Old 12-29-2010, 06:49 PM   #1
ssmike
BL1ZZRD
ssmike's Avatar
Tally of broken output shaft VIN's
If your T6060 output shaft has broken please post your VIN and whether GM repaired it under warranty. I'm trying to get an idea of VIN number range and results of warranty work for those of us that are worried that we may have ticking time bombs (VIN's under 25000)!
My car is VIN 23036 and so far so good but I'm worried that I may have one of the weak output shafts. Mine was built on 6/30/09 1 month before the production stop in July '09. GM has not come forth with any information and has left us to wait for failure and have a warranty claim. Just like most of us here that have done any mods I worry that if mine goes they might give me a hard time. Also I'd like to sink more money into suspension upgrades and maybe a tune but I don't want to be faced with a $4000 bill if my shaft goes!
I did a search and couldn't find a good source of vin numbers affected. If there was another thread on this I appologise for the repost and please direct me to the thread! If we get together and compile some data maybe we can have a better idea of which VIN's may be affected! Thanks in advance for your posts!
VIN# username
16614 hiller72
16531 rrcamaro
17711 nitromater13
14461 orangeinfernoman
13070 speeflo
14226 kimpossible
17161 carguy
13782 nuptualnemesis
14368 anolahic
14402 royalken
18934 ucf woot
9701 multi ss
4920 mercuryman96
9862 mstrfdsstr
10xxx mrgazinya
9648 tlc9193
13269 steve
17750 amwellls1
18678
18254
9691 stikSS
19687 mwt18
10872 VaderSS
18587 BlaSSt Off
12xxx Huggerorange73
12xxx Maxdmax
8243 Ls3Power
12103 BLACK10
Old 12-29-2010, 06:57 PM   #2
MrGazinya
MrGazinya's Avatar
Drives: Aggressive
I am in the low 10,000 vin number, and I broke.. GM replaced my trans under warranty.. Thank you GM
Black 2SS RS LS3 Inferno Int. '17 1LE replica 20's {MODS} KOOKS LT: Borla S-Type: Roto-Fab CAI: Hurst ST.: PFADT Stage 2, Trailing arms, Tie Rods: ECS BigBlower Cam: Fast 102mm intake: Brian Tooley racing dual spring kit: TFS pushrod set: Katech C5R timing chain: Mellings high volume oil pump: ATI Balancer: Ideal performance upgraded clutch master cylinder:Tick performance upgraded slave cylinder/throwout bearing: Mantic 9000 twin disk clutch & light weight flywheel: Tuned by Doug Ring at ECS. 475RWHP/445RWTQ.Dynapack Dyno.
MrGazinya is offline   Reply With Quote
Old 12-29-2010, 07:04 PM   #3
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
yep you and I are screwed. Obviously mine wont be a warranty item due to mods. But on the bright side....the output shaft is only part of the problem and a new tranny would not solve the syncro problems so worry not and save up about 3K for a new one. Vin 8874 May 09
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 12-29-2010, 07:34 PM   #4
ssmike
BL1ZZRD
ssmike's Avatar
So with all that power has your tranny held up or did you have a shaft failure?
Old 12-29-2010, 10:29 PM   #5
tandtperformance
tandtperformance's Avatar
Drives: 2010 Camaro 2011 PACE CAR 2012 ZL1
Send a message via Yahoo to tandtperformance
iam vin#8522 with over 600rwhp and i haven't had any thin go wrong with mine
tandtperformance is offline   Reply With Quote
Old 12-30-2010, 07:22 AM   #6
ssmike
BL1ZZRD
ssmike's Avatar
Good to know! Thanks! I guess in reality I'm hoping for more positive feedback like yours! I'm thinking there's probably a batch of closely numbered VIN's affected. That's why I'd like to get a tally of all the broken ones! We'll see!
Old 12-30-2010, 07:50 AM   #7
2010 SS RS
2010 SS RS's Avatar
Its still working fine. 200 track runs to date. However, I dont do 6000 rpm clutch drops. I also always run with TC and stable track off. In fact I am still on my original half shafts still. I think a lot has to do with the driving habits regarding output shafts.
But my builder knows the weakness of the syncros so like I said...its a matter of time no matter how its sliced. Output shaft bearing was added subsequent to ours being produced and has corrected most of the issues with the shaft itself. Our cases are already forged for the bearing so you could bite the bullet and have one installed if you choose...but you might as well build the guts at the same time.....
Old 12-30-2010, 08:51 AM   #8
ssmike
BL1ZZRD
ssmike's Avatar
So are you saying that after VIN 25000 GM started installing the bearing?
Old 12-30-2010, 09:13 AM   #9
acowherd
acowherd's Avatar
Drives: 2010 2ss/RS 4l80. 2009 2500 HD
Broke mine at the track...let out the clutch a little too fast and it snapped. 600 rwhp and drag radials, and it was hooked up good too. Vin in the 35000 range. There was no output shaft bearing. Now I am rolling with an built RPM Tranny
Follow along as we build and race this 2010 Camaro!
https://www.facebook.com/pages/FNSS-...75028626000379
FNSS Racing!
acowherd is offline   Reply With Quote
Old 12-30-2010, 09:31 AM   #10
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2011 2SS/RS/A6 cammed-n-whippled
not sure your vin matters on this one...with that setup, you'd break a lot of stock transmissions.
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 12-30-2010, 09:41 AM   #11
ssmike
BL1ZZRD
ssmike's Avatar
Yea, that's what I was thinking!
Old 12-30-2010, 10:41 AM   #12
tlc9193
The Original
tlc9193's Avatar
Drives: 2010 Camaro 2SS
Send a message via Skype™ to tlc9193
Vin 9648, broke axle shaft at track using launch contol. Stock at the time of breakage and dealer replaced with no problem.
LETHAL RACING Phase V, "ECS Supercharger, Nightfury cam, Methanol Injected, Dual Fuelpumps, Kooks Headers with Hi Flow Cats, 3'' Catback Magnaflow Exhaust, Custom Tune, H & R Drop Springs,Barton Ind. STS 773 RWHP.
tlc9193 is offline   Reply With Quote
Old 12-30-2010, 11:07 AM   #13
Merc
In The Circle
Merc's Avatar
Pumpkin is Vin # 4xxx and I broke the mainshaft. GM repaired it only.
Old 12-30-2010, 11:09 AM   #14
Merc
In The Circle
Merc's Avatar
Pumpkin is Vin # 4xxx broke mainshaft. GM repaired.
Camaro team's response to concern about Transmission Output Shaft Failure Mr. Wyndham Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 389 07-09-2011 11:09 AM
Broken Half shaft Turbobitt V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 26 04-25-2011 09:14 AM
DriveshaftShop is now testing a new 31 spline Tran. output shaft Driveshaftshop V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 24 12-24-2010 04:27 PM
M6 output shaft, ticking time bomb? ssmike V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 5 12-14-2010 07:18 PM
