| Wheels and Tires Talk Sponsored by The Tire Rack Discuss issues related to wheels and tires |
Thread Tools |
Quit being a pu$$y
Ginger lost 66 lbs with new running shoes! 18" Forgestar F14
Cliff notes: Went from stock 20" wheels to 18" Forgestar F14s and lost 66 lbs of rotational mass.
I wanted much smaller wheels/tires for my car because they would be lighter, which improves acceleration, braking, handling, and the smaller diameter will also act like a small gear change. Drove it around today and OH MY GOD! It feels like a completely different car. It literally feels hundreds of lbs lighter. You know how you have a full car of friends driving around getting on it and then you drop everyone off and you can feel all the dead weight gone? That is exactly what the car feels like. I know a lot of people will not dig the tiny front tire look, but my rear street tires I will be ordering are 27.3" tall so I wanted a smaller front and these are 26.7" tall. I used to daily drive a 98 SS with big and littles (skinnies on the front and big slicks out back) so I am used to this look, but these front tires still handle and stop decent. I think the next set of fronts I buy will definitely be the 255/45 size. I don't like how this tire looks like it has a little stretch to it and is a bit to short. Long story: So just a little over 4 months ago I ordered some 18x8.5/18x11 set of matte black Forgestar F14 wheels after seeing this thread http://www.camaro5.com/forums/showthread.php?t=125456. I have always been a drag racer so I the 18"x11" rears with Nitto NT05R 315/40 18 were a no brainer. For the front I wanted the lightest F14 and that was the 18"x8.5". Since the width of the front was very close to stock I chose the stock front offset of 35mm. or the rears i researched, researched, researched and did a TON of measuring and mocking up to try to get the right offset. I don't like how some rear wheels stick out and I wanted mine to tuck in as much as safely possible. I ended up choosing a 48 mm offset for the rear. It sits EXACTLY where I want it to, flush with the fender and about an inch of clearance between the tire and the inner fender well. There was a couple problems. One was that the lower control arm rubs on tight turns (so it will rub on hard launches also) much like the 17" forged Weld wheel fiasco. Not a big deal, I just clearanced the lower control arm and problem solved. The other problem is that I think they put the wrong finish on my wheels. I ordered matte black and when I opened them they look great but the finish looked really rough. I didn't think much of it until I found out Forgestar also has a finish called textured black. I found these pictures online and mine definitely looks like the textured one! They will be getting a phone call tomorrow morning. Matte black http://www.flickr.com/photos/nickels...ream/lightbox/ Textured black http://www.flickr.com/photos/nickels...ream/lightbox/ I waited 4 months for these wheels and I don't know if I want to go through the trouble of sending them back. On to the front tire dilemma. Since the Nitto 315/40 DR are 28" tall i decided to go with some Nitto 255/50 tires that are also 28" tall. I was thinking about going smaller on the front but could not find the right size in a Nitto. I had the tires put on and took a pic. Even thought the fronts and rears are both 28" tall for some reason the fronts just looked bigger to me and i didn't like it. I took the front wheels off and started looking for new tires. I decided to step down to 255/45 tires that were 27" tall. I remember seeing600hp-lpe's car and I liked the way it looked with a 26.9" tall wheel/tire set up (http://www.camaro5.com/forums/showthread.php?t=76884). Before I ordered them online I went to check my local tire shop. They didn't have the 255/45 tire but they had a 245/45 at a ridiculously low price. They are only 26.7" tall but I really liked that they have the exact same sidewall as stock tires so I went for it. I have also decided to not daily drive the drag radials, with a 00 tread wear rating they are way too expensive to just wear them out going to the grocery store. I will probably order a set of 18"x10" rears, i already found a nice looking 295/40 tire with a 200 tread wear rating. If the DR last three times as long by not daily driving them it will pay for the extra rear street set up. Now for the weights. I measured them with my bathroom scale but I wasn't too confident in the results (it said I had lost 64 lbs) so I looked up all the weights of the wheels and tires. Wheel/tire weights stock front wheel 30.3 lbs stock rear wheel 32 lbs stock front tire 32 lbs stock rear tire 36 lbs Total: 260.6 lbs 18"x8.5" F14 19.5 lbs 245/45/18 tire 25 lbs 18"x11" F14 21.5 lbs 315/40/18 32 lbs Total 196 lbs 260.6 - 196 = 64.6 lbs. Plus add another pound or so for the roller skate weights that I cut off to clear the front wheels. For a grand total of about 66 lbs (37 lbs of that are off the front wheels!). The first pic is of the 28" fronts and the rest are of the 26.7" fronts. Cost of today's mods: $2,116.80 18x8.5/18x11 Forgestar F14 $1,299.00 Nitto NT05R drag radials (mounted and balanced) $617.80 off brand 245/45/18 (mounted and balanced) $150 Mounting, balancing, swapping sensors $50
OKCamaros
Drives: '13 WRX STi Join Date: Mar 2010
She looks sexy man!!
what are those skate exactly for? I have em on mine to. |
Quit being a pu$$y
Thanks, they are supposed to be weights to keep the brakes from squealing, I think. They don't work and most all replacement pads tont have them.
OKCamaros
oww their attached to the pads? didn't know that.
Thanks for the info man. Just curious why did you go with 18" instead of 20"? or this is just your race wheels? |
cool
#6 |
Quit being a pu$$y
I don't like big heavy SUV wheels on sports cars. The 18's with smaller tires look a little funny, but the car absolutely LOVES them! It feels so much better now.
#7 |
![]() Drives: 2011 1SS Join Date: Mar 2010
I like the look of the first picture with the taller 28" tire up front. Did your ABS or TC lights come on from running a 26" front and 28" rear? I thought two different diameters would affect wheel speed sensor readings.
#8 |
OKCamaros
I want some Bogarts on my car but dont want to loose the Rear Brembos.
#9 | |
Quit being a pu$$y
As far as the light, nope. The tire sizes are 26.7" and 28". That's a difference of 1.3" and the computer needs to see a wheel speed difference of 6% above a certain mph, by my calculations the difference is just under 5%. It is cutting it close with the drag radials, but the lights should not come on, especially when I switch over to my street rears. Maybe once my fronts are worn down a bit it might, but that would be a great excuse to buy the 255/45 tires.
#10 |
COTW: 12/13/10
Drives: '12 370Z, '69 Camaro coming soon! Join Date: Feb 2008
Those are one of my favorite wheels
just not a fan of the size
"Are you one of those boys who prefer cars to women? - I'm one of those boys that appreciates a fine body, regardless of the make." 2010 CAMARO SOLD! JOURNAL: http://www.camaro5.com/forums/showthread.php?t=119635 | FACEBOOK: http://www.facebook.com/taylor.ryan.apt | GRAPHIC DESIGN: www.aptdesigns.net |
#11 |
Quit being a pu$$y
So I was worried about driving on the drag radials and wearing them out while I am waiting for my street tires and figure out where I am going to order my next set of 18"x10"F14's when I see an awesome pic on the interwebs. I see my exact size street tires I ordered on an 18"x11" wheel and it looks pretty good, only the tiniest bit of stretch.
So what I am planning on doing is swapping the street tires to my current 18"x11" rears and then order a set of 18"x10" this way I don't have to worry about wearing out my DR just driving around. i don't mind waiting a while to go the track since it is hot as balls right now anyways. Woo Hoo I'm so excited! Here is the thread: http://www.thirdgen.org/techboard/wh...eels-saga.html ![]()
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 1969 & 2011 Camaro SS Join Date: Oct 2008
Could you post a close-up pic of the finish, maybe just one spoke section or lug area of the wheel? Just looking at those pics above, it appears to be matte black finish. Matte black has a mostly smooth finish/touch to it, just like any matte black paint. Textured looks more like a teflon type finish, bumpy and slick feeling.
Tony
#13 |
Xecofl Member
Drives: 2011 IOM LS, 2011 CGM LS Join Date: Oct 2010
Looking good my man.
#14 |
Banned
I hate short rims...but I have to say u wear them well. u r ride is hot...good move
#15 | |
Quit being a pu$$y
#16 |
user bann'd
Drives: Chevy SS Join Date: May 2009
I dig it!!
![]() Chantilly Lace, the 2011 Rockabilly Jukebox..ADM built..617rwhp, geared A6. |
#17 |
ZEUSS
Cool!
#18 |
Quit being a pu$$y
Here's the close up pic Tony. I think it looks like the textured ones in the link I posted.
#19 |
![]() Drives: 2010 2ss/rs, 2004 pontiac gto Join Date: May 2009
Lookin good! Can't wait to see it in person!
#20 |
Edscapade
Drives: 2011 SS Camaro Join Date: Jul 2010
Nice choice - looks real nice on your care! Thanks for sharing...
#21 |
I Wanna Go Faster!!
Drives: 2011 2SS Synergy Green M6 Join Date: Apr 2011
Anybody that switched to 18s confirm that their car is actually faster?
#22 |
COTW: 12/13/10
#23 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
Padre went from 12.85 @ 108.6 mph to 12.73 @ 109.9 mph when he switched to 18" wheels (this was using DA correction factor on the runs to make it valid). I shaved over .1 tenth switching to light weight 20" wheels. I'd probably shave another .1 if I dropped down to 18" wheels. Heavier wheels need more energy to get moving. Lighter wheels spin up faster which equals faster acceleration. Another important reason guys are switching to 18" wheels is so they can run 18" drag radials. You'll get a lot more traction off the line because 18" tires have more sidewall. That allows the tire to flex and grab (hook up).
#24 |
![]() Drives: 2010 SS M6 Join Date: Oct 2009
I bought the same wheels as the OP and definately noticed a big difference in acceleration. Like he said it felt like you had 2 people get out of the car.
TVS 2300 714RWHP 686RWTQ
JRE tuned |
#25 |
Former 5th Gen owner
Drives: 2012 IOM Grand Sport 4LT Join Date: Jun 2010
I'm confused a little.. Many people say how much faster it is and is very noticeable -- but, the times posted show 0.12 s diff and 1.3 MPH.. That's not what I'd call very noticeable. Now, if someone went say, 12.8 to 12.5 I'd call that noticeable, but not very.. I've been looking at options of different wheels/tires -- I like the idea of the smaller wheel, just don't know if I like the looks -- but, if I'm only looking at shaving off a tenth -- it's just not the money for me for a full set -- I wouldn't mind the 18s in a DR due to my blower, but for daily driving I don't think I'd notice that one bit.
2012 IOM Grand Sport 4LT Auto
| Thread Tools | |
| Forgestar Wheels at DV8 Motoring - 18s, 19s, 20s, 22s! | Nine Ball | Wheels / Tires | 684 | 06-16-2013 11:36 AM |
| Forgestar F14 22x9 & 22x10.5 Photos on Camaro SS | Nine Ball | Wheels and Tires Talk Sponsored by The Tire Rack | 39 | 08-06-2012 10:15 PM |
| Forgestar F14 Weights & Photos on SS | Nine Ball | Wheels and Tires Talk Sponsored by The Tire Rack | 36 | 07-05-2012 07:20 PM |
| NEW YEARS RESOLUTION WEIGHT LOSS THREAD | BeckyD@RodgersChevrolet | Off-topic Discussions | 2503 | 01-03-2012 02:57 PM |
| /// Forgestar F14 Wheel Specials! | Wheel Studio | Wheels / Tires | 48 | 11-19-2010 01:15 PM |
