| Camaro ZL1 Forum - ZL1 Specific Topics Camaro ZL1 specific topics |
Thread Tools |
Camaro Addiction
Drives: 68SS,81Z28,87IROC,97Z28SS, '12ZL1 Join Date: Dec 2009
ZL1 VIN discussion - 2G1FS1EP3C9800004
We previously discussed whether or not the ZL1's would have a specific VIN sequence. Since this is the first week of production, my VIN appears to indicate that this is the 4th ZL1 manufactured. Compared with existing 5th gen Camaro VIN's, does the VIN sequence appear to vary from existing Camaros?
2012 Camaro ZL1 VIN #0004 ZL1, Ashen Grey, Black Leather, 6 speed, suede, exposed carbon fiber weave, gray stripe Current Status: Cruisin' !! 3800 Produced: 1/27/2012 6000 Delivered To Customer: 4/27/2012 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: fanboys and ass kissers crazy. Join Date: May 2008
FBodfather has stated that they are going to have their own sequencing. The VIN which you have provided proves this as all other camaros have the number "1" in the position which you have the number "8". This is unusual as most models simply continue with the existing sequencing as was done with the SS, LT and 'verts.
Congrats if that's your VIN! Pretty cool!!!!
"BBOMG - More than just a car show.... It's an experience!" |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2006 Silverado SS, 2009 G8 GT Join Date: Aug 2008
How did you get your VIN? That is very cool!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Rev-It-Up for Wounded Warriors Join Date: Nov 2009
Congrats...............I figured the AG would be first to go into production...............
Camaro Addiction
The VIN was provided at gmconnects.com when my order reached 4104. When I entered the order number and status code of 4104 appeared, the VIN was just shown there with the status code. I didn't do anything special. How can I post a screen shot?
#6 |
![]() Drives: ZL1 Join Date: Dec 2011
copy and paste
while looking at GM connect press the prt sc--(print screen key) above backspace then open paint. Paste it to piant and save. name it what ever you want...
#7 |
Camaro Addiction
I got all the copy paste stuff. I just don't know how to post a quick pic directly into this blog. But I have plan B. Click on the link below to see the gmconnects.com order update status code 4104 example.
http://www.camaro5.com/forums/album....ictureid=72979
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 ZL1 - #670 Join Date: Jun 2009
That's awesome, Congrats !!!
#9 |
![]() Drives: 2012 Camaro ZL1 #353 Join Date: Aug 2011
WOAH!!! AWESOME!!!
#10 | |
Number 4.... that is impressive! |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 ZL1 Join Date: Feb 2009
Very Nice!! Awesomeness! Your order did not ever take a step backwards and you got it placed in December! Good Going! Very Sweet! Almost stressless!! s m o o t h !!
2012 CAMARO-ZL1
Sincere Thanks to City Chevrolet, Charlotte, NC Last edited by htron50; 01-28-2012 at 10:52 AM. |
#12 |
![]() Drives: chevy Join Date: Dec 2011
so fine
So fine , congrats to u
#13 |
OP, If you want to put that in your original post just right click, copy image address, go into edit post and click the little mountain under the undo button. Then paste.
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS/RS IBM Black Polished Join Date: Feb 2009
Congrats on the build from everyone at GMConnects. Larry
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
#15 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2002 Nissan Altima Join Date: Jul 2008
Congrats! I'm really interested to see what the gray stripe looks like with AGM.
Factory Badassery
#16 |
"vehicle is about to leave the property"
Damn. They just slapped it on its ass and sent it home!
2012 ZL1 #1092
Black on Black 10 spoke M6 ECF 8.6" lower pulley (no tune) 552 rwhp 05/22/2012 (6000) Vehicle delivered to customer. |
#17 | |
Factory Badassery
#18 |
I'm sure it will also. Still exciting nonetheless!
Factory Badassery
#19 |
#20 |
Camaro Addiction
The first ZL1's are bound to be bayed, inspected and re-inspected before "leaving the property." Chevrolet would probably like to avoid any negative press and in this day of instant public relations such as Camaro5.com, they must get it right the first time. I'm confident that will be the case. But baby, come to papa soon!!
Ode to ZL1 - I have the garage all setup for you which includes a lift, numerous Camaro 5th gen framed posters, custom metal signs that are painted and hung (including a bowtie with "ZL1" on top) and all of your Camaro older brothers - SS, Z28's and IROC look forward to meeting you. We'll tweak you a little bit, break you in then watch you get after those mustangs. Can you tell I'm a proud father? Heck, I need a ZL1 stork sign in the front yard of the shop!!
#21 | |
Your ninja edit skills were not fast enough grasshopper ![]() And you're not being negative, you're being realistic. Fbodfather did say that vehicles produced early would be gone over with a fine tooth comb and deliveries likely wouldn't start happening until sometime in March.
Factory Badassery
#22 |
ZL1 #140
Drives: Camaros: 68 SS, 10 2SS/RS, 12 ZL1 Join Date: Mar 2008
Congrats on number 4!!!
Did you order your ZL1 directly through Hennessey? |
#23 |
![]() Drives: 2012 ZL1 #272, 00 GTP, 00 Silverado Join Date: Nov 2011
CONGRATS........
YEP, They are going to keep them in the incubator as close to their birth FATHER (fbodfather that is) until they are ready to travel "home". By baby went back to 8 cm dilation this morning (3300) and almost ready to enter the muscle car era! Very EXCITING for sure! |
#24 | |
Camaro Addiction
No, local dealer but have visited Hennessey to plan mods which I have not decided completely yet.
#25 |
BAQNBLK
Drives: 2010 SS/RS BLACK W/INFERNO PKG Join Date: May 2009
If any of the ZL1's "Brother's" get jealous of the new "baby" coming home, I'd be honored to take custody of them, and open up my garage......... I mean "home" to one of them. Just let Uncle Derrick know o.k. buddy?
| Tags |
| vin, zl1 |
| Thread Tools | |
| CAMARO WIKI | Tran | Wiki | 42 | 05-18-2013 09:32 AM |
| Some info for ZL1 owners | R6P | Camaro ZL1 Forum - ZL1 Specific Topics | 60 | 04-30-2013 06:11 PM |
| the best muscle there ever will be | rs-lt-camaro- | Camaro ZL1 Forum - ZL1 Specific Topics | 49 | 12-14-2011 08:57 AM |
| New Camaro ZL1 Video Feature - Phase Four: Aerodynamic Testing | 1BADZL1 | Camaro ZL1 Forum - ZL1 Specific Topics | 104 | 11-13-2011 03:24 PM |
| Little ZL1 | GoldenBear | Camaro ZL1 Forum - ZL1 Specific Topics | 19 | 09-27-2011 08:38 PM |
