07-17-2017, 06:01 PM | #1 |
Drives: 2010 1SS RS M6 Join Date: Jan 2015
Got to drive a Ferrari...then my car
So the wife got me a drive a Lamborghini or Ferrari gift certificate for Christmas at the track I used to race at..
Way more fun than I thought it would be... Then for an extra $30 they let me have the track for 45 minutes during their lunch break... My camaro I feel was faster in a straight line, but the Ferrari handled SO much better. It was my first time having my camaro on a track, gotta say it was awesome until I boiled the brakes! Major pucker factor! Once the brakes cooled they started working fine so I could drive it home. Now to schedule a fluid flush somewhere lol
Vararam intake, gmpp exhaust, borla stainless long tubes, cat less, jannetty tune, bmr lowering springs, heritage grill , smoked lenses
07-17-2017, 06:31 PM | #2 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Now you know exactly why when people ask what sort of preparation they should do before going to a track day / HPDE, one of the very first things they get told is to upgrade at least the brake fluid with one of the better DOT4 fluids. Followed by higher temperature capable pads. For fluids, that means ATE200, Motul RBF600, Castrol SRF in order of increasing price and periodic maintenance requirements. There are others, those are just the ones I know of offhand.
FWIW, if you've never done a brake job on this car, chances are that the fluid wouldn't have even met DOT3 specs . . . it'll have way more moisture content and a much lower boiling point. Norm
'08 GT coupe 5M (the occasional track toy)
'19 WRX 6M (the family sedan . . . seriously) |
07-17-2017, 06:50 PM | #3 |
Drives: 2014 Red Hot LS3 Join Date: Oct 2014
Lucky you to have a wife like that. Awesome gift.
07-17-2017, 07:30 PM | #4 |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
How much does it take to flush and refill a gen5 camaro SS with stock brembo brakes?
Which of these is the best? ATE200, Motul RBF600, Castrol SRF. And... What is a good set of rotors and pads for street, strip and track. I DD thing car right now and I have gone 130+mph. I drive sporty.
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
07-17-2017, 08:19 PM | #5 |
Not sure the amount you'd need, but in my experience racing Castrol SRF is the best. I used to boil all the different racing brake fluids and have to bleed brakes between races, once I switched to SRF I never boiled them again. SRF is speedy tho, it was around 115 a quart the last time I bought some. You do need to make a COMPLETE flush when switching, because it's silicon based and bad things happen when it mixes with standard fluids. I will switch to some kind of dot 4 maybe wilwood 600 or something. I don't track much so I won't put SRF in. But I couldn't recommend SRF more for racing
07-17-2017, 09:28 PM | #6 |
Ferrari F430, right?
You are lucky man with an amazing wife.
07-17-2017, 10:27 PM | #7 |
Yep,430 and yep, good wife
07-18-2017, 03:12 AM | #8 |
"BEASTM*DE"
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S... Dual 10" Kicker Comp S Subs 1200w... |
07-18-2017, 04:15 AM | #9 |
Drives: 2015 ZL1 Join Date: Jun 2015
Awesome time I bet!
2015 ZL1 M6
07-18-2017, 04:25 AM | #10 |
Drives: Miss Con Ception Join Date: Aug 2016
Did you have an instructor ride along?
2011 1SS/RS LS3 CGM
07-18-2017, 08:04 AM | #11 | |
Drives: 2020 ZL1 1LE Join Date: Sep 2012
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
07-18-2017, 08:26 AM | #12 |
Love me some Tacos
good information
07-18-2017, 08:49 AM | #13 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Get the motive bleeder. Soooo easy, you can bleed the brakes yourself in 1-2 hours.
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
07-18-2017, 10:58 AM | #14 |
That looks like WIR! I didn't know they had Ferrari thing there. You have a good wife!
