![]() Drives: 2011 Camaro Convertible SS Join Date: Nov 2011
Gains of throttle body porting vs 92-102mm???
I need some advice. I have heard a lot of talk about porting throttle bodies and aftermarket TBs. But unable to find direct comparisons of stock Vs Ported stock, stock vs. 92mm vs. 102mm.
Can anyone share Dyno charts or numbers on stock, Ported, 92mm, 102mm on a Supercharged 6.2l LS3? As a novice, are we talking just the valve/gate opening or actually increasing the TB assembly size? Bottom line, what Hp gain would I find on LS3 maggie if I had the TB Ported, or swap in a 92mm or a 102mm? Last edited by Smkymts; 11-19-2011 at 02:21 PM. |
![]() Drives: 2010 2SS/RS Join Date: Sep 2011
The 90mm is a huge restriction! at least for me! 7.0 TVS2300 maggie application, i have a 102mm TPIS throttle body being added to my set-up.
Most hated in NM....
Drives: Sold the 6POINT2, went to a 50THZ06 Join Date: Sep 2011
this is probably a very dumb question but.... with a 102mm TB, do you need a different intake tube or will any stock/ aftermarket CIA work?
#4 | |
Drives: First 9 inch-12 bolt IRS Camaro Join Date: Jun 2009
#5 | |
#6 |
I agree with hendrix! i have seen almost 3" of vacuum directly behind the tb on a 427 tvs 2300 on the engine dyno. bigger is better for me! I NEED the 102!
#7 |
Only drives on Sundays
Drives: '16 2SS A8 NPP MRC NGray Join Date: Feb 2011
Thomas, when you say "our TB" is it a NW or other brand, or yours? Just curious. I've got a NW 102 ready for my Procharger build with a FAST 102 LSR manifold. I'm a believer in doing both, though many repeat, "oh the 90mm is fine, it isn't a restriction." I'm thinking my D1 is going to love both.
Padre |
#8 | |
#9 | |
Padre |
#10 | |
Drives: 2011 Camaro SS/ 2016 Camaro SS Join Date: Jun 2009
On NA applications we see anywhere from 5-8 RWHP and RWTQ but the driveability is greatly improved. The power is much smoother and the throttle response is outstanding. Here is a back to back test we did with the VMAX on a bolt-on 2010 Camaro SS LS3. ![]() ![]() On a forced induction application I expect the numbers to be greater but until I test it is simply speculation. I will work on getting this testing done this week if possible and I'll post our results. Please feel free to call, email or PM me anytime with questions. Kind regards, Jordan Priestley 888.308.6007 |
#11 |
on a whipple its about 31 rwhp ... thats tested with the nick williams 102mm
#12 | |
FI test of VMAX TB
I only have 6 PSI with peak of 7. But I'll offer up my car as a ginnea pig for a discounted purchase. |
#13 |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
Guys, I hope to make this a little easier to understand.
At 6-8 PSI boost I would not expect anything in Peak Power but definitely more response. As you turn the blower faster Via Pulleys, Meaning More boost Air flow How ever you want to understand it, Eventually the 90mm TB becomes a Restriction. At that Point if you change to a 102mm You will see an increase in Power. The Faster your Turning the Blower the Bigger Gains you will see from this Change. The Slower you Turn the blower the Less gains will be seen It is Hard to put a Boost Number on it because Headers, Cams, Ported Heads, Cubic inches all affect Boost in relation to blower speed. I would Say on the Camaro if your Running Smaller than a 3.4 Pulley on a Maggie then you will see Gains. Those Gain will be larger as you go smaller on the pulley, or add an overdrive crank pulley or overdrive cog Pulley Etc. At 17 PSI boost we saw 35 RWHP on the Maggie. At 10 PSI boost on Cammed Headers, LS3 We saw 25 RWHP Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#14 |
Is this 102 mm TB a direct bolt for Maggy's?
| Larger Throttle Body | shines | Forced Induction - V8 | 39 | 09-08-2011 01:18 PM |
| WTB :Fast 102mm throttle body | ls3lsxz | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 1 | 08-28-2011 12:58 PM |
| Check out this 102MM Nitrous Throttle Body Being Machined! Video Inside! | Nick@BVI | Forced Induction - V8 | 1 | 04-09-2010 01:09 AM |
| Check out this 102MM Nitrous Throttle Body Being Machined! Video Inside! | Nick@BVI | Camaro Photos | Spyshots | Video | Media Gallery | 1 | 04-09-2010 12:35 AM |
| Best method to clean a throttle body on '99 Z | Broshot | 4th Generation Camaros | 5 | 07-20-2009 12:50 AM |
