Old 12-22-2012, 11:42 AM   #1
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
1 to 4 shift lock out
I was given the 1 4 shift screen on the display, but nothing stops me from shifting to 2nd Is it normal that you can shift to 2nd?
Skylane765 is offline   Reply With Quote
Old 12-22-2012, 11:57 AM   #2
knowitman
Camaro fan since birth
knowitman's Avatar
Drives: 2013 ZL1
When it says 1-4 Shift in the DIC and I try to shift, it gently slides the shifter over to 4th instead of second when I proceed to shift.
knowitman is offline   Reply With Quote
Old 12-22-2012, 11:59 AM   #3
Ghost1LE
Ghost1LE's Avatar
Drives: 2013 AGM 2SS/RS 1LE
What I've noticed is if you wait a few seconds it will let you shift to 2nd but for the first 5 seconds Or so it locks me out of 2nd
Ghost1LE is offline   Reply With Quote
Old 12-22-2012, 12:05 PM   #4
ckaram
ckaram's Avatar
Drives: 2011 2SS RS, 1968 ragtop
Sometimes it will flash the 1-4 shift on the DIC but I've accelerated out of it and it doesn't lock me out of the shift. Happens periodically. Timing has to be just right and I don't "try" to make it happen. Same thing is happening to you. No worries.
1968 Camaro Convertible LS1, T56
ckaram is offline   Reply With Quote
Old 12-22-2012, 12:39 PM   #5
pumpkinrancho
COMPULSIVE CAMARO OWNER
pumpkinrancho's Avatar
Drives: 18 ZLE,14 2ssrs,96,73 RS LT,69&67
If you have the throttle mashed when you drive the car its no problem ever. HA HA Have a Merry Christmas.
Old 12-22-2012, 02:16 PM   #6
LBV
LBV's Avatar
Drives: G8 GXP manual
If it consistently lets you shift to 2nd with the message on the display then you must have a skip-shift eliminator under the car.
2009 GXP, Manual with Sunroof
Zeta platform, LS3,TR6060 tranny ... ya, it's a 4-dr Camaro!
Borla cat-back, H&R springs, & Sprintbooster & I love it!
LBV is offline   Reply With Quote
Old 12-22-2012, 02:39 PM   #7
Skylane765
Skylane765's Avatar
No, the car is new, so maybe I do not try and shift fast enough. I do not notice the display and never had it keep me out of 2nd.
Old 12-22-2012, 02:45 PM   #8
JHall651
JHall651's Avatar
Drives: 2012 Camaro 2SS LS3 Ashen Grey
It's just a timing thing. There are several things that have to happen in order for the whole process to work. It will tell you in your manual. Something like between 1500-1700 rpm, trans oil over 150°, and no more than 15% throttle. So it will start to work but before you shift you break one of those prerequisites and it lets you shift into 2nd. I never see it any more after installing my SLP supercharger and SLP tune. Your cars fine. The lock out is so annoying anyways.
2012 2SS/RS, Magna TVS2300, RX Catch Can, Borla S-Type, Pfadt Stage 4 w/ ZL Spec Sway Bars, ADM Custom Boost/AFR Gauges, Hurst Short Throw, Forgestar F14 Matte Black 20x11 & 20x9.5 Deep Concave all 4, Nitto Invo 315/35 & 275/40, Heritage Grill, Sparks Black Grill SS & Trunk SS, P13W Fog Lights (cool white) w/ DRL Harness, Blacked Out Brake light bezels, Xpel Smoke Light Kit
JHall651 is offline   Reply With Quote
Old 12-22-2012, 02:55 PM   #9
Skylane765
Skylane765's Avatar
Thanks guys.
Old 12-22-2012, 03:04 PM   #10
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
If you wait to shift, and pass through the "zone"...it doesn't stop you from shifting.
Old 12-22-2012, 03:06 PM   #11
HDRDTD
I've noticed once or twice on the rare occasations that the 1-4 light comes on, that if I hesitate in neutral for a second or two, I can drop it right into 2nd.
Old 12-22-2012, 03:25 PM   #12
s/c ss
s/c ss's Avatar
Drives: 13 ZL1, 10 Silverado LTZ, Chopper
s/c ss is offline   Reply With Quote
Old 12-27-2012, 01:27 AM   #13
Aquabluetoo
Aquabluetoo's Avatar
Drives: 2013 Camaro ZL 1
Smile Skip shift eliminator fixes problem
A sure fire way to be safely using your Camaro is get a cheap skip shift eliminator. They work great, do not void warranty since it just plugs in and takes minutes to install. $20 and no problems again! Had one on my 2011 2SS and now it works great on my ZL 1.
Aquabluetoo is offline   Reply With Quote
Old 12-27-2012, 02:00 AM   #14
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Only happens when you're driving like a granny... give it some gas..
