Old 03-29-2011, 10:50 AM   #1
Tran
Administrator
Tran's Avatar
Cool Motortrend Drives Geiger's Supercharged Lime Green Camaro
First Drive: Geiger Cars Chevrolet Camaro SS
Bombing through Germany in Geiger's Supercharged Lime Green Menace
March 29, 2011
/ By Nick Hall
A lime green Camaro SS with a supercharged whine, aggressive bodykit, writing on the windshield, and the number 13 on its side would draw stares even in downtown Detroit. We're not in Detroit, though, or even the United States. This is downtown Munich, Germany, BMW's backyard, and half of the people staring at the Geiger Cars Camaro SS think we're the coolest guys on Earth, while the other half think we're epic tools.
Europe is used to laughing at American cars. But the groundbreaking performance of the Corvette made a whole continent look again, and now the Mustang and Camaro SS have won a healthy following on the other side of the pond. Karl Geiger's outfit used to make most of its money selling Hummers and Dodge Rams to the cowboy-boots-and-line-dancing brigade. But now the younger crowd, footballers, and others are snapping up the latest-generation pony cars as fast as they're imported.
Geiger doesn't just import U.S. muscle. It tunes it, too. This Camaro SS comes with an Edelbrock E-Force Supercharger strapped to the LS3, pumping out some 560 horsepower through a new exhaust system that sounds like God is mad. The 6.2-liter V-8 finally has the bite to match its bark, and if the numbers quoted by Edelbrock are even close to accurate, this is a serious machine that could easily mix it up with the best the Germans have to offer - in a straight line, anyway.
Of course suburban Munich isn't really the place for us to test such theories, but we follow Geiger's man to a predetermined location, and he doesn't worry about such things. So we get a firsthand look of the Camaro SS spiking violently sideways off each stoplight as massive 22-inch rear Pirelli P Zero Corsas try and fail to contain the 488 pound-feet of torque. That's more than the Mercedes and way more than the BMW, if you're counting.
Which makes Geiger's estimated 0-60 mph time of 3.7 seconds to 60 mph sound perfectly reasonable, if you hook it up right. We have to wait for a dusting of snow to clear the road before we head out, and spend a very dull morning taking static shots in the company parking lot. But when I finally get behind the wheel, engage first on that tractor of a gearbox, and give the throttle an almighty shove I know one thing -- this car is properly, seriously fast.
The supercharger provides linear thrust, so there shouldn't be a spike in the torque curve and technically there isn't, but now you have to truly measure the throttle input or even those grippy Italian tires stand no chance. Once they start to spin there's little the traction control can do about it in sub-zero conditions.
The Eaton Gen VI TVS 2300 rotors are the same as those found under the hood of the Corvette ZR1, but Edelbrock fit longer, 12-inch runners to maximize the low end torque. There's also a cast aluminum tensioner, dual bar and plate intercoolers, extruded aluminum fuel rails, 52 lb-hr fuel injectors, steel idler pulleys, a high-flow air filter, and a color-coded aluminum engine cover. It's a beautifully engineered piece of kit, and Edelbrock's website is full of testimonials of individuals doing the install themselves.
It also comes with the kind of boost you feel just about everywhere, and while nobody talks much about top-end speeds because of the variation between cars, Geiger reckons on about 180 mph with the limiter removed.
That is brutally fast, and the Camaro's surprisingly slippery drag coefficient of 0.37 has only been slightly affected by Geiger's add-on parts, which you can order from the German base. The front and rear lip spoilers, side skirts, and diffuser won't make a huge difference to the high-speed grip in the real world, because it's not a track car and driving fast enough to exploit these additions will land you in jail, but they give the Camaro SS that added touch of menace on the aesthetic front.
Continued at http://www.motortrend.com/roadtests/...ive/index.html
Old 03-29-2011, 11:03 AM   #2
GEEo
OKCamaros
GEEo's Avatar
Drives: 4 banger Diesel
I like that rear diffuser.
The color is awesome!!
Old 03-29-2011, 11:06 AM   #3
c-dub
It's that guy
c-dub's Avatar
Drives: 2011 SIM SS/RS
sweet! I like that last interior shot, what unit is that?
We mortals are but shadows and dust.
c-dub is offline   Reply With Quote
Old 03-29-2011, 11:08 AM   #4
mondain
Drives: toyota
Estimated price $48,000 USD?
Damn.
mondain is offline   Reply With Quote
Old 03-29-2011, 11:12 AM   #5
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Good looking car .. I was hoping they would have real numbers for this beast
Crowley
Crowley is offline   Reply With Quote
Old 03-29-2011, 11:19 AM   #6
armysig
Catch me if you can
armysig's Avatar
Drives: 2012 IOM ZL-1
Why did they have to go all the way to Germany to test drive a Supercharged Camaro? There are plenty of performance builders here in the U.S. that can and do provide the same or better modifications.
If you ask me MT just wasted a lot of money to go and play in another country. What they really should have done is pick one of the fine builders here, and showcase their talents.
armysig is offline   Reply With Quote
Old 03-29-2011, 11:24 AM   #7
toesuf94
toesuf94's Avatar
Drives: THR #11 E-force supercharged
Send a message via MSN to toesuf94
Tractor of a gearbox...really? Does Motor Trend have to Bitch about something every time it writes about GM cars? This is why they do not get my money any more.
Suprisingly they failed to mention the Cimarron when comparing a US brand car competing against Mercedes and BMW this time. Odd.
Cars and women are both going to give you problems...but you can pay somebody else to fix your car!
toesuf94 is offline   Reply With Quote
Old 03-29-2011, 11:41 AM   #8
blakechase
blakechase's Avatar
Drives: White 2010 Camaro 2LT RS
Send a message via AIM to blakechase
too sick, i want to do the navi like that.. it looks so clean
blakechase is offline   Reply With Quote
Old 03-29-2011, 11:48 AM   #9
Joseph.Hernandez
Drives: Got 5-6 till I get my 2011
That car is bad. The navi looks sick
Joseph.Hernandez is offline   Reply With Quote
Old 03-29-2011, 12:12 PM   #10
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
nickelodian slime green looks good, minus the engine cover
Old 03-29-2011, 12:26 PM   #11
Sasquatch
C5 THAKILYETI
Sasquatch's Avatar
Drives: 2LTRS
has the corvette stripes (or viper stripes) that we were discussing in a recent thread.
engine bay looks nice.
Sasquatch is offline   Reply With Quote
Old 03-29-2011, 12:38 PM   #12
zora2mac8
Deano
zora2mac8's Avatar
Drives: Cyber Gray Metallic SS
LOVE ITTTTTT
Nessuno mi provoca essere senza punita!
HTML Code:
http://ny5thgen.com/ZORAMAC8%20Z.htm
zora2mac8 is offline   Reply With Quote
Old 03-29-2011, 12:40 PM   #13
SSLarry
Drives: 2SS LS3
I like the green.
I don't like the "Supercharged" vinyl on the side. You don't need to tell everyone you are supercharged... show them!
2010 CGM 2SS LS3, born: 4/10
SSLarry is offline   Reply With Quote
Old 03-29-2011, 12:43 PM   #14
Brianskeet
Brianskeet
Brianskeet's Avatar
Drives: RJTC 1SS RS L99
Sweet ride but Motor dread needs to kiss off with that tractor comment.
ARH 1 7/8 coated LT, High flows, Corsa L99 exhaust, Vmax CNC throttle body, Elite Engineering catch can and tunnel brace, C.A.I. Apex Washer relocation and scoop, Janetty Tune, MSD wires, DEI heat shields, RB rotors and pads, Mike the powder coater calipers, pedders lines, Forgestar F14's, Gorilla nutz, MTI spoiler finished by Gary, Gary's Customz Bow Ties, Side Markers and Tails tinted, Bezels matte black, Badges deleted, Windows Tinted, AAC DRL P13W lights, AAC tinted LED reverse lights, AAC LED interior lights, RPI match painted DRL Bezels, Lis plate frame, Lloyds mats
Brianskeet is offline   Reply With Quote
