JUICEDMOTORSPORTS
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Exterior Parts & Accessories
Old 09-28-2011, 03:19 PM   #1
CFD
Drives: 2SS/RS L99 BLACK
Billet Coil Mounts and billet coil covers,new from CFD
Hi all, These are billet coil mounts I designed for my car. They are much cleaner looking than the stock stamped steel units. Makes for an easy swap and cleans up the top of the valve covers, allowing for more air flow and makes the valve covers visable allowing them to be painted, powdercoated etc..
They work with all the stock wiring
These will be offered as a kit with all necessary hardware for a simple, quick installation.
The photos below, are of the prototypes in my car, it is clear how much cleaner they are, combine this with the heater hose re-location and the engine area starts to clean up nicely.
CFD is offline   Reply With Quote
Old 09-29-2011, 10:02 AM   #2
CFD
Here is a quick phone shot with the valve covers side by side. Hopefully by days end I will have a picture of mine with valve covers powdercoated later today.
Old 09-29-2011, 05:47 PM   #3
CFD
Here are a few shots of the coil mounts finished, valve covers in black and installed.
Old 09-29-2011, 06:12 PM   #4
kmcd
1,425 hp / supercharged
kmcd's Avatar
Drives: (2010 2SS/L99) (1999 Corvette)
Those look good. Now we need a billet plenum cover to match.
"If it's too loud...well, you know the rest."
kmcd is offline   Reply With Quote
Old 10-14-2011, 10:03 AM   #5
CFD
Finally had a chance ti finish up a few sets of coil mounts. These will come unfinished for those wanting to paint. Other finish options may be available on request. Feature billet aluminum with stainless steel hardware. Simply unbolt the existing coil mounts and swap the coils with these brackets, they really clean up this area of the motor without purchasing new valve covers.
If anyone wants to try these I will be offering a few sets at a special introductory price. PM for details.
Old 11-11-2011, 09:59 AM   #6
CFD
Hi Kevin, whereas I have not written any instructions this will do for now, not that you will need them but will be usefull for others as well.
Revove stock coils and mounts.
Install coils on new brackets with provided button head allens and one spacer between coil and mount.
Revove the stock clip that holds the electrical connector and install on the new brackets
Install mounts on valve covers with provided socket head cap screws
You can now move the wiring to under the mount as in pics.
On the passenger side you can also move the harness that runs along the top of the coils towhere the heat shield is. You will see in the pics a group of ground wires bolted to the head. Remove this and you can lift the harness over the dipstick tube then reinstall.
Any questions feel free to call or ask.
One other thing I found, not all the coil wires are the same length, if any fit tight swap with one a little longer.
Old 11-17-2011, 12:44 PM   #7
kmcd
kmcd's Avatar
Finally installed my new victory-red billet mounts on the driver side. They went on easily and look great (much cleaner than the OEM bracket). I'm holding off on the passenger side while I try to decide whether or not to pull the valve covers and paint them black.
I can't really say I'm surprised at the quality and fitment. All of George's products are outstanding.
Old 11-17-2011, 03:17 PM   #8
CFD
Hi Kevin, Thanks for the kind words. Be sure to post up some pics when you finish it up.
Old 11-20-2011, 05:15 PM   #9
lsuguy
lsuguy's Avatar
Drives: 2011 2SS/RS
Are you offering these for sale, if so PM me with a price!
lsuguy is offline   Reply With Quote
Old 11-20-2011, 06:33 PM   #10
CFD
Yes, these are one of the products that I offer for sale.
PM sent
Old 05-06-2012, 08:44 AM   #11
CFD
Hi all. I had a chance to machine a few more sets of coil mounts. They are ready to finish in your choice of color/finish options. Shipping is about two days from time of order.
Old 07-01-2012, 07:14 PM   #12
CFD
I've got a few more sets of coil mounts ready to ship.
Old 09-16-2012, 08:19 AM   #13
CFD
Hi all. I've been making some of my other parts out of real carbon fiber plate. I am currently working on a set of coil mounts in Carbon Fiber. These are not wrapped or dipped but solid carbon fiber plate. I will post pics when they are done, most likely sometime mid week.
Old 05-27-2013, 07:22 AM   #14
CFD
Hi all.
I've been working on a set of two piece coil mounts. These are the same as the 1 piece design without the center section to hold the stock harness in place. You can clean up the wiring with no cutting or wiring changes other than re-routing. I am also working on a bracket/cover to hide and further secure the wiring. I will be machining a few sets this week. Here are a few shots of the drivers side installed.
TORQUE SOLUTION Billet Engine Mounts!! In stock! Special Camaro5 Price HERE! ImportImage Transmission / Driveline 21 11-06-2011 04:11 PM
CNC'd Billet Valve covers and coil covers Granatelli Engine Internals 4 03-14-2011 06:58 PM
Billet Custom Products LLC has released a NEW all billet valve cover kit for the 2010 Bruce at Billet Wash/Wax/Detailing and Cosmetic Maintenance Parts 0 10-10-2010 05:42 PM
Pfadt Engine Mounts installed, first and second impressions... robertway Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 03-03-2010 10:35 AM
