Old 01-23-2018, 01:19 PM   #1
nbostaph
nbostaph's Avatar
Drives: Yellow 2014 2SS Convertible
Does the BA head unit put out a flat signal if intercepted before the BA amp?
I'm looking to replace my speakers, add a sub, and replace the BA amp, but keep the factory head unit. Will I get a flat response curve without bass attenuation, timing correction, and all that other crap if I use the RCA wiring harness from ST. Or will I need to use a JL Fix 86 to clean up the signal?
In other words, is bass attenuation and timing correction done at the BA head unit or in the BA amp? My gut feeling is that it's in the head unit, but I'm hoping I'm wrong.
My car is a 2014 Camaro SS convertible with nav.
nbostaph is offline   Reply With Quote
Old 01-25-2018, 11:43 AM   #2
darkrider01
Aural Assault Vehicle
darkrider01's Avatar
Drives: 2010 IBM 2SS/RS, 2015 Sierra Denali
The EQ is applied at the amp in the BA system. The head unit is clean.
My amplifier pop/click/thump solution thread
Power Mods * K&N Typhoon CAI, Flowmaster American Thunder cat-back exhaust, Hurst Short Throw Shifter Exterior Mods * Black Phantom Grille * 22" T.I.S. 537MS wheels w/ Nitto INVO rubber * OEM body kit Suspension Mods * BC Racing Coilovers * Lakewood Strut Tower Brace Audio Mods * Stinger SPP 2250 Battery * Mosconi 6to8v8 w/ RCD * Pioneer AVH-X7500BT * Scosche Dash Kit * 2 - Mosconi AS200.4 * 2 - JL Audio 13W6v2 * Focal 165KRX2 Power (active) * Mosconi Gladen One 240.2 * Rockford Fosgate Power T1692
darkrider01 is offline   Reply With Quote
Old 01-26-2018, 07:58 AM   #3
nbostaph
nbostaph's Avatar
Thank you; that is exactly what I was hoping to hear. Would you be able to tell me how you know this? Is it documented somewhere or did you hook up a meter and measure the response curve yourself?
Old 01-27-2018, 02:58 PM   #4
Assassyn
Assassyn's Avatar
Drives: 2014 Convertable Camero
Think your talking about doing what i did using that FARK harness? I added a Amp to the RCA Outputs on it for my Sub and Rear Speakers. They work fine.
Assassyn is offline   Reply With Quote
Old 02-15-2018, 07:17 PM   #5
oslouie
oslouie's Avatar
Drives: 2018 2SS M6 Redline
He did tons of testing. Very knowledgeable guy when it comes to the BA system.
oslouie is offline   Reply With Quote
