Drives: 2011 CG 2SS Join Date: Oct 2009
How To Hook Your Forced Induction LS3 Power - ECS Turns to DSS, Pfadt, & Weld Racing
I have had this question raised numerous times to me; "Matt, I now have tremendous amount of power, but how do I get this thing to hook up?" . ECS has done a lot of investigating into this subject on our goal to reach the 9's stock bottom end with 18" drag radials in street-trim. We have come up with a great solution between The Driveshaft Shop & Pfadt Race Engineering. Coupled with the help from Jay over at Weld Racing, and our guys at M/T we can put this extreme power to the ground!
This build is based off of a 800 + rwhp, stock bottom end, 2010 Camaro. The customer turned to us for a great compliment of street items, but did not want to go overboard with every single bushing, and part made available. Working with Blair over at Pfadt, we were able to put together a nice package based off of the work we did on our project SS. This combination of the DSS, Pfadt, and Weld Racing will get the proper power to the tire, reliably and be able to hook on the street & drag strip situations. Give you some details on the vehicle: 2010 Camaro - LS3 Manual Transmission - ECS Base Supercharger Kit, Novi 1500 - ECS Alky Control Dual Methanol Kit - ARH 1 7/8" LTs with High-Flow Catted X-Pipe with Corsa Axle-Back - Pfadt Lowering Springs We are now adding the following: Pfadt Engineering: - Rear Control Arm Bushing Set - Sport Sway Bars (Front & Rear) - HD Endlink System - Trailing Arm Bushing Set - Adjustable Tie Rod Set The Driveshaft Shop: - 9" Conversion Kit - Aluminum Driveshaft - Strange S-Case, 3.70 Gear Set, True-Trac, 31 Spline Stubs Weld Racing RT-S71 Style LW Street Rims: - 18x8 Front Rims wrapped with Pirelli PZero 255/55/18 Tires - 18x10.5 Rear Rims wrapped with Mickey Thompson 305/45/18 Street II Drag Radials Lingenfelter: - LPE Dual Pump Electronic Fuel System ECS: - ECS Custom Line Lock Kit Due to the weather here, we are looking for some track results ASAP but most likely we will not get this down the strip until March. I am going to keep this thread updated with installation pictures and results!! |
Drives: 2011 SS/RS Join Date: May 2011
looks good mattSubscribed
USAF retired! Thank God!
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28 Join Date: Jul 2011
J.Sick
Drives: 2010 Camaro SS Join Date: Nov 2010
When you get the tires on those welds please weigh them.
"J.Sick"
2010 Camaro 2SS |
i def need some new tires and 18's to make mine hook better..and ive only got a cam haha
2011 2ss/RS Summit White / Grey and Black Interior. TSP VVT-2 Cam, ARH heads and Exhaust, CAI, Ported Throttle Body, Plasti Dipped tailight bezels and rims. AAC interior lighting. Tuned by East Coast Supercharging.
#6 |
![]() Drives: 2010 RS 2 SS Join Date: Aug 2009
#7 | |
![]() Drives: 2010 ss 1997 lt1 Join Date: Nov 2010
#8 |
Thanks guys !! Right now we are just finishing up the LPE dual pump installation, so tomorrow pictures shall resume.
#9 |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
Sweet project Matt! This should prove to be a really nice improvement with the power that your customer is putting down! Keep us updated on the progress!
#10 |
I have a question for you as i am getting the stage 5 kit,are there any substitutions that can be made to this kit to fit my need,s or perhaps adding to it for an all around better deal? Thank,s
#11 |
Drives: own more cars than i can list Join Date: Nov 2010
looing good, keep them coming
#12 |
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416 ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly ![]() |
#13 | |
Give me a call to discuss the package or a PM. I'll make sure you get the best deal from us on that package ! Last edited by Sales @ ECS; 01-27-2012 at 08:03 AM. |
#14 |
Here's some further pictures.. Did the proper cuts for the 9" conversion, so we now have the DSS 9" conversion installed, and most of the Pfadt parts installed on the cradle already. Putting it in the car in a few minutes!
| My Maggie install......... | PQ | Forced Induction - V8 | 1298 | 02-24-2014 11:03 PM |
| Modifying for " Dummies" | Dr Jkel | Tuning / Diagnostics -- engine and transmission | 209 | 06-18-2012 12:24 AM |
| Pfadt Lowering Spring & Swaybar Combo - BIG SALE - Available at MTI Racing | MTI Racing | Suspension / Chassis / Brakes | 0 | 02-08-2011 10:21 AM |
| PFADT Race Engineering - Drag Racing, Track or Street DD | CRUSHER2SS | Suspension / Brakes / Chassis | 4 | 10-27-2010 02:05 PM |
| LS3 engine specifications | Tran | Wiki | 3 | 10-06-2010 11:56 PM |
