Old 01-09-2014, 11:53 PM   #1
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
LS3 block vs LSA block
As I'm getting ready to build a short block, I had a thought. Would there be any benefit if I was to use a LSA block. Will it handle more strength? I'm researching it but I can't seem to find a lot of info on this topic. Any help would be appreciated.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 01-10-2014, 12:24 AM   #2
Detoxx03
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Detoxx03's Avatar
Drives: 2008 Corvette
LS3 is fine. Make sure you have a nice set of aftermarket heads.
D1SC Procharger 932/758 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
Old 01-10-2014, 12:53 AM   #3
TinyToasta
TinyToasta's Avatar
Drives: way too fast....
LSA has piston oil squirters and might be a tad stronger than a LS3, other than that I don't see much more of a benefit.
If you get a decent deal on a LSA Block go for it, that's what I did.
custom build forged LSA, 379ci, TVS2300@15psi, 696rwhp/688ft-lbs, built by DH Individual, Customkingz, tuned by Jannetty Racing
JRE rough idle cam, JRE ported lower intake manifold, OD cog drive, 6% OD crank pulley, ported ls3 heads, NW102mm TB, 1/2'' RDS spacer, IW 8-rib drive
Pfadt Cradle Bushings, Arms & Rods, Pedders Supercar w/FE4 conversion, ZL1 sways, HE Twin Carbon Street Slayer, ZL1 Rear End (3.73)
CTS-V Brake upgrade, Street: 22'' Vossen CV1, Strip: 18'' Forgestar F14 on MT Street Radials
TinyToasta is offline   Reply With Quote
Old 01-10-2014, 01:55 AM   #4
blake-b
blake-b's Avatar
Drives: 2009 ZR1
I am making over 1K to the wheels with the stock LS3 block with turbos. It may be on borrowed time but isn't showing any signs of it so far.
I believe you are using a Ysi and I made over 1k with it as well. A centri will typically be easier on parts than a turbo because of the way it builds boost with RPM.
I second toasta - if you can get an LSA block on the cheap go with it. Otherwise, you will be fine with an LS3 block.
Old 01-10-2014, 07:05 AM   #5
1 SIK SS
Drives: 2010 SS
You running stock bottom end?
1 SIK SS is offline   Reply With Quote
Old 01-10-2014, 07:33 AM   #6
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Stock crank and block. Forged rods and pistons.
Old 01-10-2014, 08:45 AM   #7
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
Centris are easier on the block per se, but they are harder on the crank. If I was going run a centri I'd spend the money on a forged crank.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 01-10-2014, 01:49 PM   #8
Piccione Performance
Piccione Performance's Avatar
Drives: 2010 2ss/rs & 2014 Stingray
The LSA block is reinforced for boost according to GM, after physically examining and building several of both the main difference is the oil squirters. That being said though they are an additional source of cooling for the pistons Which on a boosted application is definitely helpful.
As stated, if you can get an LSA block for the right price go for it, but properly built either one will be fine. We have done both between 800-1100 hp with no issues. The most important parts that are overlooked that cause failures on big H.P. Boost builds is the hardware used when assembling, don't skimp on your gaskets either.
Piccione Performance is offline   Reply With Quote
Old 01-10-2014, 10:21 PM   #9
Chris82xx
Chris82xx's Avatar
I threw the LSA out there because I was thinking of a different route. We know what applications that the LSA is used in, such as the CTS-V, ZL1, ZR1, but I was not sure what the differences were. If was able to handle boost better or what. TSP offers the LSA block for an extra $1K, but after much deliberation the end result is to go with a LSX block so I can get full use out of the 6-bolt heads that I already have.
811RWHP/719RWTQ
Old 01-11-2014, 09:18 AM   #10
2SS45th
2SS45th's Avatar
Great decision, the LSX block is one tough cookie.
Old 01-12-2014, 02:53 PM   #11
Chris82xx
Chris82xx's Avatar
I hope. It was a choice between doing a 408 and 427. I went with the 427, I'm just not too knowledgeable about how the LSX427 holds up to boost compared to a factory 7.0
811RWHP/719RWTQ
Old 01-12-2014, 03:58 PM   #12
Matt @ FSP
Matt @ FSP's Avatar
I wouldn't hesitate throwing 30lbs at a LSx block... Oh wait yes we're about to throw 35psi at one
The LS7 block is the weakpoint because of the core shift that we have seen without a girdle.
Matt @ FSP is offline   Reply With Quote
Old 01-12-2014, 04:59 PM   #13
Chris82xx
Chris82xx's Avatar
What about the cylinder walls being too thin in the LS7?
811RWHP/719RWTQ
Old 01-12-2014, 06:15 PM   #14
bct10985
Drives: 2010 2SS LS3, 2013 duramax
I think a 427 ls7 and a 427 lsx are totally different. Not just one is aluminum one is iron.
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
