Old 08-09-2011, 10:49 PM   #1
overhaulengines
overhaulengines's Avatar
Drives: Red 2SS/RS M6
DIY 3D carbon fender vents installed
break out the grinder, man long time since sweetness has been under the knife, ok, what i have here are the 3Dcarbon fender vents, i really like these, very well made, easy to prep, painted very easy, instruction and template are perfect. i started with a extra fender i had, fit is super.
Its so easy a girl can do it , thats my daughter
Got these awesome vents from BilletAnything
Get them here http://www.camaro5.com/forums/showthread.php?t=145450
Update 8-10-11, got the first one in, total time 1 hr 45 min, if you can handle a die grinder or air saw, your in, no problem. dang if my daughter can cut, why cant you, its as easy as it looks. i should be able to knock off 20 min of the other side. again really really easy install, once cut is done, i filed the edges smooth, put some zinc primer on the exposed metal, clean the paint around the edges with alcohal, put on the supplied adhesion promoter. put the double sided tape on the vent and bam, done.... Now since i have vertical doors, i have a very slight clearance issue, but its because my door is slightly in compared to the fender, so i will adjust the doors out a bit to make sure they are even and that should fix the problem. i will do the other tomorrow
lupe
overhaulengines is offline   Reply With Quote
Old 08-09-2011, 10:49 PM   #2
overhaulengines
extra place holder
lupe
Old 08-10-2011, 12:47 PM   #3
BumbleBeeSS2009
BumbleBeeSS2009's Avatar
Drives: Rally Yellow 2SS/RS
Looks sweet Lupe!!
#52325 Delivered 11/07/2009
BumbleBeeSS2009 is offline   Reply With Quote
Old 08-10-2011, 01:13 PM   #4
The Stig
knows 2 facts about ducks
The Stig's Avatar
looks awesome Lupe, so two questions. Could we buy these vents through you already painted? Second, is this something that we DIY guys would be able to do?
Click to view my build thread
Old 08-10-2011, 02:14 PM   #5
overhaulengines
Originally Posted by BumbleBeeSS2009 View Post
Looks sweet Lupe!!
thanks
hey bro, i could paint them for you, i will be updating the DIY as i go, i might start cutting tonight. is it easy you ask? well look at the pics, its so easy a girl can do it ,....all kidding aside, if you can use a die grinder, thats it, the template is perfect, make the cut, smooth edges, seal edge's, then with 3M double sided tape it goes in. i will probably add some addition seal along the seam on the inside. here are some pics they (3D carbon) sent me.
lupe
Old 08-10-2011, 08:53 PM   #6
overhaulengines
1st post update
lupe
Old 08-10-2011, 09:29 PM   #7
C4
ERNEST
C4's Avatar
Drives: 2012CAMARO 1LT RS CONVERTIBLE
nice....
i will be ordering mine soon.
i will need your help bro.
C4 is offline   Reply With Quote
Old 08-10-2011, 10:28 PM   #8
SummoneR
Paul
SummoneR's Avatar
Dang Lupe!!! That looks GREAT!!!! I can't wait to get mine.
Old 08-11-2011, 10:24 AM   #9
PIANOMN
Epic; Winning!
PIANOMN's Avatar
Drives: 2010 1SS ABM
Looks good!!
1SS ABM LS3
Lots of parts from SouthwestSpeed... Thanks Ivan!!
PIANOMN is offline   Reply With Quote
Old 08-11-2011, 10:17 PM   #10
overhaulengines
3d carbon fender vents installation
Originally Posted by C4 View Post
nice....
lol, hey ernest, you need more than just my help
thanks paul,
Originally Posted by PIANOMN View Post
Looks good!!
thanks,
hey friends, these vents look killer, great quality, billetanything is awesome to work with, easy to install 3 hrs
lupe
Old 08-12-2011, 09:18 AM   #11
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
Looks great Lupe, the template comes with it? And did you paint it or have someone else do it. I see they look like ABS plastic, did you put a clear coat on them too?
=Stephens= is offline   Reply With Quote
Old 08-12-2011, 09:32 AM   #12
overhaulengines
hello, comes with template, its full proof, it line up with the cars line and the edge of the door. sooooo simple a girl can do it , ( my daughter) lol, and i painted it and clear coated it
comes with
vents
mesh
template
double sided tape
instructions
adhesive promoter
does not come with
painted vents, you have to get painted.
die grinder and air reciprocating saw
lupe
Old 08-12-2011, 09:35 AM   #13
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
..for a minute there, I thought you were a Mustang fan..
Old 08-12-2011, 09:49 AM   #14
overhaulengines
ohhhh you dont even know how close i was to buying a mustang lol
lupe
Camaro Heritage Grill DIY install (now with official GM install instructions). vuduman67 Camaro DIY & HOW-TO instructions & discussions 216 12-03-2014 05:18 PM
All New 3d Carbon Body Styling Kits !! Unique Auto Depot Exterior Parts & Accessories 181 12-16-2011 01:21 PM
Carbon Fiber Cowl Hood, Trunk, and more! PHASTEK Peformance Sean@Phastek Exterior Parts & Accessories 3 01-29-2010 02:44 PM
