Quit being a pu$$y
Ginger gets a Braille light weight race battery!
So I have a goal of reducing Ginger's weight without taking anything away from being able to daily driver. I was a little worried about this battery not holding up, since I always have my Ac on, stereo blasting and raise/lower my top multiple times everyday. I have had it on for almost a week now and it has been GREAT! It actually has a little more voltage than the stock battery. Keep in mind I also have the ASP under drive pulley so the alternator is spinning slower than stock and the battery still hold up great. Only think I don't do anymore is sit in the car with it off and lights/stereo on or operate the top.
Stock battery is about 44 lbs and this one is just under 15 lbs. I also removed the compressor/slime and styrofoam holder. So all together I lost about 36 lbs. I used some foam pads I had laying around to secure the battery in the stock location. Cost of Today's mod: $158.52 Braille 2015 15 lb battery $158.52 I just checked Ebay and found one for $130 shipped
Whats the cranking amps it is rated for?
Quit being a pu$$y
PCA is 1067, CA is 574 and CCA is 426. The stock battery says CCA 720.
They shipped it with a little hand written spec sheet that showed what my actual battery tested at. All the specs were higher than advertised, but I can't find it now. :( I live in Texas so I could go down on the CCA without a problem. They have bigger batteries with higher CCAs if you live in a colder climate. They offer a 6.6lb, 9lb, 11.5lb, 15lb, 17lb and 21lb battery. The 21lb actually has a higher CCA ratting than the stock battery, so it has more power and is still 23 lbs lighter. Here is the advertised specs. http://www.braillebattery.com/index....teries/b2015/#
That's quite impressive for a battery in such a small form factor.
I have an optima..not light, but it works. Last edited by Nvincent4708; 07-07-2011 at 12:17 PM. Reason: spelling |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Black Camaro 2SS/RS Join Date: Aug 2009
Wonder how long the Braille lasts?
My boyfriend don't mind it. |
#6 |
![]() Drives: 2011 Camaro 2LT RS, Red Jewel Join Date: Apr 2011
I was wondering the same thing. If the alternator ever quits, will that Braille last anywhere nearly as long as a standard battery?
Alternatively, how would it fare in cold conditions? (Or does that matter, anymore? I remember when I was a kid, people having problems because it was too cold and the battery wouldn't turn the car over.)
Still not quite done.
#7 |
Slow Turtle
On the list of things to do
#8 |
![]() Drives: 2011 Black Camaro Join Date: May 2011
I thought you were talking about a red head, pale skin, freckle kid!!
#9 | |
Quit being a pu$$y
#10 |
![]() Drives: 2011 Comp 6 Turbo Join Date: Oct 2009
Great product. Meet the USA rep at SEMA last year. I like all the options that they offer for batteries.
#11 |
![]() Drives: 2010 ss. 1990 RS the faster one. Join Date: Jan 2011
Alternator failures are not as common as they used to be.
#12 |
But when they do happen it's usually 2 a.m. halfway between Glenwood, AR and Idabel, OK on a cold, lonely night on a stretch of road that doesn't see ten cars in an hour during the day.
Oh wait. That was a timing belt failure. In 1999. But you see my point
"Christ, it's Aldo Nova again!"
#13 |
![]() Drives: just a car Join Date: Aug 2010
Ginger? is that your car or your girl?
#14 |
![]() Drives: 2010 2SS/RS L99 RJT/Black Join Date: Feb 2011
Can someone explain the difference from Cranking Amps (CA) and Cold Cranking Amps (CCA)? Technical specs page says 426 CCA and 574 CA for the B2015.
Is the stock battery 720 CA or CCA? |
| Tire Monitoring System | monevz28 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 7 | 11-22-2009 03:42 PM |
| Some Texas Lighting Laws | Mecha | USA - Texas | 5 | 10-20-2009 01:49 PM |
| EXTREMELY LIGHT WEIGHT WHEELS | COR Forged | Wheels and Tires Talk Sponsored by The Tire Rack | 30 | 10-18-2009 02:33 PM |
| Anyone??? 0-60, 1/4 time, & speed on stock SS 20" VS. 19" or 20" light weight wheels? | 2cnd chance | Dragstrip and Launch Techniques Discussion | 2 | 09-19-2009 05:57 PM |
