09-26-2013, 01:19 AM | #1 |
Drives: 2016 2SS coupe 2015 3LT Stingray Join Date: Aug 2012
n2o kit
Hi guys will be doing a nitrous wet fogger kit soon and was wondering where you guys mount your solenoids. If you could post some pics that would be awsome. Also can someone that knows tell me what is the rev limit on an L99 so I can set up my window switch correctly tks
Ported intake manifold and throttle body kooks 2" headers no cats
09-26-2013, 09:41 PM | #2 |
come on guys no pics
09-26-2013, 09:48 PM | #3 |
Drives: 2016 SS Join Date: Jan 2013
Only two companies on the market in my opinion nitrous express my choice and nitrous outlet. Nx has some of the best people to work with and good Solenoids and kits. Same with nitrous outlet.
09-27-2013, 07:44 AM | #4 |
are you using special brackets of the universal ones that come with the kits
09-27-2013, 09:04 AM | #5 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
Best I can do is post my thread. Nitrous Outlet total package.
http://www.camaro5.com/forums/showthread.php?t=217103
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
09-27-2013, 09:54 AM | #6 | |
Drives: Fast! Join Date: Mar 2013
09-27-2013, 11:05 AM | #7 |
I'm just using the universal strap bent in a 90 and bolted with the intake bolt
09-27-2013, 01:12 PM | #8 | |
Super install congrats snd thanks
10-01-2013, 05:50 PM | #9 |
GrINned & JUICEd
Feed line I believe is 16 ft. An extra 2 feet would have made it easier, if you mount the bottle on the passenger side. I have a filter too, so that adds about a foot as well. Line is run along the driver's side inside sill plate/rocker panel area. Through the existing firewall hole above the clutch pedal or dead pedal. Run your line through the hole first before running all the wires through it to allow room for it, swivel fitting. Wrap your wiring with some tape to avoid chaffing at the hole area before your final pull. Can put some duct tape around the feed line so it doesn't vibrate against the body. Also used duct tape to secure to body when wire ties couldn' be used. Bottle is attached to a false plywood floor in the trunk. Home made toggle bolts secure the plywood to the trunk floor. Removed some trunk plugs and placed the toggle bolts in the holes, along with the blow down tube. So no holes or screw holes added to the car.
10-01-2013, 10:00 PM | #10 |
Thanks man I removed some panels to figure out how I was going to run it Im thinking of running it along the passenger side but now you got me thinking if I have enough line I bought the camaro bottle bracket that goes in the back. one more question which is the rpm signal wire to tap for the window switch I been told its the second one from yhe left on the passenger side connector but would like to get some verification once again thanks for your help
10-02-2013, 10:37 AM | #11 |
GrINned & JUICEd
Passenger side. Separated the connector and placed the stripped tach wire in the female connector. Did not cut into and splice. Tach signal wire is small enough for the connector to go back together. Blue wire with white strip. 2nd one from firewall.
Np, just ask/pm.
