Old 12-11-2013, 10:06 PM   #1
smokum
smokum's Avatar
Drives: 2010 2ssrs
max boost from a maggie
I have a 417 maggie car now. Just wondering what the max boost they will put out safely. Planning on upgrading the 8 rib and building a 10 rib setup or maybe 12 rib.
smokum is offline   Reply With Quote
Old 12-12-2013, 09:55 AM   #2
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
I run 16.5psi on a 10 rib. I don't have any belt slip, and can pulley down once more.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 12-12-2013, 11:10 AM   #3
PIGSMOKR
2010 Lingenfelter SS
PIGSMOKR's Avatar
Drives: 2010 lingenfelter ss
This is prob a stupid question but, where do u find the different rib belts and pulleys? I have found the regular 6 rib ones.
PIGSMOKR is offline   Reply With Quote
Old 12-12-2013, 11:38 AM   #4
smokum
smokum's Avatar
Drives: 2010 2ssrs
Lingenfelter has a 10 rib kit. But it is not cheap. I am machining my own setup because i have a machine shop at my disposal.
Old 12-12-2013, 02:43 PM   #5
Unreal
Drives: 2006 Z06
Belts are available at any auto store, amazon, etc.
Max boost will be determined by heads/cam/etc. You could put a restrictor plate between the blower and see 30psi if you want, or with great flowing heads/motor you may see a lot less. The Maggie has a set amount of air it will move, not set pressure.
Nick
Corvette Z06 -1200ish rwhp
Old 12-12-2013, 02:45 PM   #6
1LESSPROBLEM
Drives: blown
LeftCoast'32 has an 8 rib thats reasonably priced. No belt slip. They sell a blower pulley with grooves cut perpendicular to the grooves, no slip whatsoever. On that 417 depending on cam, head flow, and CR, you should see in the 16-18 range on an overdriven rear and overdriven front with a 2.8-2.9 blower pulley
VF Commodore
LSA
Heads
Cam
Weld
1LESSPROBLEM is offline   Reply With Quote
Old 12-12-2013, 05:40 PM   #7
smokum
smokum's Avatar
Drives: 2010 2ssrs
Does the pulley come with a six pack of belts? Or is it not to bad on them. Great concept. Just wondering how reliable it is? Meaning belt fray or breakage. If it works im in for it.
Old 12-12-2013, 06:05 PM   #8
Unreal
Drives: 2006 Z06
The grooved pulleys like that typically do eat belts faster than normal. Just change the belt every other oil change or so and you should be fine.
Nick
Old 12-12-2013, 11:13 PM   #9
Supercharged SS
Drives: 2010 Camaro
The RIP pulley helped with the belt slip but def didn't cure it. In the high rpms the slip was still present. I ran an 8 rib 3.2 at the track. Car was going 10.06-.08 (on 6 passes). Changed it to a 3.4 non rip pulley and the care went 10.0 on the last 4 passes. The was no additional belt wear running the RIP pulley and I used it for a season.
Without the spacer you won't see anywhere near 18 psi, especially on a 417.
Old 12-14-2013, 11:45 AM   #10
Blue70SS
Blue70SS's Avatar
What's working for the spacer on a 417..... 1/2" or 1" thermal spacer? Benefits of going from 1/2" to 1" worth it? Hood touches, but works on the 1/2", 1" definitely would need a new hood.
LPE Brotherhood
Old 12-14-2013, 12:39 PM   #11
old motorhead
Drives: Maggie blown LS3 vette
If you're serious about big boost on a 417 cubed motor, do yourself a favor, and get a bigger blower or a couple of turbo's. Maggies are great blowers (I'm running two of them), but they are out of their league with big boost on big cubes.
old motorhead is offline   Reply With Quote
Old 12-14-2013, 12:41 PM   #12
Supercharged SS
Drives: 2010 Camaro
The spacer isn't cube specific. What happens at high boost is that the air packs up. Raising the blower allows more room for the air to keep if from packing.
No idea on the 1". Only RDS can answer that.
Old 12-14-2013, 12:42 PM   #13
Supercharged SS
Drives: 2010 Camaro
Amen.
Old 12-14-2013, 03:15 PM   #14
smokum
smokum's Avatar
Drives: 2010 2ssrs
I agree. But im on a limited budget. I got a steal on a fully built adm built lpe 417 maggie car. It has all the bells and whistles. I just want all i can get with what i have to work with. Im going 15 inch conversion slicks and skinnies 3.73 gears. Car has full pedders supercar suspension. Next build will be big. Lsx twin turbo.
