02-04-2015, 11:43 PM | #1 |
Drives: Camaro 1LE Join Date: Dec 2014
ZL1 295 fronts but not the 1LE??
Hello,
I am doing research on the MICHELIN PSS tires and keep reading ZL1 guys put 295s in the front...but they would rub on a 1LE (front) What gives? Any info would be appreciated. Thanks |
02-05-2015, 12:41 AM | #2 |
Banned
Drives: 2011 Boxster Spyder (best car ever) Join Date: Aug 2014
I doubt they would as there are members running 315's all around, I believe. I am sure the pros will chime in shortly...3....2......1
02-06-2015, 02:49 AM | #3 |
Drives: 2013 2SS 1LE NPP GBE Join Date: Sep 2012
I have 295/35/20's Trofeo R's on the fronts. No rubbing. 2013 1LE.
02-06-2015, 04:20 AM | #4 |
Drives: 2010 2SS Join Date: Sep 2012
Youll be ok but id probly stick to 285s depending on your setup. You tock 1le suspension?
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
02-06-2015, 05:17 AM | #5 |
Have a 305/30/19 Toyo R8888 all around with 1.25" drop (BMR springs ) no rubbing issues. Forgestars CF5 19x10 fronts & 19x11 rears
02-06-2015, 05:19 AM | #6 |
Sorry guys , it's Toyo R888
02-06-2015, 06:44 AM | #7 |
I have a 1le that is stock height. Im interested in PSS tires since i know they run wider. Are the trofeos as wide as the PSS?
02-06-2015, 04:19 PM | #8 |
I looked into the PSS 295 but they are too much money for 10mm. Not worth it for me IMO. The 285 are already oversized 285 (similar in size to Nitto 315s).
http://www.camaro5.com/forums/showthread.php?t=344754 Summit White 2014 2SS 1LE Recaros, NPP exhaust, Nav 2010 2SS A6 - sold. |
02-06-2015, 04:55 PM | #9 |
Drives: 14 white Camaro 1LE 2SS/RS Join Date: Oct 2013
would i have any issue running a nitto motivo 315 rear and a 275 front? im trying to save a little money and i dont track my 1le, probably wont for another 2 years so will 275 front with 315 nitto motivo be okay with no issues?
02-06-2015, 04:59 PM | #10 |
Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
I want to run a 295 square setup on some 10.5" Forgelines...
Currently I run 285/295 on the stock wheels with some PSS tires. I like it. Sent from my SM-G900V using Tapatalk
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
02-06-2015, 05:20 PM | #11 |
is a 275 too narrow for the front 1le wheels tho guys?
02-06-2015, 08:07 PM | #12 |
No hijack my friends. My question s still not answered.
02-06-2015, 08:19 PM | #13 |
I don't see any reason unless the ZL1 strut is a considerable amount smaller diameter that b it wouldn't work...
My main worry is the tire would bulge instead of stretch. It would affect the sidewall flex. I have the 285/295 combo and the sidewall bulge is virtually identical. Like I said 10.5" with a 295 square set up is the ticket. I've talked to Forgeline and it can happen but my wallet can't handle it right now. Sent from my SM-G900V using Tapatalk
02-09-2015, 03:15 PM | #14 | |
Drives: '14 Blk SS 2SS/RS 1LE - SOLD :-( Join Date: Apr 2013
I imagine with the right speed and pothole/speed bump, a good rubbin' will occur! LOL |
