07-05-2011, 01:34 AM | #1 |
Drives: 2011 Camaro Join Date: Jan 2011
High idle
My v6 camaro idles high when i start it for about 15 seconds, than returns to under 1k. Is this normal its been like this for a while but when it was brand new i dont exactlly remember if it was like this?
ANY HELP THANX?
2011 Camaro A6
Black n Yellow 03 H2 Hummer 2008 Chrysler 300 1967 Cadillac Calais aka Boss Hawg |
07-05-2011, 01:37 AM | #2 |
Drives: 2011 2LT/RS M6 IOM Join Date: Apr 2011
Since you live in a desert I'm going to go with..... It's 120+ outside and your car likes the fan on "high" for a bit to get that coolant temp down?
07-05-2011, 01:47 AM | #3 |
It's fine, every car does it; Unless the idle is over 2k, then you have a problem.
07-05-2011, 01:48 AM | #4 |
Don't ask to pop my hood!
Drives: it's loud....... Join Date: Jun 2011
mine does the same, just when its cold, the first morning starts, after that its fine, so if your starting it up first thing in the am? then its normal.
Limo tint rears, 35% sides | B&G lowering springs | BowTies Blacked out | Red Footwells|Dome Light|Kicker 500Watts-Amp-Kicker 12" Ported Sub=BOOM| Stillin Splitter |Pssst 100 shot| 13.36 @102.7 @LVMS | 2010. |
07-05-2011, 02:02 AM | #5 |
ok.
how bout anyone having a clicking noise that goes up with the rpm's sounds like maybe a belt or something under the engine. In park its a low click click click very lightly than when i give it gas it speeds up ???? doesent sound like an engine knock or anything real serious , but just an annoyance i have to turn radio down and listen with windows down in quiet environment to hear it. any thoughts ??
2011 Camaro A6
07-05-2011, 02:59 AM | #6 |
Drives: '10 RJT 2LT/RS, 02 Grand Am SE Join Date: Jul 2009
It's likely that you're just hearing the ticking from the high pressure fuel pump since we have a direct injection fuel system. This is normal and nothing to worry about at all.
07-05-2011, 03:14 AM | #7 |
Thanks guys appreciate you takin the time to comment. good luck in life .
ill let this thread die out now. if anything gets to the point of concern ill just hit up the ol dealership. peace
2011 Camaro A6
07-05-2011, 03:53 AM | #8 |
Drives: 2011 2SS/RS Join Date: May 2011
threads never die...they just go to rest...or it could be your lifters ticking?...lol
Built By Blu808
LG G6X3 Cam, UD Pully, Rotofab Intake. Dynatech LT's. Borla ATAK Catback. Full BMR bushings and suspension. |
07-05-2011, 04:10 AM | #9 |
lol . yeah or maybe the compresser housing bracket o-ring got loose from the high rpm's.
2011 Camaro A6
Similar Threads | ||||
High Wing Spoiler or Not? | RSm1thX | Cosmetics and Lighting Modification Discussions | 109 | 04-03-2013 05:36 PM |
SPEC Clutch/Flywheel Upgrades | Single & Twin Disc!! | AJ@ECSMotorsports | Transmission / Driveline | 21 | 11-13-2010 03:58 PM |
Unbeatble Prices on ACT / Fidanza / Hurst / Mishimoto / MTI / SLP / Spec / More | maperformance | Transmission / Driveline | 18 | 10-26-2010 02:16 PM |
Exhaust Mods - Videos - high pitched whirr? | JFR1 | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 13 | 09-15-2010 01:50 PM |
ROTORA BIG BRAKE KITS 4-12 PISTONS/ 15" & 16" ROTORS SPECIAL | ADKINS PERFORMANCE | Suspension / Chassis / Brakes | 0 | 08-03-2010 12:08 PM |
