Old 12-06-2011, 09:43 PM   #1
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
DIY: assembly and disassembly of the key fob
My key fob was having some problems... probably due to the amount of time I constantly flipping it out (playing with it).
However... you may also need this in a few years when one of the buttons won't press... or the flipping mechanism gets loose... or if you damage the shell and don't want to have a new key cut and programmed (put the internals in a new "shell").
It pretty easy. You only need a small screwdriver for carefully prying the shell apart.
First pop the battery cover off and pull the battery out. To do this put the key in the open position and your thumb in the space where the key was... and just pop it right off (I did this out of order, thats why the battery cover is still on there).
Then pry lightly on the top side of the key fob with your small flathead like so (mine was easy because it was already coming apart there).
EDIT: if the links die again... use this link: http://s601.photobucket.com/user/DBe...rary/Key%20Fob
Then do the same to the backside (next to the metal ring holder)... but slower this time to ease it off. You may be able to hold the remaining plastic part and push on the metal part.
When the front-face comes completely free from the back-face it will spin 2 revolutions from the spring force.
Then you can proceed to take out the key and the chip
Usually I would say... just do the disassembly in reverse for the assembly. But you need to put the spring force back into the key... don't worry it is easy.
-Put the push button back into the key (if you separated it from the key).
-Put the chip back in the front-face facing down.
-Put the key into its home in the "out" position
-Put the spring back into the push button (it will "seat" into a locked in position)
- put the back face onto the spring and make sure that the spring's little "foot" is in its home... this is what the foot looks like
you will be holding it like this...
spin the back-face in a counterclockwise rotation, that will spring the key outwards.
rotate it 2 full revolutions and snap it back on.
the rest is cake... just make sure you press it together hard enough so it clicks (finger pressure should do it).
I took mine apart and put it back together in about 5 minutes. Just doing this made the key fit in there much better (no more play). So hopefully I wont need to replace my shell.
But if you ever need to replace the shell... at least you wont be dropping $120 on a new cut key, dealer programing, and a couple of wasted hours at the stealership.
There are a couple places to get an uncut, unprogrammed key (for swapping the internals):
http://americankeysupply.com/index.p...oducts_id=1282
and without the remote start...
http://www.amazon.com/gp/product/B00...A3GM12XFXQPQFV
.... Or email PatrickT at GM Parts House (forum sponsor): patrick@gmpartshouse.com .... not sure how much they cost, but I think you can get one from him pre-cut.
Or you can get a used one on ebay for a couple dollars cheaper.
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 12-07-2011, 09:31 AM   #2
Camaro21
Drives: SOLD - 2013 M6 ZL1
Nice Write Up !!
Camaro21 is offline   Reply With Quote
Old 12-07-2011, 11:32 AM   #3
y2k king
y2k king's Avatar
Drives: 2011 ss camaro
thanks, it's in my maintenance folders now.
10/28/2010 got it
y2k king is offline   Reply With Quote
Old 12-07-2011, 01:58 PM   #4
HopeRidesAlone
HopeRidesAlone's Avatar
Drives: 2010 Camaro Black 2SS/RS
I belive their is a way to program them yourself as well
2010 Black 2LT/RS - Injen CAI, ARK DTS Catback Polished Tips, OBX LT Headers, Lowered on Eibach, 3/8 blackiceolator, Trifecta Tuned.- Totaled 3/10/13
2010 Black 2SS/RS - Stainless powers 1 7/8 LT headers, cold air inductions cai, Tuned by dynosteve, Feesler side skirt, Feesler Spoiler, Feesler carbon fiber bowties, H&R Lowering Springs.
HopeRidesAlone is offline   Reply With Quote
Old 12-07-2011, 10:42 PM   #5
Bell040
Bell040's Avatar
If anyone finds out that this is true... Please post.
Ordered: 10-13-08
Recieved: 6-12-09
Old 12-08-2011, 08:48 PM   #6
denny2188
denny2188's Avatar
Drives: 2011 IBM Camaro 2LT
you can put one of your origional keys in the ignition and turn to the on position, then remove it, put your new unprogrammed key in the same ignition and turn it to the on position and wait to hear it beep and display "third key remembered" or some thing like that on the center display. that is how I programmed my ordered key. works just like the one that came with my car.
denny2188 is offline   Reply With Quote
Old 12-13-2012, 11:07 AM   #7
amz
Factory Correct
amz's Avatar
Drives: 2011 2SS/RS
Nice write up and pics. I wondered what the inside looked like.
amz is offline   Reply With Quote
Old 12-13-2012, 12:50 PM   #8
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
But you'd need to have the blade (the part that you physically stick in the ignition) laser cut to match your other keys. That part you can't do yourself...
My VIN = 2G1FK1EJ9A9105017
Old 01-23-2013, 01:12 PM   #9
ryan's camaro
Taeng
ryan's camaro's Avatar
Drives: Fast
Anyone have the pictures to those dead links?
ryan's camaro is offline   Reply With Quote
Old 02-15-2013, 09:38 AM   #10
RDKLXPRS
Drives: 2010 RS
Where are the pictures?
Hi,
Where can I find the pictures? Would feel a whole lot better if I had some pictures to go with the text.
Thanks
RDKLXPRS is offline   Reply With Quote
Old 03-22-2013, 03:16 PM   #11
Bell040
Bell040's Avatar
Pics are back up
Ordered: 10-13-08
Recieved: 6-12-09
Old 03-27-2013, 11:13 PM   #12
Haole
2017 SS
Haole's Avatar
Drives: 2017 Summit White 2SS
I read the post on how to program a new key fob. I'm awaiting my new pre cut key fob and am wondering if that's all I need to do. Is put the old key in, turn to tge "on" position then remove and do the same with my brand new key?
Any other advice would be greatly welcomed. I should get new key by Friday.
Craig
Haole is offline   Reply With Quote
Old 03-28-2013, 11:52 AM   #13
Haole
2017 SS
Haole's Avatar
BUMP
Old 04-15-2013, 08:00 AM   #14
CamaroSkooter
And I'm curious how us non-locksmith's can buy anything from that American Key Supply website...
