WICKDSS
Drives: 2011 1SS/RS IOM LS3 Join Date: May 2010
Drag radials with stock drivetrain?
Ok, so I am looking at getting some dr's (oem size) on the car for a true street shootout race coming up, also installing spohn trailing arms this weekend. My question for the street/strip guys is - will my stock drivetrain hold up to this abuse with my current mods and hp? Or should I upgrade the diff and/or at least the axles? Thanks for the help!
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei 11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds. |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2ss/RS 4l80. 2009 2500 HD Join Date: Mar 2009
I would upgrade the axles.
Follow along as we build and race this 2010 Camaro!
https://www.facebook.com/pages/FNSS-...75028626000379 FNSS Racing! |
Drives: 2010 Camaro Join Date: Feb 2010
With the LS3 axles would be a gd idea. If you were an L99 I would say don't worry about it but the M6 cars seem to be very hard on drivetrain equipment.
#4 | |
Only drives on Sundays
Drives: '16 2SS A8 NPP MRC NGray Join Date: Feb 2011
Padre |
WICKDSS
Looking at getting the jre axles. Hopefully this can get me by. Really set on nitto 555r dr's to drive to and from track. this car isn't a daily driver. SuperchargedSS, are you running all that power on stock diff with a jre posi mod?
#6 | |
Until you get into the 11's, you can't kill your diff or axles. I'm an L99, but really, with your mods, only thing that will hurt your drivetrain is bad wheelhop. I have Nitto 555R's (305/45-18) going on this weekend for the drive to the track and some passes. I also have BMR rear trailing arms. Padre |
#7 |
I have broke the output shaft on my tranny. I wouldn't trust the stock axles...Many have broke using launch control. I have also seen Richmond gears break.
Supercharged SS...What were you guy's working on during the LSX SHOOTOUT in STL??
#8 |
Drives: Camaro Justice Join Date: Jun 2007
After more te$ting than I care to think about we have come to the conclusion that the most important drag racing suspension modifications are sub-frame inserts or full bushes and toe links. Trailing arms are a distant distant third.
GM has a robust track validation program for their cars. The program is constantly improving as is the GM product. The one thing that the GM testing does not cover is after market tires. The stickier the tires, the better prepared the track the shorter the fuse on your driveline. The cheapest and most overlooked drag strip modification is rear wheel alignment. The less negative camber you have at rest, the better your rear tires will bite as your 5th Gen squat-ts. |
#9 | |
Now, if he wants to make a 10-second car, all bets are off. Guess I just think recommending axles, new diff, and other big-$$$ mods at this point is a bit of overkill. Padre |
#10 | |
#11 |
Prefer to be blown!
Drives: 2010 Silver/Black 2SS/RS Manual Join Date: Mar 2010
My stock axles are holding up so far with Nitto 555's in the back and 12.66 runs. I'm easy on it off the line and only get wheel hop doing my wet burnout. I saw a guy break something on his first attemp down the track on a stock car. Don't just dump the clutch, something will break and you will not get traction that way anyways.
#12 |
WICKDSS
Thanks Guys! I am pretty certain the car is capable of mid 12's as it sits right now, with better traction. Just wanted to be cautious how hard I can push it until I can get all of the parts upgraded eventually. Looks like the cam install will have to wait awhile longer.......need to address the suspension and drivetrain at this point. I am working my way, slowly, towards an 11 sec street car.
#13 | |
This I agree with.
#14 | |
| 18 or 20" drag radials | tom692010 | Dragstrip and Launch Techniques Discussion | 44 | 03-15-2012 04:59 PM |
| Use factory front rims for rear drag radials | caverman | Dragstrip and Launch Techniques Discussion | 0 | 06-09-2010 05:16 PM |
| 18" M&H Drag Radials on Z06 wheels | Supercharged SS | Wheels / Tires | 20 | 05-22-2010 01:35 PM |
| Drag Racing Suspension Kits | Info@PeddersUSA.com | Suspension / Chassis / Brakes | 25 | 02-21-2010 09:48 PM |
