Vivid Superchips
V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) Driveshafts | Differentials | Gears | Rearends | Clutch | Shifters
Old 11-10-2011, 10:34 AM   #1
MTI Racing Kevin
MTI Racing Kevin's Avatar
Drives: 2010 Camaro
Attention High HP Camaros New Polyurethane Transmission Mount
MTI Racing Polyurethane Transmission Mount
Fits 2010 2011 2012 Camaro V8
Part Number 206001
If you are doing any hardcore drag racing, road racing or high performance street driving you need the MTI Racing Polyurethane Transmission Mount. This polyurethane transmission mount will give you a better feel for what is going on in the drivetrain while keeping the transmission where it belongs. Less drivetrain movement equals more power to the ground.
When you add more horsepower to the vehicle, more stress is placed on the drivetrain. The drivetrain starts moving around because the soft rubber mounts get deformed, and ultimately, FAIL.
Solution:
Replace your transmission mount with the MTI Racing Polyurethane Transmission Mount
The MTI Racing Polyurethane Transmission Mount is a direct bolt-in. There are no modifications needed to install. Simply unbolt the old limpy mount, and replace with with the MTI mount.
The polyurethane mount holds shape better than rubber. Less flexing of the material means more energy delivered to the rear wheels for acceleration. This will allow you to launch harder off the line with less transmission movement. It also helps maintain proper pinion angle by controlling the movement of the transmission.
Solid mounts are just too noisy. This mount provides the proper amount of stiffness without the vibration or noise. Also, the material is long lasting. It will not decay due to oil or heat exposure.
FEATURES AND BENEFITS:
• Direct Bolt-In
• No modification to install
• Less driveline movement
• High-Strength Material
• Enables harder launches
Pricing Thread here :http://www.camaro5.com/forums/showthread.php?t=181620
MTI Racing Kevin is offline   Reply With Quote
Old 11-15-2011, 11:19 AM   #2
MTI Racing Kevin
Drives: 2010 Camaro
In stock with FREE SHIPPING.
MTI Racing
1190 Hayes Industrial Dr
Marietta, GA 30062
Kevin Esposito
770-919-7774
Old 11-16-2011, 12:23 PM   #3
55Designs
Drives: 2010
cool so who here is gonna step up and try this guy out?
55Designs is offline   Reply With Quote
Old 11-18-2011, 02:46 PM   #4
55Designs
Drives: 2010
Well everyone we have one on the way and I will test it fully and report back with our feedback and any changes we noticed from this upgrade. Stay tuned.
Old 11-18-2011, 03:18 PM   #5
MJ
MJ's Avatar
Drives: 2010 Camaro SS/RS
I have the polyurathane motor mounts. It really minimized engine movement over the viscous damped stockers. Looking at the stock trans mounts, I'm wondering how much movement there is during hard acel/decel & hard launching. Anyone want to stick a camera down there and pull a couple of 5K launches, haha. (If I had the camera, I'd actually do this!)
MJ is offline   Reply With Quote
Old 11-18-2011, 03:28 PM   #6
DandD
DandD's Avatar
Drives: 2010 2SS and 2011 LS
I have one on the way, it will go on in the spring to coincide with the Tick Performance level 2 rebuild on my TR-6060.
Dan
Around here we like baseball, hot dogs, apple pie, and Chevrolet
DandD is offline   Reply With Quote
Old 11-18-2011, 04:09 PM   #7
55Designs
Drives: 2010
MJ we did stick a gopro under the car last year. It does move enough under very high loads at when shifting and accelerating. I want to to try this mount to see if it keeps the driveshaft angle put without jumping around much. we do not have any more gopro lost them on the road as they fell out from under the car.
i just hope it doesnt transmit vibrations and stuff into the car then it will have to come off.
Old 11-29-2011, 09:43 PM   #8
MJ
MJ's Avatar
Hey Kevin, I received the trans mounts last Friday and plan to install tomorrow. Need to know what the torque spec is for the fasteners... I don't have access to shop manual. I sent a PM to you and email to MTI customer support asking for the specs but haven't heard back yet (figured you guys were busy).
Old 11-30-2011, 12:28 AM   #9
Merc
COTW 12/5/11
Merc's Avatar
Drives: 2010 Camaro 2SSRS IOM
MTI Racing Polyurethane Transmission Mount[/URL]
Part Number 206001
If you are doing any hardcore drag racing, road racing or high performance street driving you need the MTI Racing Polyurethane Transmission Mount[/URL]. This polyurethane transmission mount will give you a better feel for what is going on in the drivetrain while keeping the transmission where it belongs. Less drivetrain movement equals more power to the ground.
Solution:
Replace your transmission mount with the MTI Racing Polyurethane Transmission Mount.[/URL]
The MTI Racing Polyurethane Transmission Mount [/URL]is a direct bolt-in. There are no modifications needed to install. Simply unbolt the old limpy mount, and replace with with the MTI mount.
• Direct Bolt-In
On My shopping list, PM me details.
Old 11-30-2011, 12:43 PM   #10
FDNY-L107
FDNY-L107's Avatar
Drives: 2011 Camaro LS V6
Any chance in hell that a V6 mount is in the works? Just the simple upgrade and less driveline movement alone is worth it. I hope you guys will consider the V6 application.
Black 2011 Camaro LS M6
- Nitro Dave's NOS Plate System - 100 shot
- Hochkis Front & Rear Comp Sway Bars & End Links, SS Struts & Shocks, Eibach Springs
- BMR Sub-Frame & Tunnel Brace, BMR Rear Toe Rods, Rear Control Arms, GM Strut Bar Brace
- BBK LT Headers w/Kook's 2.5" Cat-Back Exhaust
- Forgeline DE3S Wheels NT05 Tires
- RS 4-gauge pod/RS leather console lid, Leather Steering Wheel, MTI Shifter
- Cold Air Induction CAI w/VMAX Ported TB & Ported+Powdercoated Intake Manifold, SLP UD Pulley, RX Catch can & Breather, RX Black-Iceolator, Port-matched heads
- Braille 17 Battery
- Trifecta Tune
FDNY-L107 is offline   Reply With Quote
Old 12-09-2011, 03:26 PM   #11
MTI Racing
MTI Racing's Avatar
MJ - PM was sent.
MTI Racing is offline   Reply With Quote
Old 12-09-2011, 03:31 PM   #12
DandD
DandD's Avatar
Does this mount work with both auto and manual trans cars?
Old 12-12-2011, 09:14 AM   #13
MTI Racing
MTI Racing's Avatar
I fits only the Manual.
Old 12-23-2011, 08:28 AM   #14
IDEALG
"Chevy" rumbles best
IDEALG's Avatar
Drives: 2011 2SS/RS 6 speed
Send a message via AIM to IDEALG
anyone going to come out with better rear end mounts??
IDEALG is offline   Reply With Quote
Old 01-03-2012, 01:54 PM   #15
MJ
MJ's Avatar
MTI Trans mount - some feedback...
Installed MTI polyurathane trans mount 2 weeks ago. Stock rubber mount is very loose and allows for a lot of movement - too much in my opinion - when running higher hp levels. MTI mount is beefier with thick strip of polyurathane. Didn't notice any increase in noise or vibration at idle or part throttle. Did notice some increase in vibration during hard acceleration but nothing that I'd consider to be an issue. I'm also running Prothane motor mounts.
Old 01-13-2012, 11:17 AM   #16
MTI Racing Kevin
Drives: 2010 Camaro
I have these mounts in stock and ready to ship.
Old 01-13-2012, 11:43 PM   #17
lakers67
Drives: Camaro 2SS
Is the automatic version in the works?
lakers67 is offline   Reply With Quote
Old 01-16-2012, 04:54 PM   #19
lakers67
Drives: Camaro 2SS
I've actually have all those products you just recommended! So are you saying I dont need a Poly trans mount?
Old 01-17-2012, 05:22 PM   #20
MTI Racing
MTI Racing's Avatar
Everyone can improve the trans mount. I was just giving suggestions on other ways to improve.
Hope that helps!
-Stephen
Old 03-07-2012, 07:32 PM   #21
DandD
DandD's Avatar
Ok the weather is finally breaking here and I got my car back with one of the items installed being the polyurethane trans mount. I've only got just over 300 miles on it since getting the car back, but the trans mount is great, no more movement of the trans at all unlike with the stock mount. Noise and vibrations are a non issue. Count me as a very satisfied customer, thanks Stephen!
Dan
Old 03-07-2012, 09:15 PM   #22
mstanford.us
Mark Stanford
Drives: Black 2010 SS LS3
Seems like this would mate up well with semi-solid motor mounts and semi solid rear diff mounts. I'm having the latter installed next week. JRE prepped 3.91 diff. Pfadt has totally solid motor mounts, the only motor mounts I've seen so far. Seems like semi solid might be a little more forgiving. I've seen this description before and it definitely peaked my interest.
Mark Stanford
2010 1SS M6 456rwhp, 418 torque
www.Midwestracing.net
CAI Inc, Kooks 1 7/8" 3"catted + mufflers, Livernois stage 2B cam (230/240, .591"/.608" int/exh), Custom Dyno Tune, Libertyville Chevrolet (IL) by Kevin Paddock, Nitto NT05R P315/35R20 on 20X10 American Racing Torque thrust rims, BMR trailing & toe rods. Centerforce DF clutch.
mstanford.us is offline   Reply With Quote
Old 03-08-2012, 08:13 AM   #23
MTI Racing
MTI Racing's Avatar
You are welcome Dan!
Availability is good. We have stock ready to ship!
Old 03-08-2012, 07:08 PM   #24
Crime2
Got Boost?
Crime2's Avatar
Drives: 2010 1SS RS
Are you still doing the free shipping on this? I was on he site and it wants $16.20 for ground shipping. If you still are doing the free shipping I will be in for one.
Crime2 is offline   Reply With Quote
Old 03-09-2012, 09:27 AM   #25
MTI Racing Kevin
Drives: 2010 Camaro
I adjusted the online parameters. Now FREE shipping for the lower 48 states!!
New Camo shots of a Camaro bballr4567 Camaro ZL1 Forum - ZL1 Specific Topics 150 02-18-2010 12:13 PM
