Old 10-07-2010, 08:02 PM   #1
SC2150
V6 Catch Can Installation:
2010/2011 V6 Camaro
Catch Can installation
The V6 GM engine is one of the worst in oil ingestion into the intake air charge. The following pictures will walk you through the installation.
We used a color matched to the ABM.
Start with removing the top engine cover and locate the vacuum tube as shown above. This tube runs to the passenger side valve cover where the crankcase vapors are drawn from.
Cut the plastic tube as shown, and slip one hose over the inner plastic tube making sure it slips on at least an inch. You will not need a clamp as the hose fits snugly and is not under pressure.
Above shows the vacuum end already cut. It is only oriented in this direction to show where to cut it.
Next, bolt the can to the bracket using the holes closest to the radiator mount.
The hose running below the bolt will need to be raised to above the mount to avoid pinching. It does NOT need to be disconnected, simply moved up.
With the can mounted, run the hoses as shown. The fittings both turn to orient as needed. The center fitting of the can is the inlet, and runs to the end terminating at the rear of the passenger valve cover. The outlet connects to the intake manifold vacuum source.
Run the remote drain tube along the pass side of the radiator fan shroud and zip tie it to secure it in place. Run the hose down so it terminates in a convenient location so draining is easy. The hose included may be longer than needed, so simply trim any excess.
The can should be drained every oil change and as the contents are nasty, do NOT put it into the crankcase! Discard properly.
Old 10-07-2010, 10:43 PM   #2
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Awesome write up. I'll be in touch when the bank account rebounds.
[B]
Old 10-08-2010, 11:03 AM   #3
TIE FIGHTR
Cousin of Foo
TIE FIGHTR's Avatar
Drives: 2010 2LT RS BLACK/BEIGE
Forgive my ignorance...but what's the purpose?
'I wish I was the full moon shining off a Camaro's hood' ~ Pearl Jam Wishlist
TIE FIGHTR is offline   Reply With Quote
Old 10-08-2010, 11:06 AM   #4
SC2150
Here is a good read to help understand the issue:
http://www.camaro5.com/forums/showthread.php?t=68744
Old 10-08-2010, 11:11 AM   #5
TIE FIGHTR
Cousin of Foo
TIE FIGHTR's Avatar
Perfect...thanks for the edification!
Old 10-08-2010, 11:28 AM   #6
Sevn86
Sevn86's Avatar
thanks for the link...I had the same question.
3100 Sequenced:10/12/09
3400 Broadcast:10/22/09
3800 Produced:10/27/09
4200 Shipped:10/29/09
Old 10-08-2010, 12:13 PM   #7
SC2150
Old 10-08-2010, 12:19 PM   #8
bluedevil02
bluedevil02's Avatar
Drives: 2LT/RS
im curious to see how much oil this can will actually catch
bluedevil02 is offline   Reply With Quote
Old 10-08-2010, 12:37 PM   #9
devildoc
devildoc's Avatar
Drives: '12 Toyota Tacoma Dbl
How much does this cost and where do I get it at?
STANDING 1/4MI: 13.948@99.87
6600RPM HP/TQ Gains - 30.54HP/24.3TQ (NOT PEAK)
devildoc is offline   Reply With Quote
Old 10-08-2010, 12:41 PM   #10
CamaroDreams07
Drives: Slow V6
Here you go
[B]
Old 10-08-2010, 03:10 PM   #11
SC2150
This is one of the most effective cans on the market, and has several features others do not. Will catch nearly all if not all.
Old 10-08-2010, 04:20 PM   #12
KMPrenger
KMPrenger's Avatar
I'll be buying...just not sure exactly when lol. Soon though!
Old 10-08-2010, 04:37 PM   #13
SC2150
We've got your color!!
Old 10-08-2010, 04:46 PM   #14
KMPrenger
KMPrenger's Avatar
lol I know...and from what I understand, you didn't have many of the blue in the first batch right?? Will there be more...or is that it??
***** RK Sport SS and V6 Body Kits On Sale ***** SicMSP Exterior Parts & Accessories 13 10-28-2010 05:36 PM
Ford EcoBoost V6 to power ALMS racecars in 2011 All-Or-Nothing General Automotive + Other Cars Discussion 0 08-07-2010 12:23 AM
V6 Camaro - V6 Mustang Rivalry Markal Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 67 07-08-2010 05:41 PM
V6 Cami VS V6 Genesis..LOL MillerTime Chevy Camaro vs... 226 06-09-2010 10:00 AM
