09-06-2012, 04:14 PM | #1 |
Drives: 2011 GT500 Join Date: Apr 2012
Opinions on these wheels for Drag Racing
Interested in slapping some Drag Radials on these. Opinions?
http://oewheelsllc.com/Wheels_3/Whee...Wheel-gunmetal |
09-06-2012, 04:59 PM | #2 |
Drives: 11 Seconds or Faster Join Date: May 2012
The offsets are too high... no chance on fitting. You can run up to like a 50mm and have to grind down the LCA. That 56 probably wouldn't fit at all.
09-06-2012, 05:28 PM | #3 | |
Quit being a pu$$y
You would have to run a spacer.
09-06-2012, 07:50 PM | #4 |
I can't say for sure either way. I have my doubts it would fit. But I do know that "mlee" was selling some Corvette replica wheels a while back that were 18x10.5 (+53 offset), and they fit without any spacers or modifications. Which make me wonder....is 3mm really going to make the difference between fit and no fit??? I wish I could give you a definitive answer. Unfortunately, the wheels he was selling were very limited, and I do believe he has tried to find some more....with no luck.
Here is his post....http://www.camaro5.com/forums/showthread.php?t=174122 Last edited by blazzin1; 09-06-2012 at 10:07 PM. |
09-07-2012, 09:39 AM | #5 | |
Yeah, I saw that post and it got me looking. I'm a little confused as to the offset I should be looking for in an 18x10.5 inch wheel. Last edited by YelloSS; 09-07-2012 at 10:05 AM. |
09-07-2012, 10:23 AM | #6 |
Drives: 2010 aqua blue SS/RS M6 Join Date: Feb 2010
Man what a deal that would be, if you had to run a small spacer to make it work it, would be worth it. Your going straight in a drag race and not taking hard corners, I ran cheap spacers on my 11 sec car for years without issues. No worries if you had to use one!
10.91 at 122 H/C stock block N/A
09-07-2012, 06:01 PM | #7 | |
Quit being a pu$$y
The 56mm and 53mm offset wheels are different castings. They are not the same with just a thicker pad. The back of the spokes are different and that is why they don't fit.
