04-21-2011, 05:28 PM | #1 |
Drives: 2SS/RS CGM w/ black stripe Join Date: Apr 2011
Ported throttle body?
Sorry, im not very mechanically inclined. What is the benefit of a ported TB? Can you just port the stock one or is it an aftermarket part that comes ported?
04-21-2011, 05:39 PM | #2 |
knows 2 facts about ducks
You just port the stock one.
04-21-2011, 05:47 PM | #3 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
If you are skilled and know what you're doing, you can port your stock Throttle body. There's also companies/individuals that hand port intakes and throttle bodies and do a very good job.
Recently CNC (computer programmed porting) ported Throttle bodies have become popular. Several vendors in this forum sell them from around $150.00. The greatest benefit of a ported TB is increased throttle response. You can make a little HP, but the main benefit is increased throttle response. |
04-21-2011, 05:53 PM | #4 |
ok, so i could probably find someone in my area that could port my stock throttle body. You mentioned intake also. what benefit do you get from porting your intake? Is this benefit increased if i get an after market cold air intake?
04-21-2011, 05:58 PM | #5 |
right now its 100% stock.
04-21-2011, 05:59 PM | #6 |
I plan on putting a CAI intake on it very soon though.
04-21-2011, 09:20 PM | #7 |
Drives: 2SS/RS - Black - GFX Join Date: Nov 2008
where did 8-12 HP come from?
dynos? I think you may be mistaken... if so, please delete it. Some one may read it and believe it. if you can get 10 HP for a $150 mod... everyone would have one.
Ordered: 10-13-08
Built: 3-30-09 (#1691) Recieved: 6-12-09 Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods. |
04-21-2011, 11:20 PM | #8 |
Drives: '69 SS Convertible Join Date: May 2009
To the OP...just get a VMax TB. If you can do any basic mechanic stuff you can put it on yourself. Take off the air intake and four bolts. Easy even for a novice.
http://www.camaro5.com/forums/showthread.php?t=112536
Build Journal |
04-22-2011, 02:05 AM | #9 |
Thanks caverman, i read a couple of those threads on the vmax tb's. Im definately gonna have to get me one of those!
04-22-2011, 02:12 AM | #10 |
....if there's any in stock...
:: 20% tint on 3 sides 75% on windshield :: Vmax ported TB :: |
04-22-2011, 08:48 AM | #11 | |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
Caverman is correct. Nothing like it out there....one of the best bangs for the buck and no tune needed. |
04-22-2011, 08:54 AM | #12 |
Check with SC2150, Mike Norris (I believe was another seller), or Jannetty Racing. I'm sure you can find one through one of these guys.
Even if you have to wait a little it will be worth it. IMO I don't see how a human can port an polish a TB consistent everytime like a CNC machine can. Even if someone that hand ports them and does a good job most of the time doesn't mean you'll get one as good. Using a CNC machine you get a consistent porting job everytime. Just my .02 cents.....
Build Journal |
04-22-2011, 08:56 AM | #13 |
Drives: 2010 Camaro SS LS3 Join Date: Sep 2010
And I agree with both Caverman and SC2150. I am one of the biggest skeptics and found the VMax to be well worth the money.
She is only memory now. |
04-22-2011, 05:05 PM | #14 |
I have yet to see a dyno before and after on a 5th gen Camaro... so I am still a skeptic
Ordered: 10-13-08
Similar Threads | ||||
Airaid Throttle Body Spacer | JohnZ | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 15 | 02-05-2011 03:01 PM |
VMax CNC Throttle Body Dyno Test Data | Mike Norris | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 8 | 01-15-2011 08:28 AM |
DREV PROUD TO CARRY PORTED THROTTLE BODIES BY VMAX | JDRspeed2 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 14 | 11-21-2010 02:51 PM |
DREV PROUD TO CARRY PORTED THROTTLE BODIES BY VMAX | JDRspeed2 | V8 Bolt-Ons & Tunes | 3 | 11-20-2010 01:14 PM |
