11-14-2013, 08:32 PM | #1 |
How can I get the max performance value, without losing factory warrantee
I have a new 2014 2SS/RS 1LE. I have a few questions.
1. What kind of performance tweaks can I do while keeping my factory warrantee intact. 2. What are the best value performance enhancements, keeping in mind I would like to use this as Daily Driver Please put the performance enhancements in order of best value /bang for the buck. Thanks |
11-14-2013, 08:47 PM | #2 |
Drives: 2014 Camaro 1LE Summit White Join Date: Oct 2013
Not sure about warranty but I know some long tube headers, intake, tune, and a cam should really wake it up.
Ordered 10-1-13 TPW- 10-28-13 Delivered 11-12-13 |
11-14-2013, 09:05 PM | #3 | |
"Democracy Dies in Darkness" |
11-14-2013, 09:08 PM | #4 | |
Drives: Camaro Join Date: Sep 2013
you could go with SLP SC and maintain a warranty via SLP but its not cheap. probably 10k or so and can be done at any slp approved shop. I'm interest to see what people post. deff. a thread i'll follow. But anything that is going to require a tune is out. I think for the most part you'll get the "you got to pay to play comments" |
11-14-2013, 09:11 PM | #5 |
there are ways to Supercharge and keep a warranty. its a non transfearable warranty from what i've seen.
11-14-2013, 09:12 PM | #6 |
What about cold air intake and performance chips? Do they mess with the warranty?
11-14-2013, 09:15 PM | #7 | ||
I used to be Dragoneye...
Suspension is damn-near perfect for the car....but if that's something you love to change about your cars...Pedders USA has an enhancement package that will tighten everything up and maximize feel & response for a modest price. If you like....you can keep your eyes peeled for prices and availability of Z/28-derived performance goodies from Chevy, too. Quote:
Remember: your warranty is in-tact unless the dealer can prove your modification caused vehicle component failure. Most of the time, however - it is very easy for them to prove "you dun it". Recalibrations of any kind are the one automatic-warranty-void: One of the first things GM requires the service tech to check before approving a warranty claim is the ECM... |
11-14-2013, 09:18 PM | #8 | |
I was under the impression a tune is highly highly reccomended in this case. Wouldnt the headers cause CEL's? but I would love to be educated |
11-14-2013, 09:26 PM | #9 | |
It is recommended. But I know a few who have the intake/header combo without a tune with much success. The only real downside...is sometimes bad O2 readings, and therefore trouble codes. The intake/header combination improves the pumping efficiency of the engine drastically over OE, and leaves some power on the table with regards to tuning to take advantage of this new "breathing efficiency". If memory serves...it's about right for people to see gains of between 30 and 40 rwhp with intake/headers & no-tune, depending on the products....and in between 50-65 rwhp with the same products and a good tune. Could be off just a little bit. |
11-14-2013, 10:18 PM | #10 |
all depends on your dealer.
mine said dyno tune. warrantys out. no questions asked handtune...... revert it to stock when i bring it in then put my tune back on in the bay if i want to, as long as its not there when they have possession. headers- dont effect. tuning them however with the dyno/hand tuner. is what does. anything that the engine is in any way taken apart. by by warranty. if they can connect it to the problem they will. most likely. intake, plugs, wires, exhaust should be 100% fine. ported throttle body, i would assume would be fine. partially because they would never even notice as it looks the same i would say the BEST thing to make your car faster, find a local professional driving course, and take it for giggles. you might learn something new. even if you are a skilled driver. (not saying your not, obviously i dont know your driving skill)
2013 SS/RS 1LE VR-Backup System, SOLO Perforsance HF Cats, Muffler Delete, BBK Off-road X-pipe 2002 35th Aniversary SLP SS-Sold |
11-14-2013, 11:01 PM | #11 | |
See if you can get this in writing from your dealer. i'd bet a boat load of money they wont put it in writing. And who's to say that guy you spoke to is around when you need those repairs. I think most would agree, a tune of any kind voids GM powertrain warranty. There certainly isnt anything that would suggest a hand tuner would keep a warranty valid while a dyno tune would void, or vise versa. I have nothing against tuning, and will most likely go that route. But when I do, i understand the powertrain warranty is gone. OP - Basically if you mod for performance, do so knowing your warranty is in jeapordy |
11-14-2013, 11:03 PM | #12 |
Drives: 2013 IOM 2SS 1LE Join Date: Aug 2013
On my MINI, when I installed a header I had CEL's but installed a module in the rear O2 sensor wiring that told the computer all was well. Maybe there is a similar one that would work on the Camaro? I got it off ebay at the time and I don't think it was vehicle specific. My dealer actually told me about them as an easy fix since the rear O2 sensor is only there to check the cat function and is not used to adjust the engine operating parameters.
11-14-2013, 11:04 PM | #13 |
Difference is. You can't keep a dyno machine in your glove box and revert your ecu to factory at any time.
11-14-2013, 11:16 PM | #14 |
Drives: 2013 2SS 1LE NPP GBE Join Date: Sep 2012
But do the codes reveal that you've tuned it?
