Old 01-19-2011, 11:38 PM   #1
J-Rod6410
M6 9 second club
J-Rod6410's Avatar
Drives: A 4000 Lb BeaSSt
Angry Why wont my cammed car lope??? Video added!
Looking for some help. I've installed the bolt-ons....LT headers, CAI but I wanted more power..... but I especially wanted my car to lope heavily at idle. So then I installed a cam kit myself a few months ago. I then had it tuned by someone who, well, did his best. Anyway, after going back to him several times to tweak here and there, he finally got the car to lope...when the a/c compressor is on only Now that its cold, the a/c doesnt run and the idle sounds like crap(to me). It idles pretty damn smooth. I loved it when the car loped and rocked back and forth Problem is it ran badly, bucked, surged, hesitated and was exremely rich. Now had it retuned by someone else(prefer to keep names out). Car runs alot better, a/f ratio is now good and picked up a few ponies but the lope is all but gone
I got a BIG cam because I wanted a BIG lope. Specs are 235/251 621/624 113 lsa. So can any tuners or somebody out there tell me what parameters need to be adjusted in the idle to make it lope and rock back and forth(EFI Live). Right now its kind of choppy but nowhere near where I'd like it to be.
EDIT: This is a video of my car. I decided to add one to the first post due to all the confusion
BUT, I want it to sound like this. You can really hear it at the :55 mark of vid:
Please help me (and my tuner). Thanks in advance for any help
TEAM LS3 Best pass: 9.61 @ 146 with M6
TBDRWHP TBDRWTQ ECS S/C 408, YSi, m6, Mantic Triple, ZL1 diff
#BuiltByJRod.... J-Rod's Speed Shop.... Tuned by: Matt Sorian @ MS Tuning
Check out my youtube channel: http://www.youtube.com/user/6410Jrod
Follow me on Instagram: @J_Rod6410
J-Rod6410 is offline   Reply With Quote
Old 01-19-2011, 11:57 PM   #2
el ess A
Older Than Dirt
el ess A's Avatar
Drives: 2010 & 2013 Camaros
After reading that incredible post, that's about 2 minutes of my life I'll never get back...
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 01-20-2011, 12:01 AM   #3
acowherd
acowherd's Avatar
Drives: 2010 2ss/RS 4l80. 2009 2500 HD
What's your Idle set at???
Follow along as we build and race this 2010 Camaro!
https://www.facebook.com/pages/FNSS-...75028626000379
FNSS Racing!
acowherd is offline   Reply With Quote
Old 01-20-2011, 12:24 AM   #4
BlaSSt Off
BlaSSt Off's Avatar
Drives: 2SS/RS
Seriously?
BlaSSt Off is offline   Reply With Quote
Old 01-20-2011, 12:25 AM   #5
PoleCat2SSRS2010
R6P Marketing Lab Rat
PoleCat2SSRS2010's Avatar
Drives: sometimes
X 2
Idle rpm has an effect but is sometimes required for driveability and or operating vacuum dependent accessories like the brakes or AC (depending on the design of the car)
A bigger cam might put driveability at risk.
Rich conditions cause heavey lope but are not good for the life of the engine.
The old cars with the carburetuers would use cams that had a 106 LSA that had more overlap and tons of lope but could be converted to manual brakes and use a vacuum reserve can.
PoleCat2SSRS2010 is offline   Reply With Quote
Old 01-20-2011, 12:53 AM   #6
xx_ED_xx
xx_ED_xx's Avatar
Drives: 04 Silverado
I never buy a camshaft for the sound. With that being said. IS you car a manual or auto? A manual car can get away with more because it doesnt need to idle in gear.
I tend to pick mild camshafts because after driving big camshaft cars on the street I got sick of surging etc and poor around town drivability. The specs you stated are just a lil bit smaller then the hydraulic roller I am putting in my 8.85 liter motor.
xx_ED_xx is offline   Reply With Quote
Old 01-20-2011, 01:01 AM   #7
Chalk_2
Drives: 2010 Camaro 2SS/RS
It sounds pretty lopy to me.
Chalk_2 is offline   Reply With Quote
Old 01-20-2011, 04:24 AM   #8
Wilburbeest
Think With Your Dipstick!
Wilburbeest's Avatar
Drives: 1997 Camaro Z28
Really?
- Willy
1997 Camaro Z28 (LT1/T56): K&N CAI | Kooks 1 3/4" LTs | 3" Custom Duals | UMI LCAs w/ relocation brackets | UMI adj. panhard bar | UMI adj. torque arm | Koni SA shocks | Strano Springs | Ram Powergrip clutch | Pro 5.0 shifter | skip shift eliminator kit | WS6 Store rotors | Hawk HPS pads
Wilburbeest is offline   Reply With Quote
Old 01-20-2011, 04:46 AM   #9
fastfaster
Drives: xxxxxxxxxxxxxx
its a shame you're getting sarcasm instead of help.
is the 235/251 spec @ .050?
fastfaster is offline   Reply With Quote
Old 01-20-2011, 06:17 AM   #10
Chalk_2
Originally Posted by Wilburbeest View Post
Really?
Ya Really.
Old 01-20-2011, 07:18 AM   #11
Epitaph
Custom User Title
Drives: Fast
Originally Posted by Chalk_2 View Post
Ya Really.
No Wai!
Seriously though, try talking to another tuner (or a sponsor of this forum). They may be able to help you.
Epitaph is offline   Reply With Quote
Old 01-20-2011, 07:23 AM   #12
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
because you cammed it wrong... that's why your car won't lope
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
danhr is offline   Reply With Quote
Old 01-20-2011, 07:30 AM   #13
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
1) you can lower you idle
2) when you lower your idle, adjust your idle spark table a couple degrees so it doesnt stall when you come to a light
3) make your under and over speed timing table wider
I made a correction. I meant under/over speed in your idle adaptive spark control
Tampa Tuning is offline   Reply With Quote
Old 01-20-2011, 07:56 AM   #14
getarz4u15ster
getarz4u15ster's Avatar
Drives: Camaro RJT 2SS/RS
Lope... Really...??
I want it to sound like this:
Okay, So first of all thats alot of duration on that camshaft.. 235/251?? In combination with a semi-tight LSA... your driveability with this cam is going to stink at anything below 1200rpm. I can almost guarantee you that fact. However I'm not trying to dog on your choice of camshaft, I just want to give you some sound advice here.. Only reason i saying this is because i used to have a VERY similar cam in my Camaro. It's specs were 236/243 .614/.624 w/ 113LSA. It sounded pretty much exactly the way yours does, which i think is pretty dern choppy to me. And the the drivability at anything below 1300rpm was surging and bucking most of the time, 5th gear will be your friend at anything under 68mph...
If you wanted "more lope" per-say, you should have had it ground with a 110LSA that would have been REAL choppy (LSA is what gives you more or less lope, not solely but it's a big contributor)... however the tighter your LSA and the more duration you have typically the worse your driveability gets at low RPM. The camshaft you have, should make good power at anything over 4000rpm. The only other way to get the car to sound MORE choppy is set your idle speed down... be careful with that though as you can start causing vacuum issues and spark related knock problems, It should be idling right around 870 to 950. The Only other way to get a choppier lope.. turn the AC on.. it will pull more vaccum from the motor thus lowering the RPM a little, and get's a little more choppy..
Let's be honest though, is it the sound that really matters here the most, or is it the power that car makes.. I could make a moped sound like a street bike with the right parts... however, it still doesn't mean it's going to be any faster at the end of the day. The RIGHT combination of parts in these cars are the key.
2010 RJT SS
Port and Polished, Milled .005 Heads
Patriot Valve Springs, Titanium Retainers&locks
Manley Race Valves
Comp Chromoly push-rods
Ported T/B
DT Headers, JBA H/F Catted mid pipes
Magna Flow Comp series exhaust w/ Xpipe
Comp Custom grind Cam
Tune and Machine work done by MPC
CAI Intake
getarz4u15ster is offline   Reply With Quote
PQs Camaro [COTW 9/20/10] PQ Member Car Journals 5675 09-01-2024 08:48 AM
Washing/Detailing for Newbies MRK III Z28 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 124 02-05-2024 10:55 PM
What's considered a Muscle Car? SyN General Automotive + Other Cars Discussion 125 09-25-2010 01:04 AM
