09-14-2017, 06:49 PM | #1 |
Android based Head Unit on a Boston Acoustic equipped Camaro?
I am very interested in purchasing this head unit:
https://www.amazon.com/32GB-OCTA-Cor...T7VC87G5GBYXTX Question is, will this work in my Camaro that has the factory Boston Acoustic amp/system installed? I currently Have a Kenwood Excelon DNN990HD installed, and also the first version of the Scosche Touchscreen Climate Control kit. I have the steering wheel & Onstar module/adapter as well. I am running factory speakers and BA amp. I do not use XM/Sirius, so that is of no concern, Reason I ask is that my Kenwood has died...thankfully. That was possibly the most unstable/buggy and SLOW head unit I have ever used. It finally kicked the bucket and I am thankful for that. If this is possible, what if any extra parts would I need? It looks like whoever installed the Kenwood did NOT use any type of harness. It all was done with butt/crimp connectors. Sorry if I left anything critical out. I used to be pretty good at this type of stuff, but that is before modern automotive electronics and CANBUS hit the scene. Thanks in advance!
09-15-2017, 12:51 AM | #2 |
Aural Assault Vehicle
Drives: 2010 IBM 2SS/RS, 2015 Sierra Denali Join Date: Jun 2011
It's a double din head unit so it should work with the Scosche or Metra kits without issue. It should have the exact same connections (for audio output, etc) on it as the Kenwood did.
That said, it is an android based head unit. Be very sure you're ready for the long boot times, wifi updates, etc. I only mention the long boot times because that is a complaint you had with the Kenwood. It's also really cheap.....so that would kinda scare me right off the bat. Cut out the crimp connectors and connect the new radio to the Scosche harness wires using any method you see fit (crimp connectors, solder, etc) and roll on. The Scosche kit communicates with the Canbus so you wouldn't be messing with that. Hope that helps.
My amplifier pop/click/thump solution thread
Power Mods * K&N Typhoon CAI, Flowmaster American Thunder cat-back exhaust, Hurst Short Throw Shifter Exterior Mods * Black Phantom Grille * 22" T.I.S. 537MS wheels w/ Nitto INVO rubber * OEM body kit Suspension Mods * BC Racing Coilovers * Lakewood Strut Tower Brace Audio Mods * Stinger SPP 2250 Battery * Mosconi 6to8v8 w/ RCD * Pioneer AVH-X7500BT * Scosche Dash Kit * 2 - Mosconi AS200.4 * 2 - JL Audio 13W6v2 * Focal 165KRX2 Power (active) * Mosconi Gladen One 240.2 * Rockford Fosgate Power T1692 |
09-15-2017, 03:09 AM | #3 | |
That puts me at ease a bit. Almost all of these Android units are super cheap (all Chinese brands). That one is actually on the more expensive side for this type. Thank you!
09-15-2017, 11:34 AM | #4 |
Drives: 2011 Camaro 2SS/RS Join Date: Oct 2013
I have a rebranded version of that same Android unit in my Suburban. I'm pretty happy with it. Even while the radio is booting up, the radio and back up camera function. I'll never go back to the big name brands. These Android units are far more versatile.
09-20-2017, 10:25 PM | #5 |
Well, the install is all done...finally!
What a PITA that was. But the payoff was so worth it. It sounds amazing through the BA amp/speakers. The features of these head units are freakin' incredible. One of my favorite things is how I now have DashCommand and Torque OBDII apps right in my dash via bluetooth. Having an 8 core tablet in what now looks like a factory install is fantastic. It is working flawlessly with my Scosche climate control. Steering wheel controls, Onstar, side, front, and rear cameras are working great. Boot time is super quick as well. Now I need to find a good launcher for it. But I am also considering flashing a new ROM as the Android XDA has tons of support and mods for these type of units. Best $300 I have spent in a while. Thanks for the info guys.
09-20-2017, 10:43 PM | #6 |
Pics, pics, pics......
09-20-2017, 10:55 PM | #7 |
Lol, I knew that was coming. I will get some uploaded in the morning.
09-21-2017, 05:42 AM | #8 |
Drives: 2013 SS Camaro Join Date: May 2016
Nice...This one is supposed to have fast boot....thinking about making a purchase too:
https://www.amazon.com/dp/B074M69Q4N..._jC5WzbDV022Z6 Sent from my SM-N920P using Tapatalk |
09-21-2017, 10:06 PM | #9 | |
Drives: 2009 ZR1 Join Date: May 2010
09-22-2017, 04:12 PM | #10 |
Switching over the wiring. It wasn't at all hard. Just tedious. The person who installed the Kenwood did a piss-poor job of keeping the wiring somewhat clean. It looked like a birds nest.
I cleaned it up a lot and used zip ties to keep like wires bundled together and keep the power and ACC isolated from the speaker wires. *To anyone considering this, keep in mind you MAY have to trim your faceplate a little bit. These are not your standard double-din. They are slightly oversized. If I had to do it again, I would use a file. The dremel is a bit too overpowering for this. Not as precise as I would have liked. My Scosche now has a little tiny gap on the right side. Some people would not care about this, but I am super anal and will most certainly try and buy a new face plate for the Scosche and make it more precise. Before you order, check and double check your measurements.
09-22-2017, 04:21 PM | #11 |
Thanks for the response.
I currently have an Alpine INA W910 in the first style Scosche kit. I am thinking of replacing it with an Android unit. |
