Old 04-20-2011, 01:19 PM   #1
Nvincent4708
Drives: N/A
Hot Rod Magazine Camaro Article
In the June 2011 Edition of the HotRod Magazine there is an article
"Got a '10-'11 Camaro? Here's What's Gonna Break"
For all of us doing mods..I think this is a copy we should pick up. Some good stuff.
I would post the article, but I have a feeling it's copyright infringement...(ADDED LINK BELOW)
http://www.hotrod.com/techarticles/g...e/viewall.html
Nvincent4708 is offline   Reply With Quote
Old 04-20-2011, 01:46 PM   #2
TheHorse13
TheHorse13's Avatar
Drives: 2011 Black SS M6
Any items you can list?
TheHorse13 is offline   Reply With Quote
Old 04-20-2011, 01:50 PM   #3
Smoky10
Drives: 2010 Camaro 2SS
I will be picking a copy up.
Smoky10 is offline   Reply With Quote
Old 04-20-2011, 01:52 PM   #4
Murph0408
Murph0408's Avatar
Drives: 2LT Black '10 Camaro, 2000 Durango
save me 5 bucks and start spillin the beans, OP
Murph0408 is offline   Reply With Quote
Old 04-20-2011, 01:56 PM   #5
Sawyer
Sawyer's Avatar
Drives: '13 5.0
Sawyer is offline   Reply With Quote
Old 04-20-2011, 02:19 PM   #6
Nvincent4708
Drives: N/A
[LS3]
Lifters (7000RPM) - Pump Up Issue
Timing Chain Tensioner (550HP) - Fails
Oiling (6500RPM) - Can't keep up
Rods (600HP) - Break
Head Gasket (600HP) - Fail
Pistons (600-625HP) - Fail (Detonation / excessive boost)
Crank (900HP) - Good until this point
Exhaust Valves(10PSI) -Fail
Fuel System (450HP) - Can't keep up
[L99]
AFM (450HP, High Lift / RPM) - Delete and convert to conventional
Valves (high lift) - Float, Replace
[Both]
Rockers(high lift) - Fail (Bearings Explode)
Balancer (Cam/RPM) - Explodes
[TR6060]
Main Shaft(Stock+HP) - Output Shaft Failure (This is known of..Recalled too)
Rear Support Bearing(650-680hp) - Fails
Synchro Rings (525-625) - Failure
Clutch (600) - Fails
[4L80]
TCM(Any Mods) - Recalibrate
Torque Management - Recalibrate PROPERLY
Torque Converter (500hp) - Can fail
[IRS / Driveshaft]
Suspension Flex(450hp) - Toe Arm Failure
Rear Subframe(475hp) - Flex, Use Subframe Bushings
Gears (500hp) - Fail
Halfshafts (500hp/Wheelhop) - Fail
Posi (Various) - Can Slip / Fail
Driveshaft (Over 5,000 DRIVESHAFT RPM) - Fail
I might just scan and post..depending how mad the moderators may get
Old 04-20-2011, 02:25 PM   #7
Jayson9
Drives: 2SS
Sounds like GM hit out of the park again!
Jayson9 is offline   Reply With Quote
Old 04-20-2011, 02:31 PM   #8
TheHorse13
TheHorse13's Avatar
I see that HotRod also did this for Dodge and the failures seem to line up very evenly. In other words, high horsepower may wear/break/explode stuff.
From this list and the one I saw for Dodge, nothing creeps out at me that says epic fail on the part of the manufacturer other than the known TSB items.
Thanks for hookin us up with the info!
Old 04-20-2011, 02:37 PM   #9
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
Whatever... how many vettes and camaros are pushing these motor's to 5-700hp with no problems. Most N/A cammed and bolt-on cars are running fine... is that a list of things that CAN happen, shure but anything can happen at anytime even on a bone stock engine! Hell look at old school engines, they had all kinds of weak points and were much worse off, but how many 1970 500+hp big blocks run the streets and track for years with stock bottom ends! Nothing like scaring people out of modding your car!
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 04-20-2011, 02:38 PM   #10
Nvincent4708
Drives: N/A
No problem, the article goes more into depth with solutions and such for these issues.
Old 04-20-2011, 02:40 PM   #11
Nvincent4708
Drives: N/A
Agreed, I just figured the users on the forum would like to know about this bit of information. I didn't intend to post it to scare, but to inform what may happen and what to possibly expect.
Old 04-20-2011, 02:41 PM   #12
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
If you are willing to spend the money on the engine to increase power, you had better be ready to spend money on ALL supporting systems. That is the price of performance. If not, go to either a ZL-1 or an aftermarket group that sells their higher HP cars with a warranty. (e.g. LPE, THR, Nickey, Berger, Hennessey, etc.)
Old 04-20-2011, 02:42 PM   #13
Bad70supreme
No flame on you man! Thats cool that they at lest show fixes for the issue's but they make it seem like mod your engine and expect it to break.
Old 04-20-2011, 02:49 PM   #14
DarkObsession
Drives: 2011 Camaro SS2/LS3
If that article is accurate, it sounds like a MUST READ for anyone modding their car.
Thanks for posting this info!
2011 Chevrolet Camaro SS2/LS3 - Pretty much bone stock (SLP SkipShift Eliminator, GTO clutch fluid reservoir mod) - 13.025 @ 110.492 MPH (12s?? )
1998 Pontiac Grand Prix GTP (retired) - Cam, exhaust, CAI, 12 PSI, tune - 13.465 @ 101.04 MPH
DarkObsession is offline   Reply With Quote
Transcript of Camaro ZL1 Q&A Webchat with Chevrolet Tran Camaro ZL1 Forum - ZL1 Specific Topics 42 12-22-2017 04:42 AM
PEDDERS SUCCESSFULLY FITS 305s ON ALL 4 CORNERS! Info@PeddersUSA.com Suspension / Brakes / Chassis 467 06-11-2013 09:45 PM
GT5 Camaro pics brantley847 Camaro Photos | Spyshots | Video | Media Gallery 93 05-27-2013 08:35 PM
Over 230 Satisfied 2010 Camaro Customers! Paddock Chevrolet has 40 in stock NOW camarojoe Dealer Camaros for Sale 2 05-24-2010 05:58 PM
The DEFINITIVE EXPLANATION OF CAMARO SUSPENSION, ISSUES, AND UPGRADES Info@PeddersUSA.com Suspension / Brakes / Chassis 106 10-19-2009 06:08 PM
