12-04-2010, 10:24 AM | #1 |
pinkcamaro.com for sale
Damn blind spot!
I can't believe I'm googling a proper way to arrange side mirrors to get rid of a blind spot. I almost took out my car and a car next to me last night - totally my fault... annnnnnd we were the only ones on the road. I felt so badly.
I'd like to find my road driver trainer person guy and yell at him for teaching people improper ways of using their mirrors. He even had us NOT use the driver's side mirror. Nice huh? Baaaaaaaaaaaaaaaaaaaaaaaaaaah
12-04-2010, 10:27 AM | #2 |
Drives: 2011 camaro v8 6 speed manual Join Date: Dec 2010
The view is terrible. Can't see much through windshield and rear window is insane.
12-04-2010, 10:27 AM | #3 |
Drives: 2010 Black on Black Join Date: Oct 2010
Took me about a week to get used to this, but it does work.
http://www.linquist.net/motorsports/tech/mirrors/ At first it was odd, but once you retrain yourself to use the mirrors this way it's very good. If a car is in my blindspot halfway for instance, the front half of their car is in my side mirror, and the back half is in the rear view mirror. The rear view mirror is too big as well blocking some view. I bought a rear view camera, and plan to put in a thinner mirror from another GM product. |
12-04-2010, 10:36 AM | #4 |
Car Guy
Drives: '08 Mustang GT, '01 Isuzu VehiCROSS Join Date: Jun 2009
I honestly believe that full generations of drivers were taught to adjust our mirrors improperly.
CORRECT: Lean your body toward the center of the car - adjust the passenger mirror so you barely see the back edge of your car. Lean your body and touch your head on the driver's window - adjust the driver's mirror so you barely see the back edge of your car. In VERY LIGHT traffic CAREFULLY test the setup so traffic appears in the side mirror before it disappears from the rearview / so that traffic appears in the window before it disappears from side mirror. Repeat for other side. Tip: Once correct, you can also lean slightly from side to side as you check the side mirrors to see even more area. |
12-04-2010, 10:50 AM | #5 |
My 99 T/A has better vision but i've gotten use to the 2010 Camaro it took a little while
Horse Power is where its at !!!!! |
12-04-2010, 12:09 PM | #6 | |
PWA Relapse
- X
2017 1LT/RS A8 Hyper Blue Metallic |
12-04-2010, 12:14 PM | #7 |
Booooosted.
I have used my side mirrors for as long as I can remember. I even use them when turning while backing. And you really don't need a drivers side mirror if you're driving the speed limit and you don't have a stiff neck, unless you are backing. So my driver side mirror is set to see straight back and not for lane changing. If you are driving over 100 mph, and others around you are also, then set the driver mirror accordingly. But looking over your shoulder is really easy. |
12-04-2010, 12:26 PM | #8 |
So It'll Go Down Easy
Drives: Camaro SS/RS Join Date: Aug 2010
Don't blame the car.
12-04-2010, 12:27 PM | #9 |
Go Blue!!!!!
Drives: 2012 Cruze LT Join Date: Mar 2009
Once you adapt, you should have no problem.
12-04-2010, 12:28 PM | #10 | |
Thread Killer
True blind spots are places a mirror can't see, like the front windshield pillars on my 3rd gen, you can hide a semi behind that 2in strip. |
12-04-2010, 12:34 PM | #11 |
B.O.D. 02/16/10
Drives: 2010 SGM Sp. Edition 2017 RS Conver Join Date: Jun 2010
I always thought the best way to set your mirrors up was to have them set so when an object leaves your rearveiw, it shows up in your side veiw and vice versa. Once it leaves your side veiw it should be next to you in your window.
12-04-2010, 01:04 PM | #12 |
Drives: Really Slow Join Date: Apr 2010
this could help as well.
12-04-2010, 01:11 PM | #13 |
Thread Killer
12-04-2010, 01:15 PM | #14 |
Booooosted.
Similar Threads | ||||
It's 2 Damn High! THE GAME! | Zabo | Off-topic Discussions | 10 | 10-22-2010 10:17 PM |
How To: Adjust Your Mirrors to Avoid Blind Spots | mcarney | 5th Gen Camaro SS LS LT General Discussions | 9 | 09-20-2010 07:55 PM |
Anyone want my pre-order spot? (Dallas, TX) | eggydoo | USA - Texas | 11 | 04-27-2009 10:25 AM |
anyone in Southern California needing allocation spot | briwalbri | USA - California | 1 | 02-22-2009 07:43 PM |
anyone want my spot? | sidetracked3 | 5th Gen Camaro SS LS LT General Discussions | 18 | 02-20-2009 04:47 PM |
