![]() Drives: '11 SIM 2ss/rs LS3 #13363 iom seats Join Date: May 2010
DIY: Trunklighting with an LED strip **EASY!!**
As most of us know, the incandescent bulb in the trunk is practically useless. So, I also put in a 5050 LED in place of the incandescent, which made it noticeably better, but did not get the entire trunk well lit.
So if you want HUGE amounts of light, here is an EXTREMELY easy and fast DIY to get a light strip in there. Also, if you were ever looking for a simple DIY to learn soldering, this is one for you! I am a novice solder-er myself, but this is one DIY where soldering is FAR easier than trying to use T-taps. Before Light strip: After Light strip: Materials needed: 1. Light strip (I used XenithXenon's strip and LED bulb, they really should make it a kit since they work so well for this) 2. Solder iron (I got mine from Radio shack with some solder and a few extras for less than $10) 3. Electrical tape/Masking tape/Zip ties: for holding the strip in place temporarily and securing the wiring. STEP 1: Open the trunk and leave it open for around 5 minutes or so, until the trunk light turns off. It will do so automatically. ITs important to do this because its VERY easy to short-circuit the light due to the structure of the housing STEP 2: Use screwdriver to pop out the light housing. There is a slot on the side to place your screwdriver. Disconnect it from the harness (push pin on red-wire side and slide out). STEP 3: Cut the wire that came with your light strip. If your using XenithXenon's strip, the side of the wire WITHOUT the stripe goes to the side of the housing where the BLACK wire comes in from the harness. Solder the wire to the metal on each side as shown. Your other option is to put T-taps on the harness wiring, but this is a MUCH bigger PITA to do in my opinion. STEP 4: Test your light in various places using the masking tape or electrical tape. Once you find a spot you like, secure with the 3M backing on the light strip. Make sure your wire will reach there before securing! If not you can always extend the wire with some extra. The pic below shows the difference with the incandescent bulb and the light strip. STEP 5: Ziptie the wire to the harness and pass the wire up through and out one of the holes in the trunk near where you want to mount the strip. If the edge of metal looks rough, put some electrical tape around the edge and around the wire where it comes through. Ziptie wire where it seems appropriate to avoid any dangling wiring or possible points of friction. STEP 6: Connect interface of wire to light strip. Light it up! |
![]() Drives: 67 Camaro 350, 2010 2SS Join Date: Apr 2009
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
That's hot.
Looks good!!
YDLYLB
Nice job.
#6 |
![]() ![]() ![]() Drives: 2018 Camaro ZL1 Join Date: Nov 2009
where did u get your trunk liner from and how much both look good
#7 |
#8 |
![]() Drives: '14 2SS/RS AGM 1LE NPP, 1995 Imp SS Join Date: Sep 2010
That's a good look.
#9 |
#10 |
Drives: '15 Z06, '01 NBM SS, '97 SS Join Date: May 2009
Very BA!!
(Short for Bad Ass!) Nice work, Ivan ![]() |
#11 |
I have no life
Drives: 06' Subaru STI, ex-Camaro V6 LLT Join Date: Apr 2010
Wow thats a smart mod lol... i found my trunk light was very dim... this will be an awesome mod! Thanks!
#12 |
Summer
Drives: 2010 2SS/RS IOM w/ Black Stripes Join Date: May 2009
I got a light strip from AAC and hopefully I can get to doing it this weekend
CAI intake, Rotofab W/W Reservoir, Hurst Shifter, Skip-Shift Eliminator
AAC lighting, Kooks LT headers w/ high flow cats and Borla ATAK cat-back Restoring or need parts for a Chevy. Look no further than Don's East Coast Restorations |
#13 |
Summer
did the lights this morning and WoW! Love You AAC!!! I connected the wires to the mount like 13lade. way better than trying T-taps
#14 |
Looks awesome man! I used the red xenithxenons led strip for my footwells a since I have the IOM interior also, and thought about doing the same for the trunk... Glad to see a pic of how good it looks!
Q for you PhaseV, are your Lloyds mats with the red logo or orange logo? I cant tell which would match best with the IOM leather/stitching? |
AACstyle LED strip vs. CCFL footwell lighting | binlow84 | Cosmetics and Lighting Modification Discussions | 29 | 11-05-2011 11:50 PM |
100% Waterproof LED Strips with 12pcs of 5-5050 SMD LEDs starting at $12.95 each! | Xenith Xenons | Interior Parts & Accessories | 54 | 01-23-2011 06:00 PM |
DIY - Install Flashtech 24 LED foglights (Non-RS) | wylde1 | Camaro DIY & HOW-TO instructions & discussions | 10 | 12-02-2010 08:46 PM |
DIY V-LEDS 28 LED 5202 Fog Lights High Output! I mean BRIGHT results. | D1BADZ | Camaro DIY & HOW-TO instructions & discussions | 20 | 07-21-2010 01:57 PM |
