11-17-2010, 04:17 PM | #1 |
Drives: Red 2SS/RS M6 Join Date: Apr 2010
DIY remove door handle
hello, had a request by a member to do a post on removing the door handle. so here it is. 1. tape as in the pic, put some tape also on the end of a flat blade screw driver, carefully pry up the cap that cover the key mechanism. 2. remove plug from inside door, use a #20 torx bit and begin to turn counter clockwise until it stops, while turning the screw, wiggle the key lock and lift it out. you might need to pull on the door handle just a bit for the lock to come out. once the lock is out, screw the torx screw in until it stops, if you look in the hole you can see the 2 teeth move that hold the lock. this is important. now with the lock out of the way, you will have to pull the handle out, like if you are going to open the door and toward the rear at the same time, on the next pick you can see the little lever arm that the handle is pulling on. you will here a snap as it clear and the little lever pops back in. remove door handle. ok now to get the handle back it, i took some thin wire and pulled the little lever forward and pushed the handle in and once it was in i pulled the wire out. now you can screw the torx bit counter clock wise again and see the teeth going back, you might have to wiggle the door handle a bit the get the lock to seat, once it seats, screw the torx bit in until it stops. Put the cover back on, again you might need to wiggle the door handle a bit. lupe Last edited by overhaulengines; 08-24-2016 at 12:54 PM. |
11-17-2010, 06:13 PM | #2 |
My boredom isn't safe
not sure why anyone would need this besides shaved handles, but you can never have too many DIY's
Thanks for taking the time to help people out!
11-17-2010, 09:09 PM | #3 | |
Lupe |
11-17-2010, 09:25 PM | #4 |
buzzy56
thanks for sharing
Thanks for sharing this.You never know when you might need to do this.
OLD SCHOOL / NEW SCHOOL COOL
11-18-2010, 12:22 AM | #5 |
Thanks. Very good instructions.
2010 2SS Camaro (sold) 2010 ZL 427 Camaro (sold) 2012 ZL-1 Camaro (sold) 2018 ZL-1 Camaro |
11-23-2010, 12:37 AM | #6 |
Tampa Gulf Coast Family
Drives: Sold c7, in the market! Join Date: Mar 2010
02-20-2011, 05:13 PM | #7 |
Drives: 2010 2lt RS,Have 68,69 camaro Join Date: Aug 2010
I had to remove mine.Thanks
02-20-2011, 08:18 PM | #8 |
02-21-2011, 10:03 PM | #9 |
I removed it just fine,with the instructions you listed.Never seen one like this before.
08-19-2011, 02:46 PM | #10 |
Drives: 2011 Camaro 1LS Join Date: Jul 2011
Im thinking about removing mine to paint them. Hope i can follow directions lol.
07-20-2012, 06:30 AM | #11 |
Royal Scorpion
Drives: Camaro R/S (pimped) Join Date: Nov 2011
hello man,
can you please explain how could you get the cable out, if you want to install a small led strip from the inside part of the handle? |
07-21-2012, 10:05 AM | #12 |
I run 2 catch cans...
Will the passenger's side cover fit over the driver's side lock? I am thinking about deleting the handle lock.
Overkill tuned • Air Scoop • CAI • VMAX PTB • JacFab Laminator FX + Extendolator • SOLO Hi-Flo Cats + Cat-Back Exhaust
View my top 3 LFX performance mods and more: . |
07-24-2012, 10:30 AM | #13 | |
Drives: 2010 Camaro SS/RS Join Date: Aug 2009
Yes the Passenger side cover works on the Drivers Side. I've had it done for a couple years now and love it.
2010 Camaro 2SS/RS Summit White| Black Leather Interior | JBA LTH 1 7/8" 3" High Flow Cats | 3" Magnaflow Comp Cat-Back | CAI Intake | SCT Tuner with Jannetty Tune | Pfadt 1.25" Lowering Springs | Pfadt Front and Rear Sway Bars | Heritage Grill | Revolution Styling Chin Spoiler | Fesler Moss Fiberglass Side Rockers & Rear Diffuser | MPD1 Rear Spoiler | Tinted Windows | Camaro Chrome Under the Hood | AAC LED Fog Lights | PSI Laser Etched Mirrors |
07-24-2012, 11:12 AM | #14 |
Drives: 2010 Camaro LS Join Date: Mar 2010
there have also been guys who have bought Cruze door handles for a different look...they are a direct replacement...see this thread
http://www.camaro5.com/forums/showthread.php?t=228685
Similar Threads | ||||
DIY: PDIM + USB Port installation | jtzako | Camaro DIY & HOW-TO instructions & discussions | 159 | 12-30-2017 04:02 PM |
DIY : Install Lowering Springs on 2010 Camaro | Nine Ball | Camaro DIY & HOW-TO instructions & discussions | 42 | 03-29-2017 01:31 PM |
DIY: How to Change the Door Speakers | RandyB | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 15 | 04-26-2014 10:53 PM |
DIY : Install underdrive pulley on 2010 Camaro SS | Nine Ball | Camaro DIY & HOW-TO instructions & discussions | 34 | 09-30-2013 08:25 PM |
Pfadt Race Engineering DIY Drop Spring installation procedure | PfadtRacing | Suspension / Chassis / Brakes | 20 | 09-23-2011 09:31 PM |
