Old 05-03-2011, 12:26 AM   #1
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
Question New timing chain tensioner necessary?
Thinking about putting an LS9 cam in my LS3. Can I just change over to the 3 bolt cam sprocket and leave the rest stock or do I really need to change the tensioner as well? Will the stock timing chain work fine? Thanks for your help.
Please don't reply with there are much better cams to go with. That's not my question.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 05-03-2011, 12:33 AM   #2
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
Personal preference. You'll be fine with either. I kept the stock slack adjuster on mine with a 3 bolt gear, works fine. GM's done it both styles of tensioner with a 3 bolt cam (LS9 vs LSA), doesn't make much a difference.
Ovenmitt is offline   Reply With Quote
Old 05-03-2011, 03:47 AM   #3
Irnwkrkev
Irnwkrkev's Avatar
Drives: 2011 SS/RS LS3
I've installed an LS9 cam in my '11 LS3. I went ahead and did the dampner as well. It has less parts.... I have seen threads detailing the stock tensioner coming apart. There is nothing more involved then removing the tensioner and installing the dampner. I believe you have to remove the oil pump to swap to the three bolt sprocket anyway. All that's required to re-install the oils pump is to pull the plugs, install the oil pump hand tight, spin the crank a couple of times to center the pump and torque it to specs. It's also a good time to install an underdrive pulley since you have to remove the pulley to remove the front cover. The LS9 cam is good for an easy 20hp and I didn't gain anything power wise with a custom tune. The tune was just beneficial for codes (installed cat delete pipes and 160* thermostat), calming the idle, and helped the afr at part throttle.
Irnwkrkev is offline   Reply With Quote
Old 05-03-2011, 04:40 AM   #4
steeleshark2
steeleshark2's Avatar
http://www.camaro5.com/forums/showth...=138223&page=9
Post #223
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 313 12-16-2023 06:53 PM
Timing belt or timing chain? tradosaurus Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 37 08-10-2012 07:21 PM
timing chain tensioner sspaul Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 25 12-30-2010 09:18 PM
Timing chain failures on LS3 vettes detroitboy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 15 04-12-2009 06:53 PM
VVT on the new Camaro Casull Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 19 04-01-2007 01:55 PM
