02-05-2011, 05:34 PM | #1 |
Drives: Rally Yellow 2010 Camaro 2SS/RS M6 Join Date: Dec 2010
New Option for NON BA guys avaliable at ******** :D
It seems to me that this is a much better option than splicing into the rear speaker wires. Also I would assume the sound quality would be better witht the more precise signal you nwould get through this. Just ordered it the other day . They added this item to their site a week ago:
http://********.com/Car-Audio-Produc...io-AAGM44.html The AA-GM44 “T-harness” plugs into the vehicle’s wiring behind the factory radio. It provides a 4-channel adjustable audio output via two sets of stereo RCA connectors. This allows simple and quick audio connection to an aftermarket amplifier, without effecting the performance of the stock speakers. Expand the factory sound sytem without replacing the factory radio, by adding an amplifier. Simplify the installation by using the AA-GM44 to provide the audio signal without having to cut the factory wiring. Compatible Vehicles Include: 2010 & Up Chevy Camaro (Boston and non Boston) Chevy Equinox GMC Terrain Buick LaCrosse Cadillac SRX [IMG]http://********.com/images/AA-GM44sm.jpg[/IMG] ENJOY
Rotofab CAI, SW LT Headers and High Flow Cats, SW Cat-Back, Eibach Pro rear wheel spacers, SS Grill Insert, Street Scene Front Splitter, Blacked out rear emblem, blacked out bezels, plasti-dipped lower bumper, plasti-dipped rims with yellow pinstriping, dyed interior stitching yellow, 2x Kicker CVR 12's w/ 1200 watt kicker amp. MORE TO COME! |
02-05-2011, 07:34 PM | #2 |
EVIL SS
Drives: SIM '11 2SS/RS and '13 BD Avalanche Join Date: Jan 2011
http://www.supplytiger.com/addanamp-...-p-123018.html
Same thing as above but on sale... I have used PAC audio adapters in my last 4 vehicles for sub integration with stock headunits and they work flawlessly. |
02-05-2011, 09:55 PM | #3 |
Rumbly Bumble Bee
Drives: 2010 2SS Camaro Join Date: Aug 2009
So...why not just use ********'s harness that connects at the amp in the trunk? Makes for an easier/cleaner install because the battery is in the trunk and there is less wire to run.
One issue though, I keep asking Steve if the outputs on his harness are high or low level. I haven't got an answer yet. At least with the PAC unit you know they are low-level.
2010 RALLY YELLOW 2SS 6M
-OBX Longtubes FTW! |
02-06-2011, 01:43 AM | #4 | |
Drives: 2010 Camaro 2LT/RS Join Date: Sep 2010
02-07-2011, 12:12 AM | #5 |
Drives: Black LT Camaro Join Date: May 2010
If this was only available months ago when I spliced my rear speakers and connected them to a PAC SNI adaptor. What are the pros exactly of doing it this way instead of splicing? Also how do I remove the head unit to put that in if I were to do it?
02-07-2011, 12:15 PM | #6 |
The wait is over!
Drives: 2010 Camaro, IOM, L99, Auto Join Date: Mar 2010
the benefits are -
you dont have to cut your factory wiring harness, you can adjust the output of the RCA's so you can raise your input voltage before clipping so you can lower your amp gains and keep the noise floor low (better sound) you can remove the unit if you decide to sell the car and return it to factory cleaner signal path to your amp - grabbing signal in the trunk means grabbing and converting a signal that has picked up god-knows-what noises as it has snaked its way through to the rear speakers
Ordered - 4/17/2010
Delivered - 5/29/2010 AlphaDamp CLD Mat - Get more Sound Deadening with less Sound Deadener |
02-07-2011, 07:28 PM | #7 |
Drives: 2011 2SS IOM Vert Join Date: Aug 2009
This adapter can also be used as a way to add a 4 channel amp to amplify all of the factory speakers.
02-10-2011, 10:15 PM | #8 |
Drives: jealous vendors mad!! HAHA!! Join Date: Jan 2011
so basically its a kit to add a amp and sub to my factory non BA audio system without having to splice into factory wires making everything just really straight forward easy plug and play installation?
02-10-2011, 10:49 PM | #9 |
Darth Martel
Drives: Black 1SS with 20% tinted windows Join Date: May 2009
what does the factory head unit output per channel?
the factory speakers are 20W. it was my understanding that amping the speakers would only mean you'll blow them that much quicker |
03-07-2011, 12:12 PM | #10 |
Drives: IBM 2SS Join Date: Jan 2011
Just bought this product (AA-gm44), does anyone have a write-up of how to install this?
03-07-2011, 03:32 PM | #11 |
Drives: 2010 SIM Camaro Join Date: Sep 2009
What do you have to help with bass attenuation when adding a sub and amp to a no-ba stereo?
03-07-2011, 04:32 PM | #12 |
Drives: 2011 2SS/RS, 2010 Mustang GT Join Date: May 2010
03-10-2011, 07:05 AM | #13 |
I'm ILL but Not Sick!
Steve you said you can use the harness to amplify the 4 aftermarket speakers as well as the sub in back? what's the best amp for that type of setup?
03-27-2011, 05:19 PM | #14 |
Similar Threads | ||||
Hurst Shifter option still available? | WesYFZ | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 11 | 12-03-2010 06:02 PM |
******** poll | BriCo84 | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 29 | 11-09-2010 12:51 PM |
* * * Synergy Green Pricing Announced - Option B2E * * * | CamaroScotty | Camaro Price | Ordering | Tracking | Dealers Discussions | 20 | 01-24-2010 03:06 PM |
Factory Exhaust Option SPECULATION!!!! | jmliptak | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 13 | 07-21-2008 10:13 AM |
