Old 11-18-2011, 10:41 PM   #1
jlauber588
jlauber588's Avatar
Drives: 2010 camaro
Oil breather install help
So I got a catchcan and breather for my v6 camaro and the directions were lacking on how/where the oil breather goes. Does anyone know how to install the breather on a stock engine with still stock air intake. Any pics would also help. Thanks
Sent from my DROID BIONIC using Tapatalk
jlauber588 is offline   Reply With Quote
Old 11-18-2011, 10:51 PM   #2
mhog
mhog's Avatar
Drives: 2010 V6 Camaro 2LT/RS
The breather replaces your oil fil cap.
mhog is offline   Reply With Quote
Old 11-18-2011, 11:06 PM   #3
SIXJAK
SIXJAK's Avatar
Drives: MO's only SC'd LLT.
yeah what he said and make sure to plug the breather nipple on your intake as well as the breather port in back of the motor (driver side). Good luck.
IPF supercharger kit, IPF tune, SW LT's, R. Tech HFC's, ARK DT-S catback, SS Brembo brake upgrade, BC Racing adjustable coilovers, Hurst STS, Pfadt rear arm package, Pfadt adjustable sways & end links, Pfadt diff bushings, BMR rear cradle full kit blk bezels,SS diffuser, Innovate gauges.
SIXJAK is offline   Reply With Quote
Old 11-19-2011, 09:46 AM   #4
SC2150
Is it a RX Products flow controlled checkvalved unit? If not you may need a tune to prevent a CEL due to the unmetered/un-restriced air entering w/out the MAF metering it. If you need help PM your email & I can email you the instructions that include what to cap off.
Old 11-19-2011, 02:10 PM   #5
GoldCartridgeGamer
GoldCartridgeGamer's Avatar
Drives: 2014 Ford SVT Raptor SuperCrew
Uh....I just replaced my oil cap with the breather when I bought it with my catch can. I have the stock intake. Was I supposed to do something too?
Phoenix (sold)
How to hug your camaro
Buy the car that you would most like to get beat in. The other guy will always be faster.
GoldCartridgeGamer is offline   Reply With Quote
Old 11-19-2011, 09:18 PM   #6
SC2150
Yes. If using a breather you need to delete the fresh air line and cap the unused nipples or you will have your fuel trims going crazy from the unmetered air (log and watch them).
Old 11-20-2011, 12:21 AM   #7
GoldCartridgeGamer
Oh....opps. Is there a HowTo for this? How can I check my fuel trims? I don't have a way to log it. Much appreciated!
Phoenix (sold)
Old 11-21-2011, 09:29 PM   #8
GoldCartridgeGamer
Anyone have a HowTo to do this properly? Please and thank you!
Phoenix (sold)
Old 11-21-2011, 09:50 PM   #9
hunterv6
Always bet on Black
hunterv6's Avatar
Drives: 2011 turbo LS, 2012 f 150,
I think I also installed my rx breather wrong didn't know I need to cap the fresh air line
<font color=#0066cc>http://www.camaro5.com/forums/showthread.php?t=283263</font>
hunterv6 is offline   Reply With Quote
Old 11-22-2011, 09:01 AM   #10
SC2150
Checkvalved Breather
NOTE: For the V8 If installing the optional breather you must cap off the nipple on the front inner side of the passenger valve cover and eliminate the hose to the airbridge and cap that end off as well to prevent unmetered air from entering the system.
Make sure to apply some oil to the O-ring to aid in removal!!
On the V6, The tube that runs from the CAI (or stock airbox) to the rear of the drivers side valve cover needs to be deleted and both fittings capped.
Old 11-22-2011, 09:06 AM   #11
hunterv6
Always bet on Black
hunterv6's Avatar
thanks had mine on wrong for months i alway wonder where the two caps went.
Old 11-24-2011, 11:50 PM   #12
jlauber588
jlauber588's Avatar
Drives: 2010 camaro
Does anyone have a pic of the stock intake after the breather install on the drivers side?
Old 11-25-2011, 12:21 AM   #13
GoldCartridgeGamer
I too would like to see this. It would help.
Phoenix (sold)
Old 11-25-2011, 12:18 PM   #14
camaro-21
camaro-21's Avatar
Drives: 2011 cyber grey metallic camaro v6
http://www.camaro5.com/forums/showthread.php?t=183477. If you go to this thread there are some pics
2011 camaro v6- sts turbo w/ meth injection, barton short throw, spec stage 3+ clutch, forgestar f-14 rims, Nitto invo tires, pfadt sway bars drop springs and end links, rx catch can, goodridge stainless steel brake lines, aac halos afterburner taillights and sidemarkers, sebon carbon rear diffuser.
camaro-21 is offline   Reply With Quote
A Look at GM's Oil Life Monitoring System franknbeans Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 168 08-07-2024 01:29 PM
Oil Catch Can Where to buy Pollock Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 19 05-01-2011 10:43 PM
ON STAR OIL Life % T_MECO Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 34 04-25-2010 08:55 PM
synthetic motor oil? bigd1276 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 71 01-29-2009 12:28 PM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 09:47 AM
