Don't Like it? Suggit.
Planning to install my springs this weekend (with the help of some trusted friends) and I've been hearing that the bushings will need to be tuned...
Can someone enlighten me? I had no idea this was even possible, let alone how do accomplish it... ![]()
"Tops off, tach up baby- loud and proud!" A Camaro lover from day one- 1996 3.8 V6 Camaro, to 1996 5.7 LT1 Camaro Z28, to the sold 2002 5.7 LS1 Camaro SS, and NOW, a [I]6.2 L99 VR 2SS/RS: XS Power stainless full exhaust, Airaid CAI, BMR drop springs and sways, custom tune by Cal Speed- 411rwhp |
#2 | |
![]() ![]() Drives: 2011 Challenger SRT8 6.4L 392 Hemi Join Date: Jul 2010
You were close.. It's timing the bushings. Hope this helps Originally Posted by JusticePete ![]() While some lower their cars just for the look, many lower their cars for improved function. To get the full benefit of lowering coils, you need an alignment tech that understands performance vehicles and lowered vehicles. The first step in proper alignment on a lowered car is to break loose the bolts at every rotational suspension bolt. That would the the radius and inner control arm bolts up front. In the rear, the trailing arm, toe link, upper and lower control arm at the knuckle and he lower inner. The car then should be at least bounced. The prefer-ed method is driven gently slowly around the ship parking lot. With the weight of the vehicle on the wheels all the bolts are made tight. This process times the bonded ferule OEM rubber bushes to the new ride height. Timing the bushings balances the car. The rotational resistance in the bushes is actually a second set of springs in the car. If they are not timed to the new ride height they are creating uneven loads as the car moves over a bump. The suspension will function correctly with the bushes timed and will also last longer. Only a professional that understand suspension will take this extra step. Your alignment professional should discuss with you how you want to drive your car. The alignment specifications for a weekend warrior drag racer would be different than the specifications for a weekend auto cross warrior. If you want optimum tire life the alignment specs are different from those that want optimal cornering on the highway ramps or twisties. Suspension and alignment work done well on a Camaro will produce fantastic results. Choose our alignment professional carefully. They will make a real difference in your enjoyment when driving.
2011 Stock 6.4L 392 Hemi Challenger
Flowmaster American Thunder Series Cat Back Camaro parts for sale: http://www.camaro5.com/forums/showthread.php?t=152474 |
That helps alot, thanks Ray!!
No problem.. That's what we are all here for...
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '69 SS Convertible Join Date: May 2009
Go through this thread as well. Look at post #45.
http://www.camaro5.com/forums/showth...t=71994&page=2
Build Journal ![]() |
#6 | |
Drives: His Wife Crazy Join Date: Jan 2008
#7 |
Thanks guys, gotta love my C5 family!
#8 |
I think this was my bad.....I had called it "tune your bushings" in one or two other threads.
Nice to know that I was able to pass along the concept but it's my loss of memory on what it was called.... ![]() I take that blame.... ![]()
#9 |
![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS SIM Join Date: Apr 2009
That was explained brilliantly!
![]() Every car I did suspension work on had this done to them. It took a bit longer, but the end result was worth it. Everything responds better and lasts longer. This one step can really prolong the life of the bushings after lowering springs are put in, and as said before, the handling is outstanding! |
#10 |
Drives: Camaro Justice Join Date: Jun 2007
Tune , time, tomatoe, tomaatoe it doesn't matter as we are doing it!
#11 | |
#12 |
#13 |
NEcamaro5
Don't know if this is ok but this past friday I had my car allined. The guy loosened all the bolts then rolled the car back and had his Helpers bounce the car as he was under the car watching how nose what. Then they mounted stuff too the rims and a half hour later he was done. Dose this sound wright. I had put lowering springs in and he said he was tuning yes tuning the suspension. The car handles like a dream and no squeaks. Am I ok??
#14 | |
Camaro tuner in Tampa. Tampa Tuning performance tuner | Tampa Tuning | 4th Generation Camaros | 0 | 02-17-2011 08:12 AM |
Best priced camaro corvette GTO Firebird Trans Am GM Truck tuner Tampa Tuning | Tampa Tuning | V8 Bolt-Ons & Tunes | 1 | 01-30-2011 05:02 PM |
Pfadt Street/Race Rear Differential Bushings, get more power to the pavement! | Apex Motorsports | Transmission / Driveline | 5 | 08-10-2010 05:49 PM |
Urethane Bushings from Energy Suspension | Bewenched | Suspension / Chassis / Brakes | 1 | 04-30-2010 05:12 AM |
