Old 06-04-2017, 04:33 PM   #1
sspade
sspade's Avatar
Drives: 2015 Camaro LFX A6
Radar Detector - Hard Wire
Hello. Can someone post clear instructions on the easiest way to hardwire radar detector safely so that it powers down correctly and does not put a draw on the battery.
Thanks.
Cold Air Inductions CAI : Apex Air Scoop / WW Relocate Kit : JacFab Intake Manifold Spacer : Overkill 80mm Throttle Body : Overkill Tuned : MagnaFlow Cat-Back Exhaust : Elite Engineering Catch Can : ZL1 Strut Tower Brace : Custom Tunnel Brace : JPSS Caster Locks : JPSS 32mm Rear Sway Bar : JPSS Billet Radius Arm Bushings : Pegasus Solid Sub Frame Bushings : 1LE Brembo Conversion : B&M 70273 Trans Cooler
sspade is offline   Reply With Quote
Old 06-04-2017, 04:37 PM   #2
sspade
sspade's Avatar
Or better yet... Anyone have a cordless model?
Any opinions or reccomendations are greatly appreciated!
Old 06-04-2017, 05:49 PM   #3
mma
Drives: 1LE
http://www.camaro5.com/forums/showthread.php?t=34844
tap into F17
fuse box is on the dash on driver door side
mma is offline   Reply With Quote
Old 06-19-2017, 03:56 PM   #4
CreeperRS
CreeperRS's Avatar
Drives: 20’ Chevrolet Camaro 2SS 1LE
http://www.camaro5.com/forums/showth...Radar+detector
CreeperRS is offline   Reply With Quote
Old 06-20-2017, 09:43 AM   #5
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
For escort/beltronics: http://www.ebay.com/itm/ESCORT-BELTR...pXNR1y&vxp=mtr
For valentine: http://www.ebay.com/itm/V1-VALENTINE...9WmxTs&vxp=mtr
Tap into rear view mirror harness
Current: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower w/ Idler Relocation, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, Tuned by Pat G
Past: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
Old 06-20-2017, 09:50 AM   #6
sspade
sspade's Avatar
Thanks everyone. This will help immensely.
Now I need to get my hands on a legit detector. I have a 10 year old Cobra that's basically a joke.
Anyone have one for sale?
Anyone have recommendations?
Not looking to spend $500.
Old 06-23-2017, 12:46 AM   #7
tlamb2
WHPLSH
tlamb2's Avatar
Drives: 2010 SS Maggie,ARH,Meth,AFE Coilove
https://www.radarbusters.com/Uniden-.../uniden-r3.htm these are the newest craze I also have a 10 yr old escort and it is not worth a shit I am looking at this one
tlamb2 is offline   Reply With Quote
Old 06-23-2017, 06:50 AM   #8
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
Highly recommend the passport Max's, but the problem with detectors is they're picking up blind spot monitoring systems on modern cars, and only so many (more expensive) models are introducing filtering technology. Even my max 360 still gives falses (although far less than my passport Max did)
Sent from my Pixel XL using Tapatalk
Old 06-23-2017, 07:57 AM   #9
sspade
sspade's Avatar
What do you guys think about this?
Good buy? Can I get something better for $200?
Any potential issues to watch out for?
PLEASE SHARE THOUGHTS!
Old 06-23-2017, 09:04 AM   #10
sspade
sspade's Avatar
Im thinking hard about this...
Just talked to the guy and he said its a few years old but he sent it in to Valentine in January and they "upgraded everything to the latest versions"
Does that make sense? I am not aware if Valentine offers this type of service or not.
Anyone know if this is possible?
Old 06-23-2017, 10:59 AM   #11
mma
Drives: 1LE
you live in VA.. you probably want something that's not detectable. V1 is detectable.. state trooper will pull you over for it and potentially take it. I would look for a redline or bell STI
Old 06-23-2017, 11:09 AM   #12
sspade
sspade's Avatar
Interesting. Thanks. Not really aware of VA laws. Only been here since January and Im actually moving out of state again in late July.
Really just wondering if people think this is a good value.
V1 for $200. Do it or not?
Old 07-01-2017, 07:03 PM   #13
whidobie
whidobie's Avatar
Drives: 2011 Camaro Convertible 2SS RS
Valentine 1 does offer an upgrade that does help in filtering false reads
whidobie is offline   Reply With Quote
Old 07-01-2017, 07:41 PM   #14
KenKat
KenKat's Avatar
Drives: 2014 2LT RS Summit White
Seems like a decent value but radar detectors are illegal to operate in Virginia.
KenKat is offline   Reply With Quote
