Old 03-28-2014, 01:41 PM   #1
rayers0423
rayers0423's Avatar
Drives: Camaro SS 1LE
Flywheel: 500 CHp @5700 RPM 1LE mods
Just got American Racing Headers installed, new RotoFab CAI, SLP Loudmouth 2 exhaust and tuned and added a stiffening brace - running at 500HP - (dyno run data available if your curious) video available at:
Mods done at: http://www.tonyscorvetteshop.com/index.aspx
Next step is performance camshaft - Suggestions?
rayers0423 is offline   Reply With Quote
Old 03-28-2014, 01:48 PM   #2
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
500 RWHP, on a dyno?
I challenge!
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 03-28-2014, 01:57 PM   #3
rayers0423
rayers0423's Avatar
500HP Flywheel
Pic of the dyno read - this was actually a conservative run.
Old 03-28-2014, 02:01 PM   #4
Spartan01
Spartan01's Avatar
Ok, cool. Wasn't trying to sound agro.
I didnt know that a dyno could show you the crank HP as well, thats pretty cool.
Is it a Mustang or DynoJet
Old 03-28-2014, 02:04 PM   #5
Spartan01
Spartan01's Avatar
Op- I like that brace, which one is it?
Old 03-28-2014, 02:27 PM   #6
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Nice results for CAI/headers/tuned!! You could port your throttle body, manifold intake and and install U/D pulley. Just some suggestions.
Dont forget to change your stock oil pump if your doing the cam!! Rockers trunion upgrade too are a must too and cheap insurance.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 03-28-2014, 03:24 PM   #7
rayers0423
rayers0423's Avatar
Super Flow Dyno
Old 03-28-2014, 03:25 PM   #8
rayers0423
rayers0423's Avatar
Not sure the exact model # on the brace - it ran about $450 - well worth it!!
Old 03-28-2014, 03:57 PM   #9
B-_-RAD
Banned
Drives: ...
Night fury!
B-_-RAD is offline   Reply With Quote
Old 03-28-2014, 05:07 PM   #10
toehead93
Drives: 2014 2SS/1LE
The flywheel number is an estimate base on the rwho number which vary so much. Dont put any stock in that number being accurate. If you took your engine out with those mods and did a real engine dyno it will be far less than 500. For reference the LS7 males 505flywheel hp, not a mild botlon LS3. But nice mods non the less!
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 03-28-2014, 05:12 PM   #11
Pima
Pima's Avatar
Drives: 2013 2ss/rs/1le vr.
rain maker
someone always has to rain on peoples party. let the man be happy about his numbers
Pima is offline   Reply With Quote
Old 03-28-2014, 05:54 PM   #12
Fraxum
Fraxum's Avatar
Drives: a M6 LT1 ordered From Becky!!!
OP does the 1LE need that brace?
Old 03-28-2014, 07:52 PM   #13
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Im 99% sure there is more than one LS3 engine dyno at 500hp with boltons. Dont forget engine dyno do not have drivetrain/parasitic loss and dyno very high.for exemple, a stock LS1 is known to be around 400 hp on an engine dyno...
Im sure his numbers are accurate.
13' 1LE
Old 03-28-2014, 10:00 PM   #14
L99CAMA2011
L99CAMA2011's Avatar
http://www.phastekperformance.com/20...moly-brace.htm
