SO CAL HEAD TURNERS
Drives: 2010 CHEVY BROMARO Join Date: Apr 2010
painting rims
has anybody tried painting their own rims?
![]() Drives: 2010 Camaro 1SS/RS LS3 blck w/ IOM Join Date: May 2010
I was thinking about painting my RS rims but I'm scared to mess them up, I'm not so sure about the steps needed to prep the tires, is rattle canning them a bad idea?
![]() Drives: 2013 SIM Camaro 2SS/RS/1LE NPP NAV Join Date: Jun 2010
I painted mine. My sig is linked to my journal post with pictures.
Here is how I did it - Matte Black I purchased: 4 cans of Duplicolor Primer Sealer 4 cans of Duplicolor Wheel Coating - Matte Black A package of 320 grit sandpaper 3 rolls of masking tape I removed one wheel at a time. Cleaned and dried the wheel. Scuffed the entire wheel surface with the 320 grit sandpaper, ensuring to get all the nooks and crannies. Cleaned and dried the wheel again. Laid a strip of masking tape between the wheel lip and the bead. Masked off the rest of the tire. Sprayed the wheel with 2 coats of primer. Sprayed the wheel with 3 coats of Matte Black. Allow to dry for 2 hours. Reinstall wheel and remove the next, lather, rinse, repeat. Last edited by 2Devious; 08-20-2010 at 02:55 PM. Reason: spelling doh |
how has that been holding up, is it a bad idea to clear coat it?
#6 |
yea it does look great I think I'll paint mine myself.
#7 |
So far it is holding up perfectly. I have put about 750 miles on the car since painting. Zero paint chips , flaking etc etc.
If you want to clear coat them just get the Duplicolor wheel coating CLEAR and follow the directions. I wanted to keep the Matte finish but have been kicking around the thought of clearing them. My biggest tip on doing this is: "Preparation is THE KEY!" A paint job will only come out as good as your surface prep. Spend the extra time to make sure you get all of the corners and hidden spots with the sandpaper. Then, make sure the wheel is CLEAN AND DRY before moving ahead. |
#8 |
"Camaro Joe"
its not that hard, id recomond a self etch primer but its personal prefference, a good scuffing is key
#9 |
SO CAL HEAD TURNERS
thanks man. im definetly gonna do it. i might try and do a red pinstripe around the rim
#10 |
SO CAL HEAD TURNERS
I did it this weekend. It looks amazing
#11 |
Please post a pic! If you added pinstripe, explain how you went about that thanks
#12 |
![]() ![]() ![]() ![]() ![]() Drives: 2010 IOM 2LT 334HP Join Date: Feb 2010
Sounds cool, but I would be scared to death to try it. LOL
#13 |
![]() ![]() ![]() Drives: 2018 Camaro 2SS Join Date: Aug 2010
I find it hard to be interested in rattle canning wheels when most reputable powdercoating shops will do your wheels for around 50$ a wheel. way more durable.
#14 |
I will be attempting this tomorrow, I'll post pictures of the outcome. Any tips to scuffing/prepping surface other than 320 sandpaper?
| Painting the RS rims | ducq | Wheels and Tires Talk Sponsored by The Tire Rack | 2 | 09-03-2010 08:57 PM |
| Painting RS rims, need advice | ewynn9 | Wheels and Tires Talk Sponsored by The Tire Rack | 3 | 08-13-2010 02:43 PM |
| painting rims | lootah | 5th Gen Camaro SS LS LT General Discussions | 3 | 04-28-2010 12:03 PM |
| Powdercoating... Anodizing... Painting??? WHAT TO DO TO THE RIMS????? | hv92 | Wheels and Tires Talk Sponsored by The Tire Rack | 7 | 04-11-2010 12:01 PM |
| Painting Chrome Factory Rims Black | Kory Hendrickson | Wheels and Tires Talk Sponsored by The Tire Rack | 0 | 02-15-2010 09:46 PM |
