Wretched Motorsports
Camaro ZL1 Forum - ZL1 Specific Topics Camaro ZL1 specific topics
Old 11-08-2011, 04:23 PM   #1
1BADZL1
THE CAMARO KING
1BADZL1's Avatar
Drives: 2012 Camaro ZL1 on order #PZSD7S
Thumbs up New Camaro ZL1 Video Feature - Phase Four: Aerodynamic Testing
Featured on Camaro5 HOMEPAGE.
Here's the next feature video from Chevy explaining Phase Four of ZL1 testing - Aerodynamic Testing
The ZL1 was tested in the wind tunnel for about 100 hours! Some neat info about how the ZL1's aero parts all help improve aerodynamics - front splitter, hood extractors, tire dams, brake ducts, rocker sideskirts, and rear spoiler.
GM's press release on ZL1 aerodynamics:
Firmly Planted: Camaro ZL1 Designed for Downforce
DETROIT – With supercar levels of performance and technology, the 580-horsepower (432-kW) Camaro ZL1 can reach 170 mph (273 km/h) on the famed Nürburgring’s Nordschleife course in Germany. To maintain stability and steering response at that speed, the ZL1 features an aerodynamic design that generates downforce to press the tires against the track.
“The Camaro ZL1 lapped the Nürburgring in an incredible 7:41.27 seconds, which would not have been possible without work of our aerodynamics team,” said Al Oppenheiser, Camaro chief engineer. “The design of the ZL1 creates downforce like a race car, harnessing air pressure to press the tires against the track for extra grip and control at high speeds.”
Most production cars are designed with some lift at speed slip through the air for improved fuel economy. The Camaro LS and Camaro SS are no exceptions, enabling the Camaro LS to deliver 323 horsepower (241 kW) and up to 30 mpg on the highway.
Design for high-speed track capability takes in other considerations.
For the ZL1 – the fastest Camaro ever – the aerodynamics team set out to generate downforce for improved handing at speed while minimizing the amount of increased drag that could reduce fuel economy and the vehicle’s top speed. With the computer-assisted design recommendations, engineers tested full-scale clay models and full-size prototypes in the General Motors’ wind tunnel – shaping clay and trimming foam board by hand to affect changes and measure them immediately.
Outside of the aerodynamics laboratory, engineers tested the ZL1’s aero aids on GM’s Milford Road Course, other race tracks and the unique “rolling road” wind tunnel at the Auto Research Center in Indianapolis.
When the dust settled and the wind-tunnel blades came to a stop, the Camaro ZL1 produced 65 pounds of downforce at an equivalent 150 mph (241 km/h) – compared to 200 pounds of lift in a Camaro SS – which was offset by an increase of only 40 counts of additional aerodynamic drag.
“From the driver’s seat, the added downforce makes a huge change in the feel, and responsiveness of the ZL1 at high speeds,” said Oppenheiser. “One of the best examples of how aerodynamics improved the performance of the ZL1 is the ‘Fuchsröhre,’ or Foxhole at the Nürburgring. In the ZL1, you can take that sweeping left-hand corner flat-out in fifth gear – nearly 160 mph (257 km/h). That’s a great testament to the confidence-inspiring stability and control the aerodynamic design helps give the Camaro ZL1.”
Seven elements contribute to the downforce of the ZL1:
1. Front fascia – The front fascia channels air for engine and brake cooling. The lower opening is larger than in a Camaro SS, providing greater airflow to the engine’s intercooler heat exchanger. Even the grille “fins” were shaped for optimal airflow. The corners of the front fascia, too, were reshaped to minimize lift, while the brake-cooling ducts in the outer corners of the lower grille opening provide a direct, high-flow path to the brake rotors. Cooling the brakes helps extend their life, particularly n the race track.
2. Hood – The ZL1’s hood has a vented, carbon fiber insert, contributing to both engine cooling and aerodynamic downforce. With traditional sealed hoods, air trapped in the engine bay creates lift at the front axle. With the ZL1, the specially shaped vents draw air up through the engine bay – allowing a significant volume of air flow while keeping the front tires firmly connected to the pavement.
3. Front splitter – Instead of a traditional front air dam, the ZL1 incorporates a racing-style splitter to help create downforce. Unlike some competitors’ vehicles that come with an add-on splitter, the ZL1’s does not have to be installed at the track – it is installed at the factory, and is designed with enough ground clearance for all driving conditions.
4. Front tire deflectors – The deflectors push airflow around the rotating wheels and tires more efficiently, reducing lift and drag. And by using deflectors in place of a traditional air dam, the downforce is less sensitive to pitch changes, making the ZL1 feel more stable at high speeds.
5. Belly pans – The ZL1 has two of them: one beneath the engine cradle and one at the rear of the engine assembly, just in front of the transmission. Both extend the width of the chassis out to the wheelhouse opening, to minimize airflow turbulence under the car. NACA-style ducts are incorporated into the rear belly pan for transmission cooling.
6. Rocker panels – Although subtle in appearance, the carefully shaped rocker panels help reduce lift and drag, while also contributing to stability during high cross winds. They also provide stone protection with the ZL1’s wider tires.
7. Rear spoiler – One of the most dramatic aero enhancements comes with the ZL1’s rear spoiler, which contributes approximately 150 pounds of down force at the cost of only 1 count of drag. It is taller and wider than the Camaro SS spoiler and incorporates the center high-mounted stop lamp.
The Camaro ZL1 goes on sale later in 2012. A convertible model will also be offered for the 2013 model year, starting in the summer of 2012. Pricing will be announced later.
Name:  Screen Shot 2011-11-09 at 9.43.36 AM.jpg
http://www.chevrolet.com/camaro-zl1/#image4
And here are the previous Three Phase features:
Phase 1: Track-tuning the magnetic ride suspension
Phase 2: Refining launch performance
Phase 3: 24 Hours track endurance
2012 Camaro ZL1 Car Name: Bruce
ZL1, LSA, MN6/MG9, DSX, RTQ, VR,
Current Status:
2030
1000 Initial Order 11/11/2011 Chevyland
1100 Order accepted at dealer: 11/11/2011 - PZSD7S
2000 Order accepted by GM: 12/14/2011
3000 Accepted By Production Control: 00/00/2011 - TPW 00/00/2011
3100 Sequenced: 00/00/2011
3300 Scheduled For Production:0/0/2012
3400 Broadcast: 0/0/2012
3800 Produced: 0/0/2012
4000 Available To Ship: 0/0/2012
4200 Shipped: 0/0/2012
5000 Delivered To The Dealer: 0/0/2012
6000 Delivered To Customer:0/0/2012
1BADZL1 is offline   Reply With Quote
Old 11-08-2011, 04:31 PM   #2
sed34
Drives: waiting on ZL1
i'll give it some time. its not loading right now.
sed34 is offline   Reply With Quote
Old 11-08-2011, 04:48 PM   #3
'StangBlaster5000
'StangBlaster5000's Avatar
Drives: Waiting for the 2013 ZL1
Got to love TECHNOLOGY!
I just finished reading an article about how they used the wind tunnels to help create downforce in a Corvette to attempt to break the standing mile record. It really does make a LOT of difference.
'StangBlaster5000 is offline   Reply With Quote
Old 11-08-2011, 04:52 PM   #4
1BADZL1
THE CAMARO KING
1BADZL1's Avatar
yea it will be better once its on the tube.
Did not see it as yet.
Current Status:
2030
Old 11-08-2011, 04:53 PM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
SWEET!!! THANKS!!!
"...What IS true: We anticipated that this would happen - we are never finished - and yes, Ford DOES deserve to win now and then. To think that GM can come out with a car to make ford throw in the towel is simply foolhardy..." - fbodfather
Old 11-08-2011, 05:09 PM   #6
sed34
ok. it finally loaded. makes me want this car even more. you're right about youtube. I downloaded all of their stuff so far. can't wait for vid 4 to be up there in HD. YOINK!!
Old 11-08-2011, 05:12 PM   #7
lbls1
lbls1's Avatar
Drives: 2002 Camaro SS SOM; 2009 Malibu LT
Nice find Wiz!
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic
'09 Malibu LT Dark Gray Metallic
lbls1 is offline   Reply With Quote
Old 11-08-2011, 05:13 PM   #8
The Stig
I used to be Stieger....
The Stig's Avatar
Drives: a PBM camaro
pure awesome
Stieger's BLACK Build Thread thanks for the sig Russ
Old 11-08-2011, 05:15 PM   #9
R.I.P. jesserayjames
Drives: 2010 IOM 2SSRS
absolutely awesome
Old 11-08-2011, 05:17 PM   #10
wilmaya
wilmaya's Avatar
Drives: 1970 Chevelle SS396/496 and a ZL1
Now if I could only find one @ MSRP locally! I guess I'll wait for a 2013..
wilmaya is offline   Reply With Quote
Old 11-08-2011, 05:25 PM   #11
tmandoug1
Deep Sea
tmandoug1's Avatar
Nice, I am scheduling my high performance driving class as soon as order gets off 1102. I am a man, however I am not ashamed to admit that this has more power than I have ever put to the floor. Can't wait. Goota learn the heel toe to beat my buddies.
tmandoug1 is offline   Reply With Quote
Old 11-08-2011, 05:29 PM   #12
Rice Killer
Cooter
Rice Killer's Avatar
Drives: my wife crazy
Thanks for posting. Did you notice that this test model had the traditional dual stripes on the trunk? Just an observation...
#1451 - 2012 ZL1 - White, Black Wheels, Manual, Suede Package, and Exposed Hood Insert. Delivered on 6/20/12. Thanks to Jason from Symdon Motors in Evansville, WI.
Rice Killer is offline   Reply With Quote
Old 11-08-2011, 05:35 PM   #13
1BADZL1
THE CAMARO KING
1BADZL1's Avatar
give me 30 min on this.. I think i can speed up the process.
stay tuned for a youtube link..
Current Status:
2030
Old 11-08-2011, 05:37 PM   #14
Z4me
Z4me's Avatar
Drives: 2013 ZL1 IOM Vin #169
worked fine for me np at all smooth as silk. Was interesting to watch,
alot of effort went into building the ZL1.
<img src=http://www.camaro5.com/forums/image.php?type=sigpic&userid=36987&dateline=1334886195 border=0 alt= />
Z4me is offline   Reply With Quote
Old 11-08-2011, 05:39 PM   #15
Joebot8484
ZL1 # 1307
Joebot8484's Avatar
Sweet!
Click on my signature for my build thread
Joebot8484 is offline   Reply With Quote
Old 11-08-2011, 05:52 PM   #16
Scarrzz
Do Ya like my taillights?
Scarrzz's Avatar
Drives: Suzuki Hayabusa
Chills down spine - CHECK !
Good catch, KING.
__________________________________
................................................The Faithful are Watching.
Scarrzz is offline   Reply With Quote
Old 11-08-2011, 06:03 PM   #17
Blueclyde
Blueclyde's Avatar
Drives: 2012 ZL1
Every time I see one of these videos I keep thinking $$... Very cool though. They have a bunch of Engineering NRE to recover on this car. That will tranlsate into what we pay.
2012 ZL1, GBA, M6, ECF, Black 10 Spokes
Blueclyde is offline   Reply With Quote
Old 11-08-2011, 06:08 PM   #18
KLR ZL1
H-Town Camaro Club Member
KLR ZL1's Avatar
Drives: #708 Summit White ZL1 Del. 5/17
FREAKIN BADASS and it's in my color too.
Sometimes dreams do come true. #708
KLR ZL1 is offline   Reply With Quote
Old 11-08-2011, 06:47 PM   #19
Shurenuff
Shurenuff's Avatar
Drives: 2002 Nissan Altima
I love these videos.
Chevy is doing a hell of a job making and marketing this car for the enthusiast.
Factory Badassery
Shurenuff is offline   Reply With Quote
Old 11-08-2011, 06:54 PM   #20
OldScoolCamaro
ZL1 177 Pilot
OldScoolCamaro's Avatar
Drives: 2012 ZL1, 1973 Z-28
...and the beat goes on...
Old 11-08-2011, 07:21 PM   #21
s1k0
s1k0's Avatar
Drives: 2012 2LT/RS Camaro
The holy Grail.
....Oh yeah and A CIA Inc.
s1k0 is offline   Reply With Quote
Old 11-08-2011, 07:32 PM   #22
69NMYSS
69NMYSS's Avatar
Drives: '69 Camaro SS and '12 ZL1
blackonblack wants white? Or maybe one of each?
69NMYSS is offline   Reply With Quote
Old 11-08-2011, 08:26 PM   #23
1BADZL1
THE CAMARO KING
1BADZL1's Avatar
as long as chevy don't try to get me for copyright claims (can't squeeze blood out of a turnip) ill repost it so it will stream better. And if they do it can be just as easily removed.
Use it however you like. I am sure they won't mind as its basically the same thing. We can always remove it when they post it.
almost done.
Current Status:
2030
Old 11-08-2011, 09:13 PM   #24
OldJedi
Use the Force
OldJedi's Avatar
Drives: 1967 FI Corvette and CRT ZL1 #336
Send a message via AIM to OldJedi
Great Video! You can see all four videos at : www.chevrolet.com/camaro-zl1
Walk softly, carry a light saber and drive a ZL1!
OldJedi is offline   Reply With Quote
Old 11-08-2011, 10:46 PM   #25
fiascoes1
SoCalRaceTeam new-b!
fiascoes1's Avatar
Drives: 2012 ZL1/WHITE/BLACK STRIPE
nice to know how its going to look in white since i ordered white, i am now re assured i made the right choice
4B00- 2/16/12 vin 284 my build thread http://www.camaro5.com/forums/showthread.php?t=224028
fiascoes1 is offline   Reply With Quote
2012 camaro zl1, 2012 zl1, 2013 camaro zl1, 2013 zl1, camaro zl1, camaro zl1 forum, camaro zl1 forums, camaro zl1 video, camaro zl1 videos, zl1 forum, zl1 forums, zl1 video, zl1 videos
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
