next 30 says or so.
Old 03-19-2013, 11:08 AM   #357
SlyJester7
SoCal HT5 *COTW 8/26/13*
SlyJester7's Avatar
Drives: 2013 SS/RS LS3
Absolutely Beautiful!
SlyJester7 is offline   Reply With Quote
Old 03-19-2013, 11:39 AM   #358
SUKXOST
SUKXOST's Avatar
Old 03-19-2013, 04:52 PM   #359
Vette TPI
Vette TPI's Avatar
Cool! Will be checking in
Old 03-23-2013, 05:48 AM   #360
SUKXOST
SUKXOST's Avatar
New tune confirmed for 29 Mar! This will be a new tuner as my A/F is WAY off (10.0 or less all the way across until the very end) and target is normally 11.6ish. This tuner (Performance AutoSports) is local and 100 miles closer anyways and have a great reputation so I'll be going there.
I got a baseline dyno from them a few weeks ago and it showed (547/511) vs what I originally had from the other dyno/tuner (577/578) with no changes. So something isnt right.
The car feels like it is hesitating at low speeds/RPMs so let's hope things get worked out :P Possible my FIC850 injectors are simply just too big for this build? Low pulse still might be too much? Time and tune will tell
Old 03-26-2013, 05:48 PM   #361
SUKXOST
SUKXOST's Avatar
soon, very soon :P Gonna paint the top half white and leave the bottom black to accent the front splitter
Old 03-29-2013, 04:30 PM   #362
SUKXOST
SUKXOST's Avatar
Rockers did not get done today so it will be next week :P
BUT....
I did get my tune fixed at a new shop:
Steve @ Performance Autosports in Richmond VA:
The blue pull is my "baseline" dyno from a few weeks ago (547/511)....this is after my initial base to from someone else that showed 577/578 a few months ago.
The green pull had the best #'s but had a couple blips to fix
The red pull was the last pull and all the small "issues" with my original tune were worked out. The A/F was way rich and the car was hesitating @ initial throttle.
One the same dyno(after the original tune in NC) with very similar days....from original tune to new tune from Steve @ Performance Autosports....you can see the huge gain across the powerband.....
(30-60WHP and 20-80WTQ....depending on what RMP you reference)
Aside from just the #'s......the throttle response is better and it just seems to run "smoother" I guess.
Old 03-29-2013, 06:12 PM   #363
JHall651
JHall651's Avatar
Drives: 2012 Camaro 2SS LS3 Ashen Grey
What did you use to black out your lights and where did you get it? Looking good btw. That Cog sounds awesome in your vids. I think you just made me have to give Jessika more of my money.
2012 2SS/RS, Magna TVS2300, RX Catch Can, Borla S-Type, Pfadt Stage 4 w/ ZL Spec Sway Bars, ADM Custom Boost/AFR Gauges, Hurst Short Throw, Forgestar F14 Matte Black 20x11 & 20x9.5 Deep Concave all 4, Nitto Invo 315/35 & 275/40, Heritage Grill, Sparks Black Grill SS & Trunk SS, P13W Fog Lights (cool white) w/ DRL Harness, Blacked Out Brake light bezels, Xpel Smoke Light Kit
JHall651 is offline   Reply With Quote
Old 03-29-2013, 06:59 PM   #364
SUKXOST
SUKXOST's Avatar
http://www.phastekperformance.com/20...r-f-lights.htm
Jessika will like to hear that :P
