10-20-2011, 03:33 PM | #1 |
Drives: 2011 2SS RS L99 Join Date: Jan 2011
Question on traction control
I was playing with my traction control, in the rain. I noticed that the tires will spin for a few seconds before it kicks in. I actually got the ass end to kick out pretty good & the traction control never hit. I eased on the gas from a dead stop & it broke loose for like a good 2-3 seconds before the traction control burped. This is with all on, as when you start the car & don't mess with anything. I was just wondering if this is normal behavior for 5th gens, as my 4th gen, it was much more immediate.
10-20-2011, 03:38 PM | #2 |
love. my. car.
I've had a similar experience on wet asphalt, but I was sliding sideways and had already started counter steering before I felt stabilitrack apply the breaks. I had already let off the gas as well. All I had done was apply moderate throttle after a rolling start and the car almost immediately swung out about 30 degrees in the rear before I could react. But there was another time on dry pavement that I intentionally gave it too much gas and the car bogged down immediately as soon as I released the clutch.
10-20-2011, 04:41 PM | #3 |
Drives: 2010 camaro 2SS LS3 Join Date: Aug 2011
if you are fast you can actually correct for the tire slip before the traction control kicks in, but it is pretty quick. maybe one second at the most. it should never actually slide out the stabillitrac is really good on these
10-20-2011, 04:58 PM | #4 |
Drives: 2015 c7 Join Date: Nov 2009
ya i can get the tires to spin a little with it on.
10-20-2011, 05:21 PM | #5 |
Drives: GM Vehicles Join Date: Jun 2010
Hi SWAT, I can research this one for you to see just how soon the Traction Control and Stabilitrak systems should be kicking in on your vehicle. Just send me your VIN and I should have something back for you shortly.
Jeff Morris, Chevrolet Customer Service |
10-20-2011, 05:38 PM | #6 |
I wish that there were a way to disable it so that it never came back on again. I hate having to disable it every time that I start the car. With that being said, it should only slide out on you in the rain if you were trying to do it.
2014 1SS 1LE, bone stock for now.
10-20-2011, 05:41 PM | #7 | |
Official Lounge BAMF
that's one thing I never liked about 4th gens..... the TC does more harm than good.... depending on which one you have.... killing all power doesn't help . Glad mine has none at all |
10-23-2011, 02:51 PM | #8 | |
Thanks guys, sounds like my car is fine & this is how 5th gens are.
Similar Threads | ||||
2010 Camaro PCM Pin-out Description and Wire Colors (LS3 & L99) | raptor | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 14 | 06-02-2020 12:51 PM |
E85 TUNE RESULT!! | bmorecam | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 327 | 10-13-2011 06:22 PM |
CEL - P1682 | PSU SS | Tuning / Diagnostics -- engine and transmission | 4 | 09-29-2011 07:27 PM |
traction control plug | desiel | Camaro DIY & HOW-TO instructions & discussions | 6 | 05-13-2010 01:05 PM |
Transmission output shaft | hiller72 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 267 | 12-02-2009 08:39 PM |
