11-04-2011, 12:05 PM | #1 |
Drives: '10 Camaro LS3 2SS/RS, 1968 Nova Join Date: Aug 2010
Launched the car and broke driveshaft!!
Hey everyone!!! Well yesterday i took my car to the 1/8 mile drag strip and well here it is... I just did alot of suspension work to my car everything except lowering the car because i have a very steep driveway at home. So yesterday i took my car to the track and i lowered my tire pressure to 28psi (street tires) pulled up to the line and did a burnout! once i stagged i launched the car a little too hard... had wheel hop and boom!!! (not loud but i knew i broke something) after the boom my shifter went off to the side a bit and was shaking like crazy!!! It all happen at the launch!! ( launched, wheel hop,boom, shifter went off to the side a bit and was shaking) When i tryed to put it into gear i felt like the driveshaft had broke because as i did that it felt like something kept going in circles (like the driveshaft) and it went clack, clack, clack, clack so i turned off the car!!!:(. So I called a tow truck to tow me home. The guys at the track gave me some bolts and nuts that broke off my car. i went under the car and noticed that the bolts that connect the driveshaft to the tailshaft of the transmission were the ones that broke off! That was the only thing i could see wrong because my car is too low and still havent had the chance to look under. When i put the car in gear it still rolled. I will be replacing the bolts i broke off, cleaning off the tires and the chunks of burned rubber. Then i will take it to the dealer and let them know that my car has been having a vibration coming from the shifter area and when i checked it it was missing two bolts that connect the tail and driveshafts so i replaced them so i could be able to take the car to the dealer so it can get checked out buy them!!! what do u guys think might be wrong besides that?? why is my shifter off to the side a bit? why does my car still roll in gear? is that a good story to tell dealership!?? of course i wasnt gonna tell them i was racing it!!! Any ideas or suggestions??:(: popcorn:
Posted in other places in the forum to see if i get anymore comments on this!! thanks!!
Performance- Kooks Headers w/HF cats, ZL1 Corsa exhaust, VMax, CAI Inc. CAI, MGW shifter, RX CC Suspension - KW V3 Coilovers/ Full PFADT & BMR suspension Appearance - ZL1 Fascia/Sides/ Diffuser, AAC Afterburners, RK Sport 3pc Spoiler, SLP Black out Kit
11-04-2011, 12:30 PM | #2 |
Drives: SuperCharged 2SS/RS IOM MN6 Join Date: May 2009
the broken output shaft is a known issue and normally covered under warranty. With your modifications, I hope the dealer won't give u crap.
11-04-2011, 12:45 PM | #3 |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
IMO your gonna be on your own for the repair bill.
11-04-2011, 12:52 PM | #4 |
Drives: '09 Honda Civic LX Join Date: Jun 2009
^^ this... unless you have a b.a. dealership
Saving up for a camaro.
Dream camaro is either a 1/2SS with RS, black with red stripes, or red with white stripes. No rice with my order. |
11-04-2011, 01:31 PM | #5 |
Assuming it is a broken output shaft...The car will continue to roll in gear (you push or pull the car) but the car won't move via the driveline anymore because the transmission is no longer connected to the rear end. You can tell them any story you want aside from the truth, it is not what will make the dealer deny your warranty. It is some of the mods you have done to the car, most especially if you have a tune! If you have a tune, you are better off not taking it to the dealer because if you do, and they WILL know you have an after-market tune and the dealer will tag your VIN in the system with a Voided powertrain warranty. At that point, no matter which dealer you go to for warranty claim on any part of the driveline, they will pull up your VIN and see you have voided powertrain warranty. A tune is a sure way to void the powertrain warranty. Having said that, the output shaft breakage is a very well known and documented issue with the LS3 5th Gen Camaros and maybe your dealer will take that into account and fix it under warranty without investigating your car too much. If you choose to go the dealer route, walk in there armed with documentation about the problem with the output shaft and you'll have a better chance. Good luck.
11-04-2011, 01:38 PM | #6 | |
11-04-2011, 01:42 PM | #7 |
ZEUSS
Thats sucks! Whats your VIN #?
11-04-2011, 02:27 PM | #8 |
Drives: Car Join Date: Jun 2010
How long were you in it while wheel hopping? You always come off the gas the moment you notice wheel hop.....
11-04-2011, 06:21 PM | #9 | |
11-04-2011, 06:30 PM | #10 |
Blown Cool Breeze
Drives: 2011 Black on Black 2SS M6 Join Date: Jul 2010
No Tune.....
The dealer will fix it no problem. ALOT of cars have broke this way if they use "Launch Control"... I realize you did'nt,just saying!
Had a 2010 IBM 2SS M6 Enjoy life.Think of all the women on the Titanic who passed up dessert. |
11-06-2011, 01:42 PM | #11 | ||
Yeah my car was built in early June of 09 and falls as one of the 1st 25,00 built Quote:
Yup no tune for the same reason that u never know when u might need it! Hooe they fix it.
11-06-2011, 05:55 PM | #12 |
(ʘ‿ʘ)
Drives: The one with a roof rack Join Date: Dec 2009
Skip to 0:30... maybe it includes us too!
11-06-2011, 06:03 PM | #13 |
I used to be Dragoneye...
In terms of managing the loads on the drivetrain? Yeah!!
In fact, you're supposed to use launch control in such a fashion as to put full-faith in the car's computer...foot to the floor, dump the clutch - and let it do the rest... |
11-06-2011, 06:03 PM | #14 |
CamaroFans.com
Sounds like a ring gear in the rear end... this can cause a chain reaction and mess up drive shaft etc...
Similar Threads | ||||
popping in front end when I hit a bump | soonerfanru2 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 697 | 10-01-2017 09:29 AM |
Launched the car and driveshaft broke!! | BAWLZ SS | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 34 | 01-20-2012 10:11 AM |
Launched the car and driveshaft broke!!! | BAWLZ SS | Dragstrip and Launch Techniques Discussion | 14 | 11-07-2011 10:25 PM |
Transmission output shaft | hiller72 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 267 | 12-02-2009 08:39 PM |
Pedders Suspension Benchmark Track Testing and New Jersey Track Day | Info@PeddersUSA.com | USA - NY / NJ / PA | 35 | 10-26-2009 05:20 PM |
