Old 08-04-2012, 11:42 PM   #1
darkrider01
Aural Assault Vehicle
darkrider01's Avatar
Drives: 2010 IBM 2SS/RS, 2015 Sierra Denali
Aftermarket back up camera - form and function
I looked around at a lot of backup cameras prior to finding the one I went with. The biggest issue I saw with the cameras that most people installed was that it was either huge or just to obvious. I wanted a camera that had a stock appearance and was as small as possible. I looked around for a while and came across the Crimestopper SV-6818.EM. I picked it up from SonicElectronix for around $40 shipped. Here are some of the pictures I have taken to help others that might want to go with this camera.
Bye Bye backup anxiety!
Kit includes properly sized hole saw - not bad for $40.
Camera is in place.
My amplifier pop/click/thump solution thread
Power Mods * K&N Typhoon CAI, Flowmaster American Thunder cat-back exhaust, Hurst Short Throw Shifter Exterior Mods * Black Phantom Grille * 22" T.I.S. 537MS wheels w/ Nitto INVO rubber * OEM body kit Suspension Mods * BC Racing Coilovers * Lakewood Strut Tower Brace Audio Mods * Stinger SPP 2250 Battery * Mosconi 6to8v8 w/ RCD * Pioneer AVH-X7500BT * Scosche Dash Kit * 2 - Mosconi AS200.4 * 2 - JL Audio 13W6v2 * Focal 165KRX2 Power (active) * Mosconi Gladen One 240.2 * Rockford Fosgate Power T1692
darkrider01 is offline   Reply With Quote
Old 08-04-2012, 11:46 PM   #2
darkrider01
I had some questions about how well it functions - well, here ya go.
The yellow marker (a level) is 12" from my bumper.
The hammer is 24" from my bumper.
The pipe is 36" from my bumper.
This works out pretty good for me as I don't like getting any closer than 12" to anything when I'm backing up.
Old 08-04-2012, 11:48 PM   #3
darkrider01
I wired the camera power and ground to my rear drivers side tail lamp harness.
The ground is connected to the inboard tail lamp ground wire (black).
The power is connected to main harness. The +12V wire for the back up lamps is the teal wire. I say it's light blue, but my wife says teal....
A couple of views from a little farther out to see locations.
Old 08-05-2012, 11:11 PM   #4
darkrider01
Updated with more pictures. Enjoy.
Old 08-06-2012, 08:18 PM   #5
Birm
Birm's Avatar
Drives: Florida Speed & Power
Thanks man! Helps a lot!
Birm is offline   Reply With Quote
Old 08-08-2012, 10:35 PM   #6
WiSSDiver
WiSSDiver's Avatar
Drives: 1968 Coupe, 2010 2SS, 2011 2SS/RS
Great website. They have some other goodies that I can use and the prices are very good!
WiSSDiver is offline   Reply With Quote
Old 08-26-2012, 06:23 PM   #7
Caddyroger
Caddyroger's Avatar
Drives: 2011 RJT Camaro LT2 RS auto shift
Looks like a good camera. When I saw the spec for it it reads the tilt is not adjustable. By your pictures The angle is pointing to far down for me. Is that mounted to your car?
Caddy
Caddyroger is offline   Reply With Quote
Old 07-14-2015, 01:31 AM   #8
aevans17
Drives: 2015 1LS Black
Thanks for this post. I installed a similar setup in my 1LS. The only difference is that I used a camera/screen/wireless transmitter combo from Amazon (http://www.amazon.com/Buyee-Inch-Mon...+backup+camera). On the 2015 the reverse light colors are gray (12V+) and black (-).
aevans17 is offline   Reply With Quote
Old 12-10-2015, 03:27 PM   #9
Yippee38
Yippee38's Avatar
Drives: '11 SGM 1LT/RS, '02 SOM Firehawk
I have the same camera, and I thought that too when I got it. I like it though. I can just barely see the bottom of my rear bumper (the part that sticks out under the license plate) in the camera. It helps me see exactly how far I can back up without hitting something.
My rear bumper had a cutout where the camera needed to be mounted. I fabricated a mount out of a piece of aluminum. It was a PITA, but it worked.
Yippee38
Yippee38 is offline   Reply With Quote
Old 04-26-2016, 08:38 PM   #10
Inuyashas_Brother
Inuyashas_Brother's Avatar
Drives: '10 Camaro LS - M6
Thanks, and I agree with your wife. It is teal or green at most.
Inuyashas_Brother is offline   Reply With Quote
Old 05-03-2016, 09:11 AM   #11
rydahog
rydahog's Avatar
Drives: camaro ss
@darkrider01, i just installed a pioneer head unit on my ss/rs ,,i have the oem backup camera, how do i get that camera view onto my pioneer headunit screen? as it is now,,,when i put it in reverse the pict comes on rearview mirror as it should,,but i want to see it on headunit, even if it means losing the mirror no problem...any suggestions how to do this.? thanks
rydahog is offline   Reply With Quote
Old 05-14-2016, 01:11 PM   #12
Inuyashas_Brother
By the way, how have the rear light connections held? I have heard that those quick splice connectors are not reliable, and in fact can damage wires long term.
Thanks!
Old 05-19-2016, 10:38 AM   #13
LiveWire195
LiveWire195's Avatar
Drives: 2017 Camaro 1SS
How is the quality when using it at night?
LiveWire195 is offline   Reply With Quote
Old 04-26-2019, 09:58 AM   #14
wasthatacop?
wasthatacop?'s Avatar
Drives: 2010 2SS
What color was the ground wire? My wiring does not have any black wires. I have a light gray, and a wire with a stripe. I tried the wire with the stripe as a ground, no such luck.
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts,
1.4" BMR lowering springs
ZL1 factory rims
misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete
wasthatacop? is offline   Reply With Quote
