05-31-2011, 04:05 PM | #1 |
Russ
Seat belt riding on my neck, driver and passenger.
Do any of you have this problem with the seat belt? There is no up/down adjustment like in my other cars. Looking for any suggestions if anyone else is experiencing this like me. If no solution I will buy one of those pads that goes around the belt. I don't like the looks of them so I am hoping someone has a suggestion.
Russ |
05-31-2011, 04:06 PM | #2 |
Pro Hide n Seek Player
Drives: 2010 SS LS3/LSA 620whp/630tq Join Date: May 2009
theres a magnetic loop on the side of the seat that keeps it down... unless ur realllly short this should fix it.
620whp/630wtq. ADM LSA Conversion, E85, PFADT Tri-Y Headers into Borla S, PFADT Swaybars, Springs, Links, 20x10 20x11 Forgestar F14s, Lots of AAC |
05-31-2011, 04:07 PM | #3 |
Drives: 2010 SS Join Date: Apr 2011
Put it in the magnet hoop.
05-31-2011, 04:09 PM | #4 |
Drives: 04 Ram 2500 & 2010 Camaro 2SS/RS Join Date: Feb 2010
I fought the magnet hoop for almost a year (not sure why). Now that I'm using it I don't have this problem anymore.
05-31-2011, 04:15 PM | #5 |
Retarded One-Legged Owl
Drives: 2010 Black Camaro 2SS Join Date: Oct 2008
I fought the magnet hoop, and the magnet hoop won.
05-31-2011, 04:23 PM | #6 |
Ride this Chevy
Drives: 2010 RJT RS Camaro Join Date: May 2009
I too am too short for the loop/hoop but bought a clip thingie that works pretty well.
NFL OWNR I love the smell of new car in the morning!
05-31-2011, 05:16 PM | #7 |
NFRNO SS
Russ, this simple, inexpensive fix works for me. I can't take credit for it though, as another forum member first suggested it.
Get two pieces of 1"- 1 1/2" wide nylon straps, about 6 1/2" long. If you have any left-over camera, binocular or duffle bag straps these work great, or buy it cheaply where any material is sold. Next you put a hole in each end, big enough to fit over the metal snap and magnet. Heat the edges of the holes to keep the nylon from fraying. Wrap it around the belt, snap the magnet button over it, and go! I used a 1" wide strap, to keep it fairly hidden under the seat belt. Also, I tried several different lengths, and determined 6 1/2" is the shortest you can make it, and still have the seat belt slide smoothly inside the loop. Before The strap and how it installs After the mod Last edited by R Kern; 05-31-2011 at 05:31 PM. |
05-31-2011, 05:28 PM | #8 |
el Ruco
Drives: 2010 Camaro SS (now runnin' TENS ) Join Date: Nov 2009
The magnetic loop works fine, IF YA' DON'T REACH BACK AND UP TO PULL THE BELT AROUND YA'. Reach the belt at chest level with either hand and pull it horizontally across yourself to clip it inta' place.
I had a miserable time, too, with the belt pullin' outa' the loop when I reached up to grab its end. It' hella easy, if ya' remember to grab the belt LOW. |
05-31-2011, 06:47 PM | #9 |
Russ
I do use the magnetic strap but the seat belts still ride on my neck. I'm 5'9" so not really short.
rkern- thanks for taking the time to taking pics of your setup. I'm going to use your method to see how it works. Thanks again. Russ |
05-31-2011, 07:51 PM | #10 | |
I have the same problem, 5'8 and it's on my neck. I have gotten used to it. I am going to try a phone book to get me a little higher. |
05-31-2011, 08:39 PM | #11 |
TRI COUNTY TAMPA
Drives: 2011 1SS/RS VR/BLK A6 Join Date: Jan 2011
It all just depends on the person and seating position. If i recline my seat somewhat it rubs on my neck and i'm 6ft. If i put the seat up straight it doesn't.
05-31-2011, 09:43 PM | #12 |
Cracker
Drives: 2010 2LT/RS Summit White/Beige Join Date: May 2010
I'm 5'1" and I use something similar to this. Found them at Pepboys, 2 pack.
/end thread
2010 Camaro | 2LT | RS | Summit White | Beige Interior | Born: 5/10/10 | Purchased 5/28/10
05-31-2011, 09:58 PM | #13 |
:chevy:
Drives: 2LT/RS Join Date: Jun 2008
unless im wearing a hoody, or a golf shirt, this gets sooo damn annoying
CAMARO
Consult your doctor before taking Camaro Side effects include Sudden increase in Heart Rate, Insomnia and occasional hallucinations If you experience Permagrin exceeding 4 hours after taking Camaro, seek immediate Camaro5 Help CAMARO Bringing excitment back into the Garage |
06-01-2011, 01:30 AM | #14 |
Drives: 2010 2SS/RS.. her name is "Lucille" Join Date: Apr 2010
I had the same problem. I ended up getting seatbelt extensions from the dealer.
(I think they are 6-8" extensions) They are free from the dealer, if you ask for them. My Dealership had to order them, but they helped tremendously. |
Similar Threads | ||||
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) | robertway | Camaro DIY & HOW-TO instructions & discussions | 313 | 12-16-2023 06:53 PM |
Add HUD to your 2010 | 2SSRS@Gen5diy | Camaro DIY & HOW-TO instructions & discussions | 1993 | 03-30-2019 08:02 AM |
Squeak from drivers seat or console? | klondike | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 23 | 02-28-2018 01:00 AM |
Passenger seat modification ? | Mzodarg | 5th Gen Camaro SS LS LT General Discussions | 175 | 10-14-2010 07:13 AM |
SQUEAK/BIRD CHIRP SOUND IN DRIVERS SEAT!!!!! | klondike | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 10 | 08-25-2010 12:51 PM |
