Old 02-03-2014, 10:10 AM   #1
kf12538
Drives: 2011 1SS Convertible
Reverse wire to automatically turn camera on?
I have an aftermarket Pioneer DVD receiver and have installed an audiovox backup camera on the 2011 SS convertible. The camera works when you manually pull it up on the deck, however I would like to get it to automatically bring the camera up when I put it in reverse. Pioneer says I need to wire one of the receiver wires to the reverse lead that switches polarity when placed in reverse gear. I have wired the violet/white wire from the Pioneer to the reverse wire (light green on taillight harness???) but it must not switch the polarity when you put it in reverse, because it brings up my camera all the time. This does not matter what I polarity I set the Pioneer setting to. Has anyone already figured this out on an aftermarket receiver?
kf12538 is offline   Reply With Quote
Old 02-03-2014, 12:12 PM   #2
ZeuSS2011
ZeuSS2011's Avatar
Drives: Black 2011 2SS/RS / Black 2013 ZL1
http://www.camaro5.com/forums/showthread.php?t=241806
Post #3 from the above thread shows you which wires to tap into for the camera to turn on when you put it in reverse. Member on this forum shared the DIY for the back up camera install. Worked great for me.
ZeuSS2011 is offline   Reply With Quote
Old 02-18-2014, 04:19 PM   #3
Camaro84
Camaro84's Avatar
Drives: 2010 Camaro SS
Did it work I'm getting ready to install mine now
Camaro84 is offline   Reply With Quote
