Old 10-05-2017, 09:49 PM   #1
DodgeDefector
Drives: Chevrolet Camaro 2014 V6
Wider Tires? (V6 Camaro)
Hey guys , second post after a while i dont know if i placed it in the right place. i just got back from doing service in Nam with Jim Carry. and i had a question. i have some small ass stock tires on my camaro v6s whats the biggest possible tires ( Wide ) i can get on them. ( Im Canadian btw )\
THANKS YALL
DodgeDefector is offline   Reply With Quote
Old 10-05-2017, 10:26 PM   #2
JOURDAN
Drives: 2010 Camaro SS 2SS
Unfortunately your very limited by rim width.
You will need to pick up a set of rims.
Decide if you want to go staggered or NOT.
10" all the way around... 11" ??
Most import thing is... do it correctly! Maintain as close to OEM offset. You want to keep to load centered.
dont play around with scrub radius.
Edit: Re read post, sounds like I don't like staggered, actually I do and how my car is setup.
JOURDAN is offline   Reply With Quote
Old 10-05-2017, 10:50 PM   #3
Spec
Drives: 2010 Camaro 1SS LS3
Calipers on a V6 are smaller than the brembo's on a v8. On a V6, you can easily wear an 20x11" rim with the a good offset and throw some 315-325's on those rear bad boys.
I've got 315's on my 10.5" Niche Milan's. 0.5" = 12.7mm. 325's on an 11" rim is probably the maximum I would go.
You could get a 10" for the front with a good/right offset and go 275-305'. Stay staggered... nothing wrong with that.
Squaring up on 20x11" rims with 325's on all corners might prove difficult I think... especially on those with the brembo's. Would look crazy though lol
Spec is offline   Reply With Quote
Old 10-06-2017, 11:36 AM   #4
mickss
mickss's Avatar
Drives: 2010 Camaro LS-M6 67 Chevelle Wgn
THANKS YALL
I think some of you are miss-reading the question, he wants to know what size tires not rims. It would be helpful to know what size rims do you have? I thought Canadians called them "Tyres"
"i just got back from doing service in Nam with Jim Carry.".....Please explain that one.
Free Trade is not Fair Trade
I am, we are INDIVISIBLE
Invictus, By William Ernest Henley
mickss is offline   Reply With Quote
Old 10-06-2017, 11:44 AM   #5
spyderbuddy
spyderbuddy's Avatar
Well I've got the Stock 20's on mine and i run a 275-40-20 on the front and a 295-35-20 on the back
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
Old 10-06-2017, 11:50 AM   #6
Ir0nM4n
Love me some Tacos
Ir0nM4n's Avatar
Drives: 14 1LE
This is my former V6 with Forgestars F14's 20X9.5 and 20X10.5, tires Michelin Pilot Super Sports, front will be 275/35 and rear will be 295/35.
http://www.camaro5.com/forums/showth...428&page=9#114
Ir0nM4n is offline   Reply With Quote
Old 10-06-2017, 12:49 PM   #7
gringo
gringo's Avatar
Drives: Camaro V6
The base V6 has the 18x7.5" alloy wheel. Stock tires are P245 in width. So, I'm guessing a P255 would be the max you could go on a 55 series tire. The rims might look more sunken in with a wider tire like that though.
If you upgrade and stay with the stock 18" diameter. The F14's come in a 18x9.5" wheel which weigh only 18 lbs or so. That's even lighter than the stock wheels which weigh 23 lbs per wheel.
gringo is offline   Reply With Quote
