Drives: 2014 Z51 Corvette Join Date: Apr 2011
To grease or not to grease?
I have a popping noise in my front end after the installation of Pfadt lowering springs.
I have read that the endlinks are a likely culprit. I am going to re check all the connections but should I use some heavy duty grease on them when I re tighten them? |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
Do not grease the endlinks on the threads. The factory endlinks are a sealed system and should not need relubrication. The first place we would look though is at the condition of the endlinks. If you're using our endlinks check and make sure they are assembled correctly according to our illustrations here: Pfadt Endlink Installation Guide
If you're still using the factory endlinks make sure that the endlink it's self isn't bent in any way, and the hardware is in good condition. Also pay close attention to when the car is actually making noise and under what condition you hear any sounds as that will help narrow down future troubleshooting steps. Shoot me an email to info@pfadtracing.com,send us a PM, or call us at 1-888-972-2464 with some more details of your noise and we can work with you on troubleshooting the issue! |
Thanks! I will give you a call.
Grease just attracts dirt and road grime. Make sure the springs are "Clocked" properly. If they are not they spring can rub on the bottom spring perch causing a noise.
![]() Drives: 1SS Summit White Join Date: Jun 2010
#6 |
![]() Drives: 2010 Camaro 2LT V6 Join Date: Jul 2009
I had a popping noise coming from the front of my car when i would turn and go over a shallow dip or into a driveway. But i bought the LSR front subframe brace and the noise stopped. It was only 60 bucks, worth it to me just for the noise and if it stiffens up the chasis that is just gravy.
Here's the link http://www.lsrperformance.com/chassi...vy-camaro.html
Injen CAI, V-Max Throttle Body, Rx 25mm Iceolator, Rx 10mm Plenum Spacer, Mace Ported Manifold, ARK N-II Catback, Trifecta Tune, Rx Catch Can.
BMR Bushing Inserts,Pedders Radius Rod Inserts, Pfadt Sway Bars and Endlinks, LSR Front Subframe Brace SS Brembo Brakes, Racing Brake Stainless Lines |
#7 |
Thanks Johnz!
#8 |
Drives: 2011 Camaro SS Join Date: Jun 2011
Let me know if I can get you a brace. Thanks for the props JohnZ
#9 |
#10 |
Are there any ill effects by just doing the front sub frame brace?
I was told not to upgrade just the front sway because it would throw off the rear. |
#11 | |
Adding chassis bracing won't have a huge effect on the overall balance of the car, so if you wanted to add some kind of brace that wouldn't hurt anything. |
| grease points | Cyber/Orange10 | Camaro DIY & HOW-TO instructions & discussions | 13 | 03-30-2012 07:48 AM |
| Lithium grease. | alssiri | Suspension / Brakes / Chassis | 18 | 07-14-2011 05:39 PM |
| GREASE ON INSIDE REAR WHEEL!!!! | Peter W. | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 6 | 03-29-2011 08:08 AM |
| BMR Trailing Arms Grease | oachalon | Suspension / Brakes / Chassis | 19 | 12-28-2010 02:20 PM |
| Grease and tar, etc | Tee304 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 9 | 04-28-2010 01:55 PM |
