| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
Tri-County Camaros Tampa
Drives: 2011 Camaro 1SS/RS VR/BLK A6 Join Date: Jan 2011
Issue SOLVED strong MAF.
Lot's of threads have been made about MAF issues. I recently made a thread myself asking questions as to why my car has been so damn doggy and lagged lately. The general consensus was it's simply the HEAT here in FLA.
Being as i have lived here 10yrs and owned many sport / muscle cars here i wasn't buying it all. Maybe some loss of power yes but, not flat out lagged and dogging it like some Corolla. My car is bone stock other than 2 simple performance mods. Right after i bought the car i installed a CAI Inc. Made a nice difference in sound and throttle response. Later i wanted even better response so i bolted up a VMAX TB. It instantly made the car seem much quicker off the line or from a roll when i punched it. About 5 weeks after i installed the TB. The temps went up and slowly my torque, throttle response and overall power was being sapped big time. I did the fuse pull several times. Removed the CAI and TB cleaned and replaced with no change. I even swapped back to my stock TB to see if that was the issue and no change. Finally i read on here about this strong MAF issue. I pulled mine out on Sunday and low and behold mine was a single letter Q. 2011 1SS Built DEC 2 , 2010. I emailed Chase and asked if he had a strong MAF i could buy and try to see if that resolved the issue. The new MAF arrived today and was in my mailbox when i got home at 5:30pm. I quickly removed my old MAF and lined it up with the new one and took photos of them together. Contrary to what i have read in other threads you cannot tell a difference between mine and the new one. Font is identical, arrow and everything. Chase sent me a K16 MAF. I installed on a hot car i just got home from driving 20 miles in 90+ degree heat. Had to use gloves so i wouldn't get burned to a crisp from the hoses and tubes as i have to remove them to get my MAF off due to my radiator shroud. I started up the car and took of down the road. I floored it from a stop, smoked them and was gone like a rocket. Punched it from a 30MPH roll and was instant response and gone again. Did it in both D and S mode. Repeated this several times and all i can say is WOW. 95% of my power is instantly back with virtually zero lag. I will buy a little performance hit from the HEAT but, this simply proves to me that it isn't all the heat. The consensus now is the old MAF was fine with only the CAI. After adding the TB the old MAF couldn't handle both mods and was the problem. Here are the photos of my old "weak" sensor and the new "strong" sensor side by side. Big thanks to Chase and APEX for once again delivering super fast exactly what i needed. Primo vendor. |
Gearhead
Drives: 2010 2SS/RS L99 Join Date: Oct 2010
Nice.
I can't read it... what's the ID number on the original? |
"VIRTUAL MEMBER"
Drives: 2010 Camaro SS/RS 6spd Join Date: Sep 2009
The original one looks like it has a Q on it!!!! Mine has an M!!!!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 imperial blue SS, black 92 RS Join Date: Apr 2011
Ok, so now I'm confused. What should I look for? I'll run outside in a lil while and take mine out and snap some pics.
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires.
2000 1500 silverado extra cab |
"Black Ace"
Drives: 2SS/RS black/black Join Date: Aug 2008
Mine was a "T." I can't say if I noticed a difference when I changed mine though.
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Maggie TVS 2300 SC, Spinmonster cam (230/234, .613/.598, 114+1) installed & dyno tuned by Lashway Motorsports, Richmond 4.10 gears, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane differential & cradle bushings; UMI trailing arms & toe rods. 568 rwhp/493 rwtq (conservative mustang dyno, 5 lbs. [bleeding] boost). |
#6 |
All numbers and letters on both MAF sensors are identical. As is the font , font size and arrows. The only difference is mine was a "Q" And the new one is a "K16"
The numbers are a little dark on the upper MAF in the fourth picture but, if you look close you can see them and they are the same as the new one. |
#7 | |
See my first photo. the bottom MAF the new one has a K16 in the little indented window. The old MAF i had only had a Q in it. You want any combination of a letter and two numbers. A single letter is apparently a weak sensor. I validated this issue today as described above and my car now runs better than new again with loads better throttle response. |
#8 |
![]() Drives: it like I stole it. Join Date: Feb 2010
Dave, thanks for your order and the shout out. I am glad your issue was straightened out.
The only way to visually tell the difference is by checking the indent windows like in the picture below. The unit on top is the original MAF and only has a Q. A single letter only indicates a "weak" sensor. The unit in the bottom of the photo is the one we sent him and it is labeled K16. Any letter followed by a number indicates a "strong" MAF.
#9 |
Theres a tread on this that covers it all. I have a weak MAF and have been thinking it was ok because I didnt have a lot of mods, intake and Vmax,. Im thinking I might have to look into this again. Theres a guy I think at GM parts , Cris , who will sell you a good MAF. Im just remembering this. Ill have to check the thread.
1SS/RS ,LS3, Volant Intake, VMax TB, Hurst Shifter
#10 |
![]() Drives: 2010 2ss black with silver stripes Join Date: Jul 2010
sorry in advance guys but, help me out here. I have a cai, headers and full aftermarket catback with a jannetty custom tune. If I find that I have the "weak" maf, would I need to be concerned with having my tune adjusted? If it makes such a difference, what is going on here? Is it timing that changes that makes the car run different?
K/N cai, borla "s" type catback, XSPOWER 1 7/8" LT headers, Jannetty tuned, blacked out bowties, aac abl dome/trunk led's, matching footwells. custom dash plaque, Hurst Harddrive shifter plate, and e-brake boot, custom SS kickplates ![]() ![]() |
#11 |
![]() Drives: 2010 Camaro 2SS - Black on Black Join Date: Aug 2010
Just changed mine as well...had the same original one as the OP "Q" and replaced it with a strong one labeled "K16" also. I also installed a CAI today and I can tell a BIG difference. I obviously cant say how much the MAF is doing but the combination of them both is a very noticable difference in throttle response and sound!
#12 |
Ok, so is the gm part number different?
#13 |
![]() Drives: 2010 1SS/RS Imperial Blue Metallic Join Date: Sep 2010
ApexChase: can you tell me or PM the price on a strong MAF. Thanks
#14 |
Yea me too
#15 |
![]() Drives: 2011 2ss Rs LS3 manual in black Join Date: Jul 2010
#16 |
Ok, I went pulled it out, had one letter in the spot described. Weak one?
#17 |
i Can't really see it very clear but in the second photo upper left inside the indented part there is a flat spot with either just 1 big letter in it or a smaller letter and numbers. If you only have just one letter than yes it is a "weak" one. I have heard from others and from my cars experience as well that it won't matter until you start adding on some mods that change the airflow through it like i did with a CAI and a TB. My weak one worked fine with only the CAI. after adding the TB as well then it went downhill. New stronger MAF corrected my issues.
#18 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 ZL1 - #670 Join Date: Jun 2009
Thanks
#19 |
www.Camaro5Fest.net
My tuner swapped mine out last week while it was at the shop... I just tossed the old one in the trunk and just now took a look at it... K12 damn... he swapped out a good one..
Anyone want to buy a slightly used Strong MAF for 50 bucks...
#20 |
![]() Drives: 1SS Camaro Join Date: Sep 2010
If you're trying to sell it, I'd refrain from using words like "tossed".. These things are pretty delicate.
CAI Cold Air Intake, VMax CNC TB, Borla Sport Catback Exhaust, EE Oil Catch Can, Eibach Sway Bars and Drop Springs, AAC concept side markers, stealth signal bulbs, Heritage grille, Sparks Restorations front and rear modern SS emblems
#21 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS M6 Join Date: May 2011
The GM part number is the same for both. Thats why you need to talk to Apex or PatrickT because it's verified before it goes out. Just got mine in the mail today even though I didn't notice any sluggishness after my CAI intall.
If it helps the packaging was AC Delco. So whoever the other supplier is is the one that sucks. AC Delco part # 213-4222 GM part # 15865791 |
#22 | |
#23 | |
Sounds a bit like the issues i was having. It still had all the top speed just had more trouble getting there. It was bogging down when i'd give it good throttle. Couldn't smoke em anymore and just seemed like it would labor too much. I really noticed when i'd get on it from a dead stop i'd go and sorta bog down a bit then i'd go some more then it would bog down again then pick up. The new MAF solved the problem right out of the gate. You could be having the same problem i was having. Not sure about tuned cars but, pretty sure tune or not if the MAF is not compensating properly it wouldn't matter either way and still exhibit these issues. |
#24 | |
Doug Thorley Tri-Y LT/cat back, Ported TB, Halltech CAI, Pedders sways, endlinks, Drop Springs, Tuned by TandTPerformance 371HP/383TQ
#25 |
Out of respect for a vendor and a fellow business owner. I will refrain from stating what i paid for the item as it may no longer be available at that price. I couldn't say honestly. I will say though to all it isn't a real expensive part.
I'm sure if you PM any of the vendors on here that sell them they would be happy to shoot you a price or direct you to where you can get one. |
| Thread Tools | |
| Dealership Screw Up - Clearcoat Issue | FDNY-L107 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 12 | 04-26-2011 10:52 AM |
| window indexing issue | TripleB | 5th Gen Camaro SS LS LT General Discussions | 9 | 03-20-2011 11:19 AM |
| Sequential Tail Light Issue | 40again | Cosmetics and Lighting Modification Discussions | 5 | 03-17-2011 01:33 AM |
| Please Think before you post | 35th02ss | Off-topic Discussions | 35 | 08-02-2009 09:38 AM |
| Bumleb's Camaro battery cable issue is almost Fixed, Issue Solved | Bumleb | 5th Gen Camaro SS LS LT General Discussions | 118 | 05-14-2009 11:04 PM |
